What octane gas do you use for your Tundra?
Discussion in 'Performance and Tuning' started by tundrathr0w, Jun 22, 2018.
  1. Mar 21, 2020 at 4:16 PM
    #271
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Costco in Vegas....Was it a zoo? How long for gas? See any N.G.?
    I run 87 or 91 in my 12' 5.7 FFV.
  2. Mar 21, 2020 at 4:21 PM
    #272
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Gas is no crazier than normal. Grocery shopping is another story.
    B.Ross[QUOTED] likes this.
  3. Mar 21, 2020 at 8:47 PM
    #273
    Tundra_power
    Tundra_power New Member
    Nick
    Yea keep it simple most of tundra owners will put 87 octane which is ok. But i dont want the wrong information going out to everyone. For example Lexus 5.7 engine has the same engine put requires 93 because to boost up power. This is from dap directly
    As we have reported with every truck we have tested on, 4.6L, 4.7L, 5.7L, all run best on 91+ octane weather they are completely stock with stock tune, or tuned. These engines pull 8-12 degrees of timing due to knock retard on 87 oct, 6-10 deg on 89oct, 2-6 deg on 91oct, and 0-2deg on 93oct. That is on a completely stock truck with factory tune.
    If you care about the engine in your $35,000-$65,000 truck as you think you do, you wont run anything but premium in it weather you are tuned or not tuned."
    And this is a guy that works and sweats everyday on tundra 5.7/4.6 and theres proof that the 5.7/4.6 runs better using 93 octane. Dyno proven!!!!!
  4. Mar 22, 2020 at 5:59 AM
    #274
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Any advantage going nonethanol? I was doing it both on my '18 and the wife's Venza. We've switched back out of convenience but I do run mid grade or better. Since I got the '20 limited i've only run mid grade or higher.
  5. Mar 22, 2020 at 6:13 AM
    #275
    Tundra_power
    Nick
    It depends, non ethannol is staright gasoline which has a higher btu "higher energy level" than normal gas. Iv heard better mpg from non ethanol but higher octane will give you more power than anything its up to you though.. For me i run 93 octane always and my truck runs smoother less noisy, no pinging and more power...
    Moon Puppy[QUOTED] likes this.
  6. Mar 23, 2020 at 8:41 AM
    #276
    TexasArdnut
    TexasArdnut New Member
    Dennis
    2017 Tundra 1794
  7. Mar 23, 2020 at 8:46 AM
    #277
    TexasArdnut
    Dennis
    2017 Tundra 1794
    If you want the real truth, go to Hemmings.com, Tech 101 - Octane
    Running 93 and claiming you get more power is in your mind. I’d like to see dyno runs burning 87 and 93 before anyone claims more power...
  8. Mar 23, 2020 at 8:48 AM
    #278
    TexasArdnut
    Dennis
    2017 Tundra 1794
  9. Mar 23, 2020 at 10:04 AM
    #279
    Tundra_power
    Nick
    Ask dap tune he will show you. And recent studies show that 93 octane has 10x more cleaning chemicals than 87 only in specify gas station. That article was back in 2014 and it was broad not specific to the 5.7 that dap has.
  10. Mar 23, 2020 at 11:19 AM
    #280
    TexasArdnut
    Dennis
    2017 Tundra 1794
    10x more cleaning agents at a specific retailer? Which retailer? Where’s the data that indicates that?
    I don’t mean to question the validity of what you said but there is a lot of BS going around and without hard data, it’s just unverified claims. 10x the cleaning agent would cost the manufacturer more money to produce each gallon of fuel. If they are doing that, why aren’t they advertising it? It doesn’t make any sense to do what other producers don’t do and not advertise and charge extra for it.
    Could it be Chevron and their Techron?
    Cuban11182 likes this.
  11. Mar 23, 2020 at 11:53 AM
    #281
    Tundra_power
    Nick
    Do your own research. Many case studies proven 93 has more cleaning additives than regular 87. Yes chevron, Sunoco, Mobil, Techtron. Im not getting into argument weather its better or not. Im just putting out the right info. If you believe 87 is better than ok its your opinion but dont put stuff out thats not true like 93 is horriable for the 5.7 and the engine is going to have incomplete burn which is 100% false. Like i said to others try it out if you dont like it go back to 87. Right now gas is cheap so why not. I will bow out for right now ✌
  12. Mar 23, 2020 at 12:38 PM
    #282
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    I use 91 or 93 octane regular. I have found out that when I put high octane regular my gas mileage is better over the ethanol or lower grade regular octane
  13. Mar 23, 2020 at 12:46 PM
    #283
    TexasArdnut
    Dennis
    2017 Tundra 1794
  14. Mar 23, 2020 at 12:48 PM
    #284
    TexasArdnut
    Dennis
    2017 Tundra 1794
    Yes, please bow out. Everything online refutes what you’re spewing out as correct data
  15. Mar 25, 2020 at 8:58 AM
    #285
    TexasArdnut
    Dennis
    2017 Tundra 1794
    Must view video. The truth about octane. The real truth regardless of what people claim about 93 giving your engine more power (LOL)
    https://youtu.be/Bb5VfiFy0kY
    Flyinryank likes this.
