What octane gas do you use for your Tundra?
Discussion in 'Performance and Tuning' started by tundrathr0w, Jun 22, 2018.
  1. Apr 2, 2019 at 8:15 PM
    #211
    Racingjohndeere55
    Racingjohndeere55 New Member
    Alcohol carries it's own oxygen. So you are able to pack more fuel in the cylinder per stroke.
  2. Apr 2, 2019 at 8:29 PM
    #212
    Racingjohndeere55
    87. 16.99 mpg 10% ethanol. Beast mode without the tow/haul
  3. May 15, 2019 at 1:35 PM
    #213
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    So 91, right? Lmao
  4. May 15, 2019 at 1:38 PM
    #214
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    87 from Costco only
  5. May 15, 2019 at 2:08 PM
    #215
    Rakso
    Oskar
    I'm about to take a 600 mile road trip, I got Costco at both start and end locatios. We'll see. 91 on the way there, 87 on the way back.
    Migraine likes this.
  6. May 17, 2019 at 2:02 PM
    #216
    ktmhauler
    ktmhauler New Member
    GA
    2019 SR5 Dbl 4wd 5.7
    Whew can't believe I just read through this whole thing trying to figure out what kind of gas to put in my new truck :)
    I'm pretty well researched in octane ratings and ethanol vs. non etc. when finding the right fuel for my 2 stroke dirt bike, let me try to clear a few things up.
    1. Not getting less ethanol with higher-octane premium fuels. Ethanol is a cheap way to boost octane so you are more likely to get that full 10% of ethanol if you buy premium 93 unless clearly marked as non-ethanol
    2. You aren't getting better gas mileage with higher octane fuels. The higher the octane rating the less combustible the gas, so if you aren't running higher compression you aren't getting as much energy out of the fuel so less mpg*
    3. Your daily driver manufactured this century is fine with 10% ethanol gas or E10. E10 is only a problem if it sits for awhile and absorbs water or you run it in a engine that wasn't designed for it.
    4. A premium fuel could be better for your engine, even if you don't need it due to lower compression, if it has better additives, better quality control, etc. but I don't know any brand of standard pump gas that makes it worth it for this reason alone.
    5. E85 sucks. Just don't use it unless it is at least 30% cheaper and you don't need all of your horsepower
    6. non-ethanol of a suitable octane is better than E10 by about 3% so if the price of pure gas is 3% or lower vs. the E10 get the pure gas.
    The * from #2 and what I'm here trying to figure out. Some engines will retard timing to prevent knocking with lower octane fuel, which means that you aren't getting all of your performance and therefore MPG, does the MPG loss make up for the higher price of a 91 vs. 87? Ehh hard to say but I want my engine running at the peak performance it was designed for. But I've only really heard of that happening for cars that say they want 91+ but will retard the timing if you do put lower octane in to protect the engine, never really heard of them asking for 87 and always running "downgraded" and boosting timing if it has higher octane fuel
    I've heard people mention that happens for the gen 3 tundra's with the 5.7, but does anyone have any definitive evidence of that?
    Also while I don't plan to run E85, I can with the FFV, so i'm thinking maybe on a long road trip of highway driving, if the price is right and i'm going to burn through the whole tank in a day or two, it might be worth it
  7. May 17, 2019 at 9:39 PM
    #217
    Tundra_power
    Tundra_power New Member
    Nick
    87 vs 93 for a daily driver i recommend 87. But if you want performance go will 93. I have the bullydog bdx and i can tell the difference fron regular and performance tune. Octane has alittle more to it than you think. Alot people say 93 is better gas or e85 is shit gas wronggg. No 93 is the same quality gas has 87 its just less prone to knock. And the timing with 87 is so retard its not even funny. Toyota recommends 87 because they design it to be safe running that octane. CAFE standards and why would they put, you need to run 91+ octane. No its truck and i think they would have less buyers out their for that reason. And e85 ethanol has less btu than gasoline but it has more oxygen which is a good thing and its has a more complete burn. 100 ethanol is like 105 octane. And e85 is about 93 octane. I run 87 octane and e15 with performance tune no pinging and more power. Better yet 93 ethanol free and e20 thats power right there before you go to the track. So running a tuner go 91+ see how it does. daily driver with no tune 87 but its where you get the gas also. Dont go to some joe shop and buy gas. Go to sunco or mobile with high quality gas.
