What's with all the 2021 issues?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bergy24, Sep 7, 2021.
  1. Sep 12, 2021 at 8:59 PM
    #91
    Big Dog
    Big Dog New Member
    Alan
    2021 Limited 4x4
    Got mine in March and just about 15K. Only issue is the roof molding insert on drivers side does not like car wash air dryers. It flops off, dealer replaced once and still happens, will try some silicon. Otherwise, all is well.
    Henry1jg likes this.
  2. Sep 12, 2021 at 9:18 PM
    #92
    xSkeme
    xSkeme New Member
    2017 White Tundra SR5
    Haven’t heard of any problems
    Bergy24[QUOTED][OP] likes this.
  3. Sep 13, 2021 at 5:46 AM
    #93
    Robster80
    Robster80 New Member
    8k. No issues. However is it just my truck or do the doors on the tundra not close just right? Alot of times ill hafta open door and close it harder. All 4 doors. Just a slight annoyance
    Bergy24[OP] likes this.
  4. Sep 13, 2021 at 7:02 AM
    #94
    Bergy24
    Bergy24 [OP] New Member
    2021 Cement Crewmax Limited TRD 4X4
    I have noticed that too. Almost like the air pressure from the inside is holding it back from closing unless a little force is used
  5. Sep 13, 2021 at 7:04 AM
    #95
    Robster80
    Exactly. Happens pretty much every time i close it
    IsaiahCanada likes this.
  6. Sep 13, 2021 at 7:27 AM
    #96
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Correct. Tight air seal.
    You can confirm by rolling down one of the windows, in order to allow air to escape.
    This is why when getting a new windshield, the tech advises to crack the windows during the first day, to allow air pressure to escape while the adhesive to sets. One could blow the new seal if closing the doors with all windows closed.
    IsaiahCanada, Mike59 and Robster80 like this.
  7. Sep 13, 2021 at 7:38 AM
    #97
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Indeed.
    Two week road trip in October. It will be about 4,000 miles.
    Mwah ha ha...
    And yes, I changed the oil at 1,000 miles and drove easy during the recommended break in period.
    OP: Did you get the new truck? Got pix?
    Mike59 likes this.
  8. Sep 13, 2021 at 7:45 AM
    #98
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    GM seats are really really bad. They need to change suppliers.
    I'm a big stickler for seats. And I have to say they're pretty comfortable to me. With all the comments I read prior I was nervous, but other than needing a little more side bolstering, I think they're good.
    avssuc[QUOTED] likes this.
  9. Sep 13, 2021 at 8:01 AM
    #99
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    only thing that i dislike is how the grab handle to close the door isnt adhered and can butch up especially when hot, in other words it feel loose and cheap.
  10. Sep 13, 2021 at 9:09 AM
    #100
    IBeam
    IBeam New Member
    Southeast Texas
    2021 SR5 CM 4x4 Trail Edition, bed-mounted M2
    Yep, disappointed after less than 3000 gentle miles. First thing was the driver's seat belt latch -- stopped working altogether probably a hundred miles after purchase, and the truck pulled hard to the right (dealer had it for a day. Was okay for a while, now doing it again. Now the seat gives a thud sometimes upon acceleration or braking or sometimes just getting in the seat. I have also now noticed that there is a paint issue at the edge of the rain gutter with what looks and feels like dried paint droplets. I also see that there is a light dent in the body of the truck where the driver enters on the floorboard edge (the painted metal part). I certainly did not do that and I cannot image in the dealer doing it either. Less of big deal is the tailgate cables, with one being much too short.
  11. Sep 13, 2021 at 9:21 AM
    #101
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    When I was detailing and doing the running boards installation I noticed 2 paint defects. Looks like contaminants or dirt under the paint. It's in 2 spots where it doesn't bother me and it would probably be worse if it was attempted to be corrected.
  12. Sep 13, 2021 at 9:37 AM
    #102
    Bergy24
    I picked it up last Friday, already installed the TRD Rear sway bar and bed mat, and order the AVS in channel vent visors.
  13. Sep 13, 2021 at 3:11 PM
    #103
    iloqin
    iloqin New Member
    2021 Cement Limited Crew Cab
    If you leave the AC on when you turn it off, then turn in in a couple of days, no grind. This grind apparently happens if you've let the truck sit for at least a couple of days, turn it on, and then turn on the AC right after. After the engine is warm, there is no noise. So if you went to the store and back when you turn it on, it won't grind. My little work around is just leaving the AC on before I turn the truck off.
    Wallygator and Oey12 like this.
  14. Sep 13, 2021 at 3:13 PM
    #104
    iloqin
    iloqin New Member
    Have a limited Cement Gray Crewmax I got in January 2021 (this year), no issues. Although the AC grind is annoying, I just leave the AC on before I turn off the truck.