  16. Mar 25, 2020 at 1:28 PM
    #286
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Hoff likes this.
  17. Mar 25, 2020 at 3:11 PM
    #287
    Tundra_power
    Nick
    Ok i just had to laugh. Lol this video contradicts what you saying about 93 fuel-burning slower. LAMO
  18. Mar 25, 2020 at 3:28 PM
    #288
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    It burns the same speed but with higher octane engine timing is adjusted and can start burning sooner which typically creates a little more efficiency and power. That’s how I understand it anyways.
    Bottom line for me is to stay consistent with whatever you choose so your truck can adjust the ecu and run it’s best for the fuel you decide.
  19. Mar 25, 2020 at 4:12 PM
    #289
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    Please respond to post 263 and 265. You appear to be justifying running higher octane fuel as the Tundra 5.7L has a compression ratio above 9.5:1 (it has 10.2:1) thanks
    Metro14536 likes this.
  20. Mar 27, 2020 at 7:36 AM
    #290
    Steelyhead
    Steelyhead 2016 Tundra TRD
    America
    16 Tundra TRD/03 Limited TRD
    I’ve run both 87 and 92 in the 5.7 V8. Owners manual say 87, but I’ve always run 92. 87 seems to be fine no knock but 92 seems to give slight more power. I switch depending on price and time of year.usually get about 350-400 per tank depending on where I am and doing, doesn’t matter the octane !! My 2 cents.
  21. Mar 30, 2020 at 11:37 AM
    #291
    lonelydriver
    lonelydriver New Member
  22. May 9, 2020 at 2:24 PM
    #292
    jre5490
    jre5490 Rane
    Rane
    MS Gulf Coast
    2019 Tundra SR5 TSS
    I use 89 because the GMC Sierra I had before this ran like crap if I used 87. I’ll put 87 in 4 cylinder vehicles but for a V8 no lower than 89.
  23. May 9, 2020 at 3:08 PM
    #293
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    So my Tundra manual says:
    "87 (Research octane number 91) or higher"
    My engine has an after market tune, which does affect how it runs. The tune recommends 93 octane for best performance. IMHO the Tundra manual is not real clear because of the "Research octane number 91" in parentheses. The manual also says "or higher" and to me that means that running higher octane may indeed help the engine run better. In other words, 87 octane is the minimum Toyota recommends.
    Anyhow, 87 is fine but if you decide to run a higher octane and you think it does indeed help your truck run better (and we all know that when you constantly drive a vehicle, you get pretty in tune, pun intended, with how it runs and when there are problems, issues, or performance enhancements) then that's not necessarily money wasted.
  24. May 9, 2020 at 3:35 PM
    #294
    Turtle88
    Turtle88 New Member
    2018 Tundra - Platinum - 3/1 level kit - Fuel Crush 18” / 285/75/18 NRG - Stubby Antenna - TRD Skid plate - NSV light bar - Fuel Crush Wheels - 285/75 R18 Ridge Grapplers - Rear Sway Bar - Tinted Windows - Halo 9 head unit with Focal Speakers, (2) 10" subs and sound deadening throughout the cab - LED interior bulbs - Removed chrome and replaced with color matched mirror caps and black door handles - TRD Shift Knob - Storage unit under rear set - 3/1 Toytec leveling kit - line x bed liner
  25. May 10, 2020 at 12:02 PM
    #295
    Ncherry84
    Ncherry84 New Member
    Nate
    Dickinson, ND
    2020 Tundra SR5 CrewMax Magnetic Gray Metallic
    Stock
    Doesn't matter what I run, truck runs good and mileage sucksno matter what....so the cheapest 87 or equal priced mid grade I find when I need fuel.
  26. May 10, 2020 at 12:05 PM
    #296
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
    2019 MGM Crewmax TRD Sport
    Icon Stage 5 17” Icon Rebound Wheels TOYO Open Country A/T 35 12.5 RCI Heavy Duty Side Step Weathertech Mats 4” Stubby Antenna Fyre Flys Interior LED Lights Plastic Dipped Badges Decked tool box Baja Designs Squadron Sport fog lights
  27. May 10, 2020 at 12:33 PM
    #297
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
    Costco premium..
  28. May 13, 2020 at 8:28 PM
    #298
    jptshadow
    jptshadow New Member
    um....E85 pump gas since day one.
  29. May 13, 2020 at 8:55 PM
    #299
    BoxersBrew
    Thomas
    Northern Virginia
    How many days has Day 1 been? I ran premium in my Taco since day 1 and then drove it 14 years and 213,000 miles.
    jre5490 likes this.
  30. May 13, 2020 at 9:46 PM
    #300
    AZBoatHauler
    So.Arizona
    87. I’ve run a several tanks of premium and there was no perceivable difference in driving or MPG. I’ve run premium in a lot of vehicles (Acura MDX, Lexus GX, Denali XL) but do not see any benefit in doing so with the Tundra.
