What lift kit to go with
Discussion in 'Suspension' started by TundraJunkie, Mar 1, 2017.
  1. Jul 11, 2017 at 4:14 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Did they swap out the coils to get 4" or are they adjustable up to 4"?
  2. Jul 11, 2017 at 5:14 PM
    Cranked to 4"
    boardude[QUOTED] likes this.
  3. Jul 21, 2017 at 8:05 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    7" BDS with the Fox shocks ...BDS has Life Time Warranty with (NO fine Print)Tundra 2.jpg .. Meaning if it breaks or bends they don't care they will replace.....
  4. Jul 21, 2017 at 9:30 PM
    Bluering808
    Bluering808 Upper Left
    Keahi
    Pacific Northwest
    2017 SuperWhite DC Trd off-road
    Icon stage 3 lift Icon tubular UCAs 18x9 SCS Ray10 wheels
    If your set on a 6" lift go with fabtech with the dirt logic coil overs. Had that system on my FJ and last two Tundras and wouldn't go with anything else. Fabtech is on the pricey side but all the components are quality you won't be disappointed. Pick your lift based on what your use will be are you actually gonna hammer it off road or is it gonna be more of a pavement princess.
  5. Jul 22, 2017 at 4:26 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Do you know what they did in the rear Sean? Shackles?
  6. Jul 22, 2017 at 5:10 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I would also suggest the 4" lift if you don't want to cut your front cross member cut. The front cross member is over $800 so once you cut it typically the lift stays on the truck. So staying with 4" lift you can avoid cutting. Plus the bigger the lift the more money you typically spend to make the truck drive decent. Just my .02 .
  7. Jul 22, 2017 at 6:05 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Their truck still has the blocks. 1.5" I believe. Also has air bags for towing
