What PSI ?
Discussion in 'Wheels & Tires' started by geno0506, May 11, 2017.
  1. Mar 1, 2018 at 7:07 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    How much over? I run like 40-46 and never get a light.
    Wondering if I would get a light on some high E rated tire with like 70psi. Lol.
  2. Mar 1, 2018 at 7:09 PM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    I’m not sure what my current PSI is. I’d have to go find out
  3. Mar 1, 2018 at 8:22 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Yes get a simple air pressure gauge. And if you get non OEM tires get the same or higher load index :thumbsup:
  4. Mar 1, 2018 at 8:52 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    285/65r18 K02's. Run them at 46. No sensor light on. They seem to ride just fine at this pressure.
  5. Mar 1, 2018 at 8:56 PM
    pschiller86
    Paul
    Temecula, CA
    I took the air down to about 40 psi. Light still on... drove about 7-10miles, still on.
    What should I do next?
  6. Mar 1, 2018 at 9:12 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I don't think the light comes on because of more pressure. You say you just got some pro wheels? did u use ur sensors from ur old rims? where they steel? if they were steel rims that might be the problem. its a different sensor
  7. Mar 1, 2018 at 9:16 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Yeah it’s not the psi. I run 40-46 and no issues.
  8. Mar 1, 2018 at 9:34 PM
    pschiller86
    Paul
    Temecula, CA
    Yes I had the steel rims on before. So I need different tpms sensors?
  9. Mar 1, 2018 at 9:36 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    if I'm not mistaken. I have heard for some ppl they work for some they don't. Double check tho but I'm pretty sure that's why ur light is on
  10. Mar 1, 2018 at 9:37 PM
    pschiller86
    Paul
    Temecula, CA
    That makes sense though. I know for sure the shop swapped sensors from the steel wheels to the pros ...
  11. Mar 1, 2018 at 9:42 PM
    pschiller86
    Paul
    Temecula, CA
    It’s weird because on @Roman website it looks like the same sensor is used all tundra models.
  12. Mar 1, 2018 at 10:09 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Roman likes this.
  13. Mar 1, 2018 at 10:15 PM
    pschiller86
    Paul
    Temecula, CA
  14. Mar 1, 2018 at 10:18 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Lol... I know what you mean. There goes the gas money for the week, right!?!?
    :burnrubber:
  15. Mar 2, 2018 at 6:23 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    The TPMS on the steel wheels are different from the aluminum wheels. Type A is for aluminum, and type B is for steel:
    Big J likes this.
  16. Apr 5, 2018 at 3:49 PM
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    Did you get this fixed?
  17. Apr 5, 2018 at 3:53 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I run 30/33 psi on 35 inch KO'2. The only thing I care about is cushy soft comfort...
  18. Apr 5, 2018 at 3:58 PM
    17inferno
    17inferno New Member
    I have ridge grapplers, and run what "feels" good. In my case its what the door jamb says. They were 50 psi when I left the tire installer and was rough...285/70/18.
  19. Apr 5, 2018 at 5:02 PM
    #49
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    NRG 295/70R18:
    42/40 empty bed
    52/50 when towing
    Can’t remember where I got that from, will do chalk test lol
  20. Apr 5, 2018 at 5:05 PM
    #50
    chphilo
    chphilo Tundra addict
    Western PA
    When I first got Trail Grappler, my local shop people had it inflated to 65 psi. I did not get the TPMS light at that pressure.
  21. Apr 5, 2018 at 5:23 PM
    #51
    pschiller86
    Paul
    Temecula, CA
    Yes and no. I learned that steel wheels and the alloys have different tpms. So, I need to buy the correct system.
  22. Apr 5, 2018 at 7:05 PM
    #52
    PBH
    PBH New Member
    Destin Fl
    2018 Tundra Crewmax xsp
    Same psi on front & rear? Dealer told me aprrox 4-5 more psi on rear.
  23. Apr 6, 2018 at 2:28 PM
    #53
    Festo
    Festo New Member
    For those referencing the door jam sticker those numbers are for the tires you got with the truck...more than likely P rated tires. When you upgrade to E's the sticker on your door means nothing at that point.
    I've been searching for info as mine came with the Michelin P275's and when i switch to E's as i do pull a 4500lb boat a fair amount i want to find what psi i should be running while towing and while not towing on an E rated tire. I suppose i will contact the tire manufacturer once i decide which ones to get as there is a lot of different answers out there.
    And also hello to all as this is my first post!!
  24. Apr 6, 2018 at 2:38 PM
    #54
    17inferno
    Welcome Festo! I think most get that about the door psi, which is why everyone else runs 40's and up...for me that just so happens to be what makes my truck ride soft and handle well the way I want . I'd do 25 if my tpms wasnt on:)
  25. Apr 6, 2018 at 3:35 PM
    #55
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Should be less if anything because it’s lighter in the back.
    PBH[QUOTED] likes this.
  26. Apr 6, 2018 at 4:31 PM
    #56
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I emailed Toyo about proper PSI for at2, I told them what truck I had and what size tire I plan to go with (LT285/65/18). They asked what came on the truck and what the door jam says to run. After giving them that info they responded 36 front 39 rear. Once I get a set I'll start there and then do the chalk line test to see if it needs tweaking. I did fail to mention that I often pull my bass boat which is ~3,500#, prior to getting the tires I'll probably relay that info and see if their answer changes.
    Festo[QUOTED] likes this.
  27. Apr 14, 2018 at 5:40 PM
    #57
    Jk78Limited
    Jk78Limited New Member
    2018 Limited Crewmax
    I’ve been running 42-46 psi all around with my BFG ATs for years. They seem to wear good and the ride is fine