  15. Sep 13, 2021 at 3:15 PM
    #105
    iloqin
    iloqin New Member
    So glad it wasn't just me. I def have to use some force closing the doors.
    Robster80[QUOTED] likes this.
  16. Sep 13, 2021 at 3:31 PM
    #106
    TRDFett
    TRDFett New Member
    PA
    21 Tundra Limited
    Good to know... I have noticed a few times the charging port stops working with Carplay. Time for a new cable I guess.
  17. Sep 14, 2021 at 8:57 PM
    #107
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Thanks for posting the pix. Beautiful. You even got a sunset pic.
    Congrats.
  18. Sep 16, 2021 at 5:42 PM
    #108
    DavidinPhx
    DavidinPhx New Member
    Phoenix
    2021 DC Tundra SR5
    Icons, Deavers, 34s, 4.88s, F&R e-lockers, Ovrlnd Camper, & other stuff
    Zero problems, since I bought my 21 in December 20. 5000 miles, about 200 off-road miles and I love it. My 09 Tacoma, which was the best truck I ever had up to this point had to have its transmission replaced at 1500 miles, and had a few persistent AC and fan issues. The tundra is actually far better built.
    FWIW JD Power came out with their 2021 Initial Quality Study just recently. The ‘21 tundra won their award for the lowest number of problems per 100 vehicles in the 1/2 ton truck category.
    I do think COVID and supply chain issues may have impacted some recently built vehicles, but I hope not.
  19. Sep 16, 2021 at 6:09 PM
    #109
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I was gonna have Toyota look at this issue…thanks for the info.
  20. Sep 17, 2021 at 12:24 PM
    #110
    PapPap
    PapPap New Member
    Tennessee
    2021 TRD Sport
    That's because the cabin is air tight. Leave another door or window open and close the door, you'll notice a big difference.
    BowChicka and Robster80[QUOTED] like this.
  21. Sep 17, 2021 at 12:33 PM
    #111
    TRDSPEC
    TRDSPEC New Member
    2021 @ 5 months no problems or failures.
  22. Sep 19, 2021 at 4:59 PM
    #112
    Undercover
    Undercover New Member
    Maryland
    2021 Tundra TRD Pro CM MGM
    Had the same thing happen with my ‘21 two days ago. Not sure what the deal is but doesn’t seem normal.
  23. Sep 22, 2021 at 1:07 PM
    #113
    Jackattack82
    Jackattack82 New Member
    2020 Platinum
    BedRug, Toyota rear power tailgate lock, tonneau cover
    That's not your bushing, that's your skid play against the rear cross member. Cut a small section of rubber floor mat loosen to rear skid bolts sneak the rubber between and re torque. Problem solved!
  24. Sep 22, 2021 at 7:35 PM
    #114
    eagleguy
    eagleguy New Member
    ITS YOU!
  25. Sep 23, 2021 at 12:37 PM
    #115
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Not quite 1000KM's on my 2021 and not an issue. Feels much more solid than my '17 F150 eco and the mileage is "slightly" worse but not bad considering.
  26. Sep 23, 2021 at 1:51 PM
    #116
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    Got mine Sept 2, 2021. Almost 1k miles and no mechanical issues at all. However, the front bumper on the passenger side hangs lower than the driver side. about 1/2" difference on the gap. It does not really bother me but now that I've seen it, I can't unsee it lol. Will be telling the dealership to fix it on my 5k service.
    Mike59, JDR76 and IsaiahCanada like this.
  27. Sep 23, 2021 at 1:53 PM
    #117
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    My front bumper was the same way. I should have taken a picture of it. I had the dealer fix it for me under warranty. There are also some posts/threads on here about how to fix that yourself. Doesn't look too bad.
    50Shades[QUOTED] likes this.
  28. Sep 23, 2021 at 1:58 PM
    #118
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    100% this. I know people like to complain about the interior materials and general outdatedness of the truck, but everyone else in my family (wife, grandpa, dad, father in law, brothers in law, uncles, great uncles, etc) drives a full-size domestic whether it’s a half ton, HD truck, or a Suburban/Yukon/Expedition. NONE of those vehicles feel anywhere near as solid as my truck. The only truck I felt was as solid is my buddy’s ‘14 Chevy HD gasser. Everything else just rattles down the road like mad.
  29. Sep 23, 2021 at 2:16 PM
    #119
    50Shades
    J
    West Coast
    Ohhh I'll look into that. I thought maybe it was just a little QC issue with my truck. It's my first ever toyota truck lol.
    I'd rather work on my own vehicles than take it to a dealership but hey if it's covered by warranty, why not? lol
    JDR76[QUOTED] likes this.
  30. Sep 23, 2021 at 2:30 PM
    #120
    ToyotaG
    ToyotaG New Member
    I have my trans cooler orings missing in my 21 tundra. In my 5k service from toyota they got it fixed. Besides that i have had 0 issues. Currently 16k miles
