What's in your rear end?
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, Mar 25, 2019.
  1. Mar 7, 2021 at 3:16 PM
    #121
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    We know it's dark in there like you like things, but unnecessary to post rear end pictures that IS gross.
  2. Mar 20, 2021 at 11:52 PM
    #122
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Snapped a pic while swapping my diff for one with LSD.
    des2mtn and Darkness[QUOTED][OP] like this.
  3. Mar 21, 2021 at 9:44 AM
    #123
    coTony
    Tony
    Montrose, CO
    I regeared and have my LSD carrier in the garage. Truthfully, I am not sure what the LSD a looks like when it is removed
  4. Mar 21, 2021 at 9:59 AM
    #124
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Here's what it looks like.
  5. Mar 24, 2021 at 6:41 AM
    #125
    coTony
    Tony
    Montrose, CO
    Mine are just the brake applied simulated LSD on my 2018 but I put Harrop lockers in
  6. Mar 24, 2021 at 9:00 AM
    #126
    Darkness
    Darkness [OP] Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    First gen use a real LSD, except for a few late models that have brake assist traction control crap. 2nd and 3rd gen are different.
    Good choice on the Harrop.
    des2mtn likes this.
  7. Mar 24, 2021 at 3:01 PM
    #127
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Here's a pic of an open diff.
    FirstGenVol, Voss and jimf909 like this.
  8. Aug 4, 2021 at 12:00 AM
    #128
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'll be using this soon as I was paying attention when @FirstGenVol, and @jpink changed John's fluid. The mangler had no issues doing this, so I shouldn't either.
    I'm assuming I'll poke my eye into the bunghole for nothing, but that's okay. I am a butt snorkeler after all.
    If I can find something for cheap down the road a ways I may swap, or have it swapped for a real LSD or something. Any help for my two wheel peel will be nice. Any suggestions welcome, or links to more information.
    Toyota Build Specs shows no info on LSD for me. Assuming Open diff which is just what I've assumed forever.
    Darkness[QUOTED][OP] and bmf4069 like this.
  9. Aug 4, 2021 at 8:44 AM
    #129
    Strangebird22
    Strangebird22 New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    Not photos of their whole rearend....... Just their bunghole:rofl::rofl:
    bmf4069 and Darkness[OP] like this.
  10. Aug 4, 2021 at 11:33 AM
    #130
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Just cause you said not to, I'm going to.
    Desert Dog and Lil Steve like this.
  11. Aug 4, 2021 at 11:51 AM
    #131
    Strangebird22
    Terry
    Ohio
    Damn I wish my rearend was that CLEAN (rust free)!!
    bmf4069[QUOTED] likes this.
  12. Sep 19, 2021 at 6:54 AM
    #132
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Gasket change
    bmf4069 and Desert Dog like this.
  13. Jun 2, 2023 at 2:52 AM
    #133
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    My truck has a 3.91 LSD rear from the factory. I just found a guy who has a 3.91 (3rd unit/carrier assy) for sale at a good price, apparently after upgrading to a different ratio. I don't really need one (yet) at 240,000 mi, but I'm willing to buy it to have when I need it. Here's the thing...it's from a 2005 DC. Does anyone know if this will fit my truck? The parts system doesn't seem to specify a p/n for the complete carrier assy.
  14. Jun 2, 2023 at 5:22 AM
    #134
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    @Shifty @empty_lord ?
  15. Jun 2, 2023 at 5:25 AM
    #135
    Jack McCarthy
    Jack McCarthy My work anxiety is my morning alarm clock
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Clean it and coat it in POR-15 to protect it for years. Mine only has minor surface rust and I’ve been driving mine for 21 years in the salt belt.
  16. Jun 2, 2023 at 6:52 AM
    #136
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Should be the same
    w666[QUOTED] likes this.
  17. Jun 2, 2023 at 9:30 AM
    #137
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    ^ this.
    It might have a different pinion flange. Which can be swapped. That'll be the only possible difference.
    FrenchToasty and w666 like this.
  18. Jul 12, 2023 at 4:18 PM
    #138
    w666
    Maryland
    So I bought the used 3rd unit and it's great. ~ 120,000 miles and effectively zero backlash (I haven't put a dial gauge on it yet). But I can now confirm that I do need to swap the flange. The 2005 - 2006 flange is larger, and the hole spacing is 66 mm vs 60 mm.
    Q: Does anyone have a flange (maybe from a blown out rear) laying around that I can bargain for? I'm hoping to get the flange installed and properly torqued while it's out of the truck so the 3rd unit swap is quick and painless. Maybe I'm just being lazy...I can probably just pull my old flange and make the swap, just adding another day to the ordeal. (The seals are the same for both years, I checked already).
