Wheel Spacer Recommendations?
Discussion in 'Wheels & Tires' started by Triton19X2, Feb 28, 2018.
  1. Aug 13, 2018 at 1:43 PM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Spidertrax or G@ both make good hub centric spacers. Don't go cheap on this mod
    SoCal619 likes this.
  2. Aug 13, 2018 at 1:56 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    I’ve always been told (by guys I trust) to just never do spacers.
    Better to save and just buy wheels with the right offset?
    It’s not the ideal answer... but spacer malfunction could be real bad.
    SloppyJ likes this.
  3. Aug 13, 2018 at 2:02 PM
    Uncle Nine
    Uncle Nine New Member
    2004 Tundra Limited
    The Tundra came with newish ocersized tires. Hardly any space between them and the shock. Plus there isnt a full turn without spacers in. The wheels are OEM
  4. Aug 13, 2018 at 4:05 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Both Spidertrax and Bora are hub centric and both good brands
  5. Aug 13, 2018 at 4:56 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I have a set of spider track that I planned to use but went another route. Message me if interested.
    Gio1971 likes this.
  6. Aug 15, 2018 at 4:00 AM
    Fired
    Fired Flame Extinguishment Specialist - Ret.
    The LowCountry
    '18 Limited Dbl Cab TRDOR
    Swapped 5.7 for V6
    I went with the Bora 1" on front from Wheelers. Just clears OE hub studs & keeps tires relatively even with fender lip.
  7. Aug 15, 2018 at 8:17 AM
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    2023 Black SR5 Crewmax Long Bed
    I'm going to agree with this answer as well. I had very good hub-centric aluminum spacers on my last truck and I will never own another pair again. You need to make sure that the existing lugs will not poke out and hit your wheels. You also need to make sure of this with your spare since the actual wheel is different. It'd be a bad deal if you got a flat out on the side of the road and couldn't install your spare because of the spacers. Some tips if you get spacers: Use locktite and a proper torque wrench on the nuts that attach the spacers and use copper based anti-sieze where your wheel hugs the spacer.
    Within 20k miles of adding my spacers on my old truck, I needed new bearings. Not sure if it was a coincidence on the bearings but I didn't like the overall feel after putting some miles on the truck with the spacers. This is completely personal but if I ever desire to change the offset, I will just save for new wheels. Tons of people run spacers and I think they are safe if installed correctly but I didn't care for them. Good luck either way you go!
  8. Oct 2, 2018 at 7:57 AM
    Gio1971
    Gio1971 New Member
    Giovanni
    2016 Tundra Limited TRD package
    Leveled 3/1
    I’m interested. What width are they?
  9. Oct 2, 2018 at 8:04 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
  10. Oct 2, 2018 at 11:01 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  11. Oct 2, 2018 at 3:15 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    Sorry these are gone.
  12. Oct 2, 2018 at 3:20 PM
    Gio1971
    Gio1971 New Member
    Giovanni
    Leveled 3/1
    Thx Bud
  13. Nov 6, 2018 at 8:10 AM
    jptshadow
    jptshadow New Member
    Hey, guys, so I am thinking running 20X9, +1 offset with stock tires. Do you think adding the spacers would rub anything?
  14. Oct 5, 2019 at 5:22 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I know this is old but I bought a pair of G2 spacers off of here from a member for my 02 Tundra...hopefully they hold up
  15. Apr 22, 2021 at 7:18 PM
    yikes84
    yikes84 New Member
    yiking
    sell me them lol
  16. Apr 22, 2021 at 7:37 PM
    MoonRock2021
    MoonRock2021 New Member
    2021 TRD Pro Crewmax Lunar Rock 2021 4Runner Nightshade
    Bora's 1.25 although they're special order and takes about 3 weeks.
  17. Apr 22, 2021 at 9:05 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    3 years too late, I would otherwise ;)
