What octane gas do you use for your Tundra?
Discussion in 'Performance and Tuning' started by tundrathr0w, Jun 22, 2018.
  1. Jul 5, 2019 at 4:37 PM
    #241
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I ran 89 for the first time since I purchased my truck last year and was pretty surprised with how mellow the engine had become. I posted months ago about feeling a very slight vibration in my gas pedal at random, fast, intervals. My wife even commented on it, uh-oh...anyways @ColoradoTJ diagnosed my
    problem as a likely needle bearing (known issue), I did my research and agreed, it wasn’t problem I was going to throw a dime at, but good to be aware...fast forward to me using 89 for the first time last week, my gas pedal is smooth as butter now, no more slight “grindy” feel thru the pedal at all...I don’t know what to think...
    ColoradoTJ likes this.
  2. Jul 5, 2019 at 4:43 PM
    #242
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Its "all" in the additive package. A single fuel terminal may supply gasoline to all kinds of brands - Costco, Mobil, Shell, Kroger, Billy Bob's road stop. The bigger brands will supply their own additives -V power, Techron, Synergy, etc. (often the terminal will have tanks of the stuff on site, including "competitor" product to mix in) while the other brands might source something like Additech. 87 and 91/93 get the same amount of the stuff, and 89 is just a mix of the two
    Jrharvey02[QUOTED] likes this.
  3. Jul 5, 2019 at 4:52 PM
    #243
    Jrharvey02
    So all octanes of shell have this v-power that they only seem to advertise as in their top tier 89 here?
  4. Jul 5, 2019 at 5:02 PM
    #244
    Tundra_power
    Tundra_power New Member
    Nick
    This is all correct most but all has the same additives..
  5. Jul 5, 2019 at 5:04 PM
    #245
    ninjajay
    Spoolston, TX
    I don't know about that weird 85 stuff you guys have up there but otherwise yes
  6. Jul 5, 2019 at 5:17 PM
    #246
    The 5.7L requires 87 octane, so in CO, that would be midgrade. Lower elevation that would be low grade.
    A good read...
    https://www.usatoday.com/story/mone...gasoline-low-octane-too-much-ethanol/2369579/
  7. Jul 5, 2019 at 8:22 PM
    #247
    Wfdfirefighter76
    Wfdfirefighter76 New Member
    Will
    I use nothing but 91..... I can feel better performance and it has less ethanol which is the death of an engine
    Wildtrout likes this.
  8. Jul 5, 2019 at 8:27 PM
    #248
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    Again, I'm curious about flex fuel trucks/cars. Does running ethanol free gas make these engines run better when they are set up to run E85? Does "up to" 10% ethanol in 87 octane fuel adversely affect a flex fuel 5.7L Tundra when you can mix in E85 (manual says start switching from regular gas to E85 at a quarter tank and vice versa) with regular gas and run the truck just fine?
  9. Jul 5, 2019 at 8:36 PM
    #249
    Wfdfirefighter76
    Will
    You lose 3-4 miles per gallon running E-85 rather than 87 and E-85 is horrible... ethanol has a ton of water and eats the hoses from the inside out ....
  10. Jul 5, 2019 at 8:51 PM
    #250
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    Then why do some race car enthusiasts convert their engines to E85 for more performance? That is, instead of paying the high price for racing fuels, they simply transform their hi-po car to run on E85.
  11. Jul 5, 2019 at 9:28 PM
    #251
    High octane for boosted motors. E-85 is the ticket for that.
  12. Jul 5, 2019 at 9:48 PM
    #252
    Wfdfirefighter76
    Will
    It has more alcohol in it. It’s the bi- product of corn ... but it has a ton of moisture... just ask boat people how they like it... I’ll stick with 91.... I notice better performance and better fuel economy even though my truck is a gas hog
    flyfisher likes this.
  13. Dec 14, 2019 at 12:12 PM
    #253
    stevolene
    stevolene New Member
    GA/TN line
    so to decrease engine noise would using a 89 octane ethanol free gas help or hinder? thats my question
  14. Dec 14, 2019 at 12:13 PM
    #254
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    87 Costco
  15. Dec 14, 2019 at 1:19 PM
    #255
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Bourbon
    Blue Thunder likes this.
  16. Dec 15, 2019 at 7:29 PM
    #256
    Tundra_power
    Nick
    Pure 100% ethanol has like 115 octane e85 is like high maybe 109 octane. 87,89,91, and 93 has the same level of ethanol 10%. Its just 93 is more resistance to knock. So when your towing maybe 6000lbs up a hill and the engine is lugging it wont take timing out as much as 87. On some gas station has that 93 has 10x the cleaning agents than 87 which is true theirs was somebody that tested that on youtube. If its 0.50 difference than ill go to 87 but if it goes close to 0.30 than 93 at Sunoco. If I live in a hilly area i would run atleast 89 but what do i know...
  17. Dec 15, 2019 at 9:04 PM
    #257
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I run 91 ethanol free fuel. She runs good and a little more peppier. I read something from DAP tuning on how much the engine automatically retards the timing with each fuel octane. They recommend 91 or better just to keep the engine running top
    OBXTundra likes this.