    Timmy the Toolman has a video where he changes the pinion seal and re-installs the flange without setting the preload (theory being that staking the nut in the same place will more or less approximate the original torque. Seems legit...I would do this if I were laying under my truck and only changing the seal. Since I want to use a different flange, however, this seems like not the best approach. Or am I being to AR about this?
    Q: Has anyone been to this movie before?
  19. Aug 29, 2023 at 3:05 PM
    #139
    Aaol1
    Aaol1 New Member
    Sam
    05 DC tundra TRD offroad 4x4 V8 w/ LSD and tow
    2 inch lift, diff drop
  20. Aug 29, 2023 at 3:36 PM
    #140
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    If you don't see the LSD sticker on the rear of the pumpkin, I recommend checking out this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    It'll help you understand what you need to be aware of for the truck as a whole, and it also should help you sign up for the Toyota Owner's website, so you can link its VIN to you, check on recalls, and print out the options build sheet, which would list if it came from the factory with LSD.
  21. Aug 29, 2023 at 3:45 PM
    #141
    Aaol1
    Aaol1 New Member
    Sam
    For sure! Definitely no sticker, and I tried the vin but it's a Canadian truck, and it has minimum info on it when entering the vin ( nothing under equipment) , I'm guessing that's the case because it's Canadian?
    The original post on this thread talks about looking into the housing, and others have done the same, just hoping someone can recognize with my photo and video
  22. Aug 29, 2023 at 7:39 PM
    #142
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Looks like an LSD case to me.
    LSD:
    Open:
    Jack McCarthy likes this.
  23. Aug 30, 2023 at 5:59 AM
    #143
    Shouldn't be the case, I don't think? But actually ....
    After signing in to https://www.toyota/com/owners I click on the Owners button, then on Vehicle Specs link
    From there, I plug in my VIN number in the box provided and submit...
    Sometimes it takes a minute for the data to load, when it does, you should be able to download a PDF of your truck's specs using the circled link, or just scroll down in the page to view the specs.
    It looks like Toyota has done screwed something up again, because here's a side-by-side on what the new Owners website puts out (right) versus what it put out a couple years ago (left)... you can see, Toyota is strangely omitting a crapload of info here...
  24. Aug 30, 2023 at 6:39 AM
    #144
    Aaol1
    Aaol1 New Member
    Sam
    Yea tried exactly that and I get next to nothing, same results as before
  25. Aug 30, 2023 at 6:41 AM
    #145
    Totally bogus. If I had a Twitter account, I'd probably lambast Toyota of America over this, tell them they need to fix their shit.
  26. Aug 30, 2023 at 6:43 AM
    #146
    Aaol1
    Aaol1 New Member
    Sam
    Even on the support page you can see in this pic, they only handle USA vehicles
  27. Aug 30, 2023 at 6:43 AM
    #147
    Aaol1
    Aaol1 New Member
    Sam
    And the Toyota Canada or Toyota north america websites have nothing like the USA one , where you get all the data
  28. Aug 30, 2023 at 6:44 AM
    #148
    What I posted above is from the N. America/US website. Clearly we're not even getting "all the data" after Toyota's changed things on their end...
  29. Sep 29, 2023 at 3:13 AM
    #149
    Hard_Knox_Blount
    Hard_Knox_Blount New Member
    East Tennessee
    2005 Tundra SR5 4.7 DC 4x4
    None yet, but big plans
    Sorry for bringing this back from the dead, but I recently acquired a 2005 DC 4x4 and I'm looking to build out a new rear axle with disc brakes. My current axle is severely rusted and is seeping gear oil through the housing. This thread was very helpful for discerning differentials, but when shopping salvage parts for a new axle housing, are they all the same for our trucks if I stay within the same model year(05-06)? I.e. 2wd vs 4wd, LSD vs Open, AC vs DC, ABS vs non-ABS, etc. Thanks in advance for any help I may get regarding this.
  30. Sep 29, 2023 at 8:36 AM
    #150
    Hey hey another E. Tennesseer! @FirstGenVol @janbrochill and I'm missing someone but it's expected.
    The info dump/intro dump thread doesn't have that info directly, just that you need to stick with your cab type if double cab.
    There's a bunch of threads around here that have throwbacks to what the various gearing is across years, cabs, trim packages. Someone here has a grid or layout. I just keep hitting threads like this: https://www.tundras.com/threads/rear-diff-swap.124533/#post-3311468
    Maybe it's @assassin10000 who knows, or @BubbaW?
    janbrochill and Hard_Knox_Blount like this.
