What's with all the 2021 issues?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bergy24, Sep 7, 2021.
  1. Feb 26, 2023 at 1:52 PM
    #151
    eagleguy
    eagleguy New Member
    Joined in Aug of 21, Started this post in Sept 21? What specifically is wrong with your truck??
  2. Feb 26, 2023 at 2:04 PM
    #152
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Knock on wood since I bought my 21 LunaRock Pro I’am very anal with keeping my vehicles clean. My paint has been flawless. Cleans up really nice and don’t show the dirt much when it’s dirty. Yes people complain about Toyota’s paint. So far very happy with my paint.
    WAtundra4x4 likes this.
  3. Feb 26, 2023 at 6:38 PM
    #153
    Bergy24
    Bergy24 [OP] New Member
    2021 Cement Crewmax Limited TRD 4X4
    At the time, I was just reading posts that seemed like the 21’s had more problems.
    To date, I had to have my steering rack replaced due to the recall.
    I do have a couple small paint chips from road debris.
    Knock on wood, that’s the only issue to date.
    IsaiahCanada likes this.
  4. Feb 26, 2023 at 6:47 PM
    #154
    itsallgood101
    itsallgood101 New Member
    Randy
    Southern Utah
    2021 Tundra SR5 4X4 crew max
    I have a 21 39k miles yup i had to change oil a few times rotate tires
  5. Feb 26, 2023 at 7:00 PM
    #155
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Bought a used 2018. As soon as the 2022s made their reveal (design and drivetrain), I decided to trade up to a 2021 to have this platform new. Been to the dealer 1 time since I bought it, that was for the 5k toyota care interval, haven't been back and done all my own maintenance at 5k OCI.
    Few minor things I've noticed, likely no fault to Toyota, it seems the truck dents fairly easy and I got a chip in my hood bulge (probably from a rock). Outside of that, couldn't ask for a better 1/2 ton IHMO that fits all my needs.
  6. Feb 27, 2023 at 4:03 PM
    #156
    eagleguy
    eagleguy New Member
    Just a suggestion but don't read into the post on the forum. Enjoy the truck as someone somwhere will always post about something negative. Its human nature.
    Wanna go nuts? Get into the I need the trans cooler that Toyota decided I don't!!!
    Dirtytruck, Mike59 and Cpl_Punishment like this.
  7. Feb 27, 2023 at 4:20 PM
    #157
    Bergy24
    For the most part, I now read through the posts and try not to worry about it too much.
    Trust me, I already was looking into the trans cooler as well. Still on the fence if I should add one or not, LOL
    Dirtytruck likes this.
  8. Mar 4, 2023 at 10:26 AM
    #158
    Ike
    Ike New Member
    2021 Toyota Tundra Limited Double Cab Magnetic Grey
    I bought a 2021 limited extended cab exactly one year ago with 7000 miles on it. There is now just under 15k. It has been an outstanding truck so far. No rattles or squeaks or any other issues. After a year of ownership my only complaints are no rear window defrost grid, no heated steering wheel and no transmission cooler.
    I traded in a 2015 Tacoma that I had 6 years and was a disappointment. It rattled in the seat rails that the dealership said they could not fix. It sagged on one side that also annoyed me. The overall fit and finish not as good as the tundra.
    I also had a first gen tundra 13 years that frame rotted out with only 106,000 miles.
  9. Jun 9, 2024 at 10:15 PM
    #159
    Dirtytruck
    Dirtytruck Overkill it
    2021 SR5
    Bought my ‘21 SR5 new. I’ve got right at 70k on it now. 99% highway miles. No mechanical issues to speak of. I stopped going to the dealer for maintenance long ago and do all the fluid maintenance myself. The only exception is the brakes, brake fluid, turning rotors.
    “Ike”. If interested check out Genuine Cooling Systems.com. I installed a transmission cooler from him and couldn’t be happier. All the parts are OEM except the cooler. Everything bolts right up and only cutting a 1” hole to run the soft lines thru the plastic shroud next to the radiator.
    Henry1jg and QuikreteTundra like this.
  10. Jun 9, 2024 at 10:40 PM
    #160
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    I have a 21 longbed
    only 21K miles as of today
    Dodged the steering recall
    Good truck
    Design is smooth, simple, and so far has been reliable
    To me it seems like a really solid year of Tundra, I bought and sold a '21 tacoma in '21, it was less than half the truck of the '21 Tundra having driven both for at least 1000 miles.