  18. Dec 18, 2019 at 5:24 PM
    #258
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    Since I got the DAP Tune I've been running 91 but it's not ethanol free but it is not expensive either. I'm averaging around $2.50/gal for 91 with the ethanol, can't complain about that
  19. Mar 20, 2020 at 8:10 PM
    #259
    TexasArdnut
    TexasArdnut New Member
    Dennis
    2017 Tundra 1794
    Here’s the truth about octane and I’m surprised some obviously don’t understand octane. All engines with cylinder compression ratios at 9.5:1 and below are to run on 85-87 octane. Basically regular gas. Higher octane is only for engines with compression ratios above 9.5:1 like 91, 93 or even 95 in some places. Higher octane does nothing more than slow the burn rate of the fuel so that in higher compression engines (>9.5:1) the fuel will not ignite due to compression heat before the spark ignites. This prevents knock or what is called pre-ignition. Using a higher octane like 93 in a lower compression engine like our 4.6 and the larger 5.7 will actually rob your engine of power. USE THE OCTANE LEVEL RECOMMENDED BY THE VEHICLE MANUFACTURER. They know what compression ratio they designed the engine for and the octane they recommend will provide the best performance from that engine
    flyfisher, GPJoeyD and Boerseun like this.
  20. Mar 20, 2020 at 8:13 PM
    #260
    TexasArdnut
    Dennis
    2017 Tundra 1794
    Also, unless you do a mod that actually increases the cylinder compression ratio, stick to regular 85-87 octane. Anything higher will burn too slowly and be an incomplete burn, robbing your engine of power
  21. Mar 20, 2020 at 8:41 PM
    #261
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Costco 87 , and when i have extra money , i switch it to 91 once in a while, cant tell any difference except my money.
  22. Mar 20, 2020 at 9:07 PM
    #262
    Nick T
    Nick T New Member
    Nick
    Both the 4.6 and 5.7 UR engines are 10.2 : 1 compression ratio, so exactly what are you saying? 87 octane or 93?
  23. Mar 21, 2020 at 12:21 AM
    #263
    buckeyeinlv
    buckeyeinlv International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    My 2017 (naturally aspirated) needed 91 or would start to make noises at transition between low rpm and any raised stress or increase in load. I have only filled up once in my 2020 and out of habit filled with 91.
  24. Mar 21, 2020 at 1:43 PM
    #264
    Tundra_power
    Nick
    You cant be more wrong lol. Our engines are like 10:2. And Toyota reccommends 87 because it runs on 87 without any issues dosent mean its the best. When you see the 5.7 on the dyno running 87 octane all the timing is being pulled like 14 degrees!! But it still runs fine with it. Running 93 octane only pulls 2 degrees. Running 93 octane=advanced timing and pulls fuel and that equals to better mpg. Running a tune is even more beneficial. Keep it simple the only difference is 93 is more resistant to knock which therefore can advance timing and make more power. Toyota would not reccommend 93 because who would buy a truck that can only run 93 octane and that has the worst mpg out their and alot to do with epa regulations also...
  25. Mar 21, 2020 at 3:17 PM
    #265
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    So I've been running zero ethanol 93 octane in my truck, with a DAP tune, and it's running great. It was running strong on the 91, with ethanol, but it's running really good on the 93 no ethanol. According to my Fuelly app my last MPG was 17.7, my best MPG was 18.7 and my average MPG over the life of my truck (since I've owned it and ran everything from E85 to regular 87 all the way up to some 98 octane--NASCAR fuel--) is 15.2.
  26. Mar 21, 2020 at 3:47 PM
    #266
    TexasArdnut
    Dennis
    2017 Tundra 1794
    The Tundra’s Dual Independent Variable Valve Timing with Intelligence system is used to maximize fuel efficiency and power delivery. Regular 87 is best. Higher octane just slows the burn
  27. Mar 21, 2020 at 3:52 PM
    #267
    Tundra_power
    Nick
    That is false and dap tune and ov tune can back me up on this. The 5.7 engine is max out as timing goes if running 87. Running 93 will perform better all around and its been proven on the dyno on stock engine. Like i said try 93 right now its really cheap if you dont like it switch back to 87. And yes 93 is slower but not for a incomplete burn and we are talking 10:2 compression guys not 9:5 that's the most idiotic thing I heard all year...
  28. Mar 21, 2020 at 4:00 PM
    #268
    Tundra_power
    Nick
    Also owner manual says minimum of 87 octane. But dosent say best octane. Its safe to run 87 or 93. But i notice if i run 87 it will ping alittle under heavy load. If you put in 93 octane let the ECU adapt to the new octane, so couple tanks full should be enough to fully adapt.
  29. Mar 21, 2020 at 4:05 PM
    #269
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    The best part of the zero ethanol 93 octane is the low end torque. This truck just jumps off the starting line. On the higher end, that is, when the RPMs get up, I can't really tell much of a difference in the performance on this truck, and really, these are not high revving engines to begin with. But the low end of the RPM curve, yep, it's real nice...
  30. Mar 21, 2020 at 4:09 PM
    #270
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I keep it simple and run 87 and try to stick to “top tier”
    georgiey22 and rebmo like this.