  8. May 30, 2019 at 8:38 AM
    #218
    sergio5327
    sergio5327 New Member
    Sergio
    2014 Toyota Tundra Limited
    3 months ago I bought my tundra and I still do not know what kind of gasoline to use.
    For now I am using 89 for fear of using 87.
    Many people say not to use 87 because a 5.7L engine works better with 89 or 91 gasoline.
    Is there someone who can help me?
  9. May 30, 2019 at 8:43 AM
    #219
    ktmhauler
    GA
    I looked in the manual and didn't see where it said what octane it required either. 87 is fine and you aren't getting any better mileage or performance out of a higher octane (actually less) unless the engine dynamically changes the timing when it has lower octane fuel than it was designed for. I haven't found anything definitive saying this is the case or not.
    However I have the FFV version of the engine and the manual does have a procedure for switching from E10 to E85 so there is some changes happening based on fuel type, so I really don't know whats happening between E10 87 - 93
    So for now i'm running 87 as I still don't think any gains in mileage, if any, would off set the higher price.
    sergio5327[QUOTED] likes this.
  10. May 30, 2019 at 9:10 AM
    #220
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I was under the assumption that burning 93 in a truck built for 87 will mess things up.
    Valves etc will suffer.
    This was coming from someone that was an engineer at GM (I know, not saying much)
  11. May 30, 2019 at 9:14 AM
    #221
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    85 but I'm in Denver.
  12. May 30, 2019 at 9:15 AM
    #222
    ktmhauler
    GA
    Not that I know of, I guess the gas wouldn't be burning as hot and might allow for more build up on the valves
  13. May 30, 2019 at 9:39 AM
    #223
    Tundra_power
    Nick
    Yes it does run smoother on 93 and thats probably the only gain from running higher octane in our 5.7 engine toyota recommended 87 because it runs good but not the best. Why would toyota recommend 93 in a work truck. I have a bully dog and run 93 i could tell a big difference from 87 regular tune to 93 with performance tune.
    XPTUNDRA likes this.
  14. May 30, 2019 at 9:45 AM
    #224
    Steelyhead
    Steelyhead 2016 Tundra TRD
    America
    16 Tundra TRD/03 Limited TRD
    I got my truck 3 months ago, and have been use I gotta different brands and different octane. Cheveron 93 gives my tuck a little more power rather than 87, fuel mileage is better with 87. Arco 87 I get the best mileage with 87, 93 isn’t any different than chevron. Getting 385 miles to 24 gallons on 87 and 350 with 93. Hope it helps
  15. May 30, 2019 at 2:02 PM
    #225
    Tundra_power
    Nick
    Thats impossible 93 burns hotter and slower than 87 but it dosent do anything to the valves. And we have port fuel injection which means the gas goes over the valves rather than direct into the cylinder like ford. Only thing that matters is the quality of gas.
  16. Jun 1, 2019 at 2:25 PM
    #226
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    I started to use top tier gasoline, it is a higher detergent gasoline, from 87-97 octane depending on the brand. same price as the junk that chain convenient stores sell. go to there web site
    they have information on locating stations. Ten auto manufactures recommend top tier gasoline. you can look in your manual.
    MajorC likes this.
  17. Jun 1, 2019 at 2:53 PM
    #227
    MajorC
    MajorC New Member
    Major
    2007 Tundra SR5
    You have succumbed to marketing hype. Why don't you add an $8.00 bottle of fuel additive to your tank every time as well? Tens of millions $$ worth of research by the best engineers in the world at Toyota to build an engine that runs the best it can on 87 octane and you put in 93 octane. I have tried every octane level out there along with every brand including non-ethanol and my best milage comes from 87 octane from Shell, BP and Exxon on my 5.7 Tundra. I avg 17.8mpg. My worst average was 16.5mpg using 93 octane non-ethanol. (All averages based on 700 mile trips from SC to FL and back on the interstate.)
    Rakso likes this.
  18. Jun 1, 2019 at 3:09 PM
    #228
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    You can look at my fuelly and see, road trips I run 93. Daily it's 87. I see a difference on road trips and I don't fill up on 93.
    huboverland likes this.
