What Tire PSI are you running?
Discussion in 'Wheels & Tires' started by georgiey22, Jan 27, 2019.
  1. Jan 28, 2019 at 6:44 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    35 psi all around. I did lower it to 33 psi for a better ride but noticed performance issues. Brought it back to 35 psi. I did email General Tire for there recommendation for tire pressure. They said 37/42, tried it and truck road like shit. 35 psi seems to be key number. Bear in mind I have a DC, I weight less then CM.
    14burrito likes this.
  2. Jan 28, 2019 at 6:53 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    There are many factors that influence the ideal tire pressure. The door jam sticker is a general guide for stock tires on stock wheels. When you go with wider tires, different sidewall ratio, load rating etc., it all impacts the required pressure. Mine (stock Sport Bridgestones on stock wheels) were wearing along the outsides close to the sticker pressure, so I had to increase by 10 psi to get it to wear even.
    Wear along the outside indicates too low pressure; more wear along the center tread of the tires indicates too high pressure. The best is to keep an eye on the wear and adjust accordingly.
    15whtrd likes this.
  3. Jan 28, 2019 at 7:01 AM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    42psi all the way around, 285/55R20 BFG KO2’s
  4. Jan 29, 2019 at 9:20 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    44 on similar 10 ply with 80psi rating. Will do the Chaulk test in the spring. Runs well at this PSI but may go higher
    Adriver71x[QUOTED] likes this.
  5. Jan 29, 2019 at 9:22 AM
    CookieMonsterTundra
    CookieMonsterTundra New Member
    Trip
    2018 1794 Tundra
    41-42 PSI on all four stock tires.