  11. Jun 10, 2024 at 5:23 AM
    #161
    icodeintx
    icodeintx New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    The only problems with my 2021 is it likes gasoline and it collects dirt on the paint.
  12. Jun 10, 2024 at 7:44 AM
    #162
    eagleguy
    eagleguy New Member
    My biggest problem as well. Boy do those gas pumps digits fly!
  13. Jun 10, 2024 at 12:30 PM
    #163
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I get worried if I DON'T hear it now.
  14. Jun 10, 2024 at 7:45 PM
    #164
    icodeintx
    Scott
    Palacios, Texas
    Sometimes I think those number are lying similar to those numbers on the scale
  15. Jun 12, 2024 at 1:35 PM
    #165
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
    Mine has the same problems
  16. Jun 15, 2024 at 6:10 AM
    #166
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    My '21 has been great for the 9 months and 9k miles I've had it. Only quirks have been Android Auto cutting out a few times, but that's on me as my charging cord is like 5+ yrs old. The other is the 'brake' light that will flash if the vehicle thinks you should be stopping has sounded the alarm 3 times, none of which were times I actually needed to as I was on open road. Weird, but whatever. I turned off all the various chimes.
    I absolutely love this truck!
  17. Sep 22, 2024 at 9:09 PM
    #167
    imgreenlantern2
    imgreenlantern2 New Member
    Snake Plissken
    Central Texas
    2021 Tundra TRD Pro Double-Cab
    285/70/18 Nitto Ridge Grapplers. RCI rock sliders Leer Tonneau Cover NSV Hood Mounted Lightbar. Suspension air bags for better towing.
    My 2021 Tundra TRD Pro which I bought brand new just hit 62,458 miles today. Outside of oil changes (I use Amsoil Signature Series) and tire rotations, I have also services the front and rear diff fluids and radiator fluid changed at 50,000 miles. I just had the transmission and brake fluids changed at 60,100'ish miles. I do a lot of towing so fluid maintenance is really important. My Tundra pulls a 7,400 lbs. boat (combined weight with trailer) every other weekend, and I have a trailer that I lug around six ATV's on that my family regularly enjoys. That trailer with the ATV's runs almost 6,000 lbs with the trailer and fuel.
    I have owned a lot of 1/2 ton trucks over the last 20 years, and none of them tow as good as this Tundra does. That 4.30 rear end is incredible.
    Overall, this Tundra has been flawless.
  18. Sep 23, 2024 at 2:37 AM
    #168
    Bergy24
    Did you add a trans cooler or leave it as it came from factory?
  19. Sep 23, 2024 at 3:31 AM
    #169
    Retired...finally
    My 21 had to have new wipers installed. Well, not really. I just thought it wouldn't hurt. Still just shy of 36K miles and tomorrow morning I hitch up the travel trailer and head south for the winter....Again. 4 years in a row.
    Cpl_Punishment likes this.
  20. Sep 23, 2024 at 3:46 AM
    #170
    Bergy24
    Mine is about to turn 15,000 miles and I had one wiper blade that was torn and needed replaced. Considering it has been 3 years of sitting outside, I thought it had a good life span. (Replaced with OEM- not sightline)
  21. Sep 23, 2024 at 3:53 AM
    #171
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Please edit thread title to: 2021 Tundra... Truly a Piece of Crap.
    Thx!
    Cpl_Punishment and Oey12 like this.
  22. Sep 23, 2024 at 3:58 AM
    #172
    Bergy24
    LOL, I cant believe that I had to replace these wiper blades after only 3 years.
    Seriously though,
    I drive a 2022 F150 (5.0) extended cab during the week for work and the Tundra or GX on the weekend.
    Driving these vehicles on the weekend is one of the highlights of the week.
  23. Sep 23, 2024 at 5:19 AM
    #173
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    I bought a 2021 this year. It only had 19K on the clock at the time. To date, I have put another 5K miles on it.
    Apparently, there was something wrong with the exhaust system. I only know this because the wife insisted I replace it immediately with a straight pipe system from Dirty Deeds. It does sound much better now, so it seems she was right as usual.
  24. Sep 23, 2024 at 10:50 AM
    #174
    imgreenlantern2
    Snake Plissken
    Central Texas
    I did add a transcooler onto my 2021 Tundra. https://genuinecoolingsystems.com/
    It has been fantastic and worth every penny. It is still upsetting Toyota took that off.
    Bergy24[QUOTED][OP] likes this.