  19. Jun 1, 2019 at 3:11 PM
    #229
    Tundra_power
    Nick
    There could be a lot of factors involved in MPG but yes toyota did desgin our engine to run on 87 but thats not the best octane for our engines and heres why toyota yes spent lots of $$$ to make our 5.7 engines run good on 87. But the factor is why would toyota say you can only run 91 and higher like the Lexus because its a worl truck. When we put 87 in our engines they take 14 of timing when using 93 they take out 2 degree of timing with using stock tune. I dyno it myself and saw all the timing events and af on all the rpms. If you dont tow i recommend running 87 and if you do tow ill run 93 ethanol-free. Ethanol has a lower BTU then normal gasoline that's how government raises octane level using corn. If you have bullydog I recommend performance tune on 93 octane from Sunoco i think they have the best gas. Now when people say your wasting your money i agree and disagree. Our engine has a staic cr 10:2 which back in 2007 was somewhat high but dynamic compression is the kicker because whatever octane you use the ecm calculates that and changes valve timing events creating less Dynamic compression. Using higher octane gives you better valve timing events which creats more power and also dosent take away timing. Lexus has the same engine but requires 91 and higher because its a sports car trying to push out as much as possible safely.
  20. Jun 1, 2019 at 3:15 PM
    #230
    Tundra_power
    Nick
    mpg can be affected by temperature, wind, humidity, road conditions, traffic, using different stations, your right foot, the type of fuel, octane levels, weight, tires, a/c on or off, drafting another car and so much more but ethanol free will give you from a science view point vetter mpg
  21. Jun 5, 2019 at 10:15 PM
    #231
    marcfs71
    marcfs71 New Member
    Marc
    2010 Grey Tundra TRD Offroad Pkg with TRD Supercharger
    Dual Exhaust
    93 - 5.7ltr with TRD Supercharger
  22. Jun 17, 2019 at 10:18 AM
    #232
    SRM18TRD
    SRM18TRD New Member
    18 TundraTRDOR
    Stock
    Manual calls for 87 or Higher. I run 89. I live in the foothills with a lot of low/mid speed hills. She shifts less with 89
  23. Jun 17, 2019 at 10:34 AM
    #233
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have never run anything but 87 in mine. If I was almost empty and knew I would be making several trips towing the boat I would try 93. I towed my boat 300 miles with the Tacoma and filled up once with 93 and did get a little better MPGs. Tried a couple of tanks for normal driving and never saw a difference. Have not put 93 in the Tacoma or Tundra since.
  24. Jul 4, 2019 at 1:31 PM
    #234
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    I use 87 and ave mpg is 15 in mixed city/highway. No tonneau cover. All stock.
  25. Jul 4, 2019 at 4:04 PM
    #235
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Question:
    How does the ECU know the octane rating of the fuel? Is there a sensor in the fuel line?
    Last I read engines didn't know to pull timing unless the knock sensor detected an ignition event sooner than expected.
  26. Jul 4, 2019 at 4:29 PM
    #236
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    It seems that gaining 12 degrees of timing when going to 93 would give a noticeable performance boost in SOTP. Most stock tuning is set to use 87 and will not afford more timing even with higher octane.
    bc
  27. Jul 4, 2019 at 8:52 PM
    #237
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    What about a flex fuel truck, a truck that can run on E85, how does ethanol free improve its performance and mileage? I'm thinking that it would not help in anyway as the truck can run on E85, so why will it run worse on E10?
    Anyone know the answer to this question?
  28. Jul 4, 2019 at 9:09 PM
    #238
    Tundra_power
    Nick
    Ethanol has a lower btu power level than gasoline usual e85 will get worse gas mileage because the power level of ethanol is lower. But 100% ethanol has a octane rating of like 110ish around there. So e85 is more knock resistant. And a more clean combustion.
  29. Jul 5, 2019 at 3:11 PM
    #239
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    I understand, thanks. So what difference does it make to, especially in a flex fuel vehicle, to use ethanol free gas?
  30. Jul 5, 2019 at 4:29 PM
    #240
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    This is the most interesting thing I’ve read all day. I stood at my shell station contemplating whether the additional $.60/gallon for the top tier 89 (colorado) with “V Power Cleaning Agents yada yada yada” was worth it... I spent the extra $8.00 and now you’re telling me that shit is in all octanes? Seriously?
