What PSI ?
Discussion in 'Wheels & Tires' started by geno0506, May 11, 2017.
  1. May 11, 2017 at 2:32 PM
    geno0506
    geno0506 [OP] New Member
    Michael
    Hello all,
    trying to determine best PSI for my new 295/70/18 Nitto Ridge Grapplers while mainly riding on pavement highway and city!
    So far I went from 14.3 to 14.1 mpg
    What are you running in a similar set up
    2017 Tundra CrewMax 4x4
    5.7
    295/70/18
  2. May 11, 2017 at 2:38 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Go with the pressures on the label on the drivers door pillar.
    Or, 32 psi is good as s general rule.
    Sunnier and geno0506[OP] like this.
  3. May 11, 2017 at 3:01 PM
    Snoozer
    Snoozer New Member
    2014 MGM Sequoia Limited 4x4
    carseats
    geno0506[OP] likes this.
  4. May 11, 2017 at 3:35 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    39 on STTs
  5. May 11, 2017 at 3:38 PM
    geno0506
    Michael
    Yeah, I was thinking 39-40!
  6. May 11, 2017 at 3:41 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  7. May 11, 2017 at 4:11 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    Running 40 PSI in my KO2s. Played with 35-45 until I found best hwy ride quality and doesn't "look" overinflated.
  8. May 11, 2017 at 4:16 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I usually just run the max cold PSI allowed on the tires themselves.
    Big J likes this.
  9. May 11, 2017 at 4:17 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Huh, never heard of that "chalk test". Makes sense.
    Kids all grown up, no more sidewalk chalk laying around. Damn.
  10. May 11, 2017 at 4:24 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    That's kind of funny. We get all kinds of guys out in the glamis area with huge F-350's, 40" tires etc... they get stuck all the time and can't figure it out. I kick the tires and they're rocks. They have the pressures at 70-80. When I air em down to 15-20 they drive right out of the hole, w the trailer.
    I've known guys to make $2k over a big weekend pulling people out w a little Toyota or 1/2 ton and an air compressor.
  11. May 11, 2017 at 4:56 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I go 42-45 on my toyo AT's.
  12. May 11, 2017 at 6:42 PM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    I emailed BFG when I bought my ko2's they suggested 50 psi I'm at 45-46 50 about rattled my teeth outta my head felt every seam and pebble on the road lol
  13. May 12, 2017 at 7:00 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I am assuming that you are asking for only those tires with 80 max psi.
    I run 45 psi on my Trail Grappler.
    KCTundra likes this.
  14. Feb 6, 2018 at 12:45 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    are you guys using these numbers as cold or warm pressure? Im at 38 on my 295/70 Toyo ATII's and they are a bit rough still
  15. Feb 6, 2018 at 1:02 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    Call Nitto and ask them! I called Nitto on the larger size I had on my Sequoia and I just called Toyo an hour ago to get PSI recommendation for my LT285/60R20 Open County AT II Xtreme installed yesterday
    41F cold
    44R cold
    Will do a chalk test to adjust from that starting point. Nitto/Toyo are pretty good about recommendations. They were dead on with the Sequoia!
    Not sure what you previously had, but likely stock to Ridge Grapplers, there will be a decrease in MPG due to increased rolling resistance.
    BlueBottle likes this.
  16. Feb 6, 2018 at 1:07 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I run 40 psi in cooper stt pros on the road. Off road 25-28.
    aperezsh and BlueBottle like this.
  17. Feb 6, 2018 at 1:15 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    45 on my Ridge Grapplers. Subject to change.o_O
    boostedtrdpro and BlueBottle like this.
  18. Feb 6, 2018 at 1:21 PM
    TheBeast The Beach
    40 psi Toyo R/T
  19. Feb 6, 2018 at 1:59 PM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    40 psi on 275/60/20 Hankook Dynapro ATM
  20. Feb 8, 2018 at 6:01 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    This is what I do except I go 4-6lbs less than the max. Never had an issue.
  21. Feb 8, 2018 at 6:04 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    30-35psi on road LR E tire
    Roughly 10-20 off-road depending on terrain
    Bprose likes this.
  22. Feb 8, 2018 at 8:32 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I run 35 psi cold on my RG’s, same size as yours. I wore down the middle tread my stock tires pretty quickly running 40-44 psi in them. Still got 44k out of em though.
    14burrito likes this.
  23. Mar 1, 2018 at 3:40 PM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Will running a higher than "recommended" psi set off the Tire Pressure Warning Light?
  24. Mar 1, 2018 at 4:07 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Since I run higher than what is posted on the door stamp (like 40-46psi). I haven’t had any TPMS issues.
    I’d be curious if anyone tried it with like 75psi on some heavier rated tires. Like is there a threshold you can’t go over?
  25. Mar 1, 2018 at 4:34 PM
    pschiller86
    Paul
    Temecula, CA
    I'm curious about this as well.
  26. Mar 1, 2018 at 5:44 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Email Nitto. One of their engineers can give you what psi you should run. Thats what i did a few days ago when my Generals showed up. They were friendly and more than helpful.
  27. Mar 1, 2018 at 5:44 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    No. It won't.
  28. Mar 1, 2018 at 5:57 PM
    pschiller86
    Paul
    Temecula, CA
    So I just got my trd pro wheels and new tires installed. Tpms sensor is on. Installer said because the air pressure is higher than the oem recommendation.
  29. Mar 1, 2018 at 7:02 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    I think some of us was wondering how high of psi can you go without getting a tpms light? Or is there no limit aka no light at any psi above the minimum amount of psi?
    For what you should run that comes down to the tire, load index, hauling/towing/payload, etc. I’d say just make sure you all get the same load index or higher. And don’t go over the max psi rated for that tire. Keep the minimum psi what’s on the door. 1/2 tons usually around 35-40 +/- (typically)
  30. Mar 1, 2018 at 7:05 PM
    pschiller86
    Paul
    Temecula, CA
    My psi light is on after new tires. I think it’s directly related to the tire shop OVER airing my tires. Is that a thing?
