  1. Mar 24, 2021 at 9:20 PM
    #5851
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Another option, as a “mud room” is to leave it unconditioned or “slightly conditioned” (enough for freeze protection) and simply closing it in but not fully opening it up to the house.
    TaquitoBandito likes this.
  2. Mar 24, 2021 at 9:44 PM
    #5852
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    Why are you draining your pool?
    TomC843 likes this.
  3. Mar 24, 2021 at 9:59 PM
    #5853
    AZTundra
    Paul
    Phoenix, AZ
    Chipping out the plaster and replacing with minipebble. Installing new waterline tile. Adding a dedicated suction line for the pool cleaner and an automatic pool leveler. Our current plaster is 15+ years old and needs replacing.
  4. Mar 24, 2021 at 11:23 PM
    #5854
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    It appears that the concrete is pretty close to level with the dining room wood flooring.
    It would have a door to the garage and a door to the dining room but it would have the washer/dryer as well so it needs to be heated.
  5. Mar 26, 2021 at 5:39 PM
    #5855
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  6. Mar 26, 2021 at 5:43 PM
    #5856
    Outbound
    Aaron
    Northern Alberta
    Nice job on hanging the towel ring. I hate to break it you though, someone stole your mirror and sink.
  7. Mar 26, 2021 at 6:03 PM
    #5857
    csuviper
    Broomfield, CO
  8. Mar 26, 2021 at 6:07 PM
    #5858
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Started this Monday, huge walk-in-closet and floating vanity..
  9. Mar 26, 2021 at 7:36 PM
    #5859
    TaquitoBandito
    Joel (AKA Bif)
    Replaced two dead citrus trees with an Olive tree and a Meyer Lemon. Added a seedless tangerine tree. When I was planting the Olive tree, I think I found an old horseshoe. I have to figure out how to clean it.
    The roses are going crazy, trees are budding, and my Crossvine is really blooming. I do love Spring in Central Texas.
    IMG_2127.jpg IMG_2129.jpg IMG_2133.jpg IMG_2134.jpg IMG_2122.jpg IMG_2123.jpg IMG_2130.jpg
  10. Mar 26, 2021 at 9:19 PM
    #5860
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    A great cigar on a great day / Home improvement...
  11. Mar 26, 2021 at 9:20 PM
    #5861
    Nowhereman
    Al
    Monterey Bay area
    Could be a bowling alley...
  12. Mar 26, 2021 at 11:25 PM
    #5862
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Hired block Mason to finish out 42’ of wall for my camper parking pad. Done.EB197B6A-C52F-4809-9D05-FF54C5FE6EA4.jpg
    mdavis, BlueRibbon4x4, 1UPPER and 8 others like this.
  13. Mar 27, 2021 at 3:43 AM
    #5863
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Evaporust for the horseshoe, knock off at much loose stuff as you can then submerge it and leave it for a week.
  14. Mar 27, 2021 at 7:06 AM
    #5864
    Nowhereman
    Al
    Monterey Bay area
    That's sweet, nothing like having the proper parking spot for stuff like this.
    I'm looking at the Airstreams right now and trying to get the wife over the "shocking" look of it.
    I think it is far superior to the "Box" units that populate the trailer scene.
  15. Mar 27, 2021 at 11:15 AM
    #5865
    P-Factor
    P-Factor New Member
    Tim, "The Tool Man" would be proud!
    Added another 200 watts of solar to my man cave/radio shack.
  16. Mar 27, 2021 at 11:45 AM
    #5866
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    Damn Doves found a place in the upper eaves above the garage.... just added these to keep’em out
  17. Mar 27, 2021 at 1:22 PM
    #5867
    RainMan_PNW
    Casey
    Clark County, WA
    Blowdown from winter storms, got some of it cleared and burned. A lot more to go, but I can make rounds out of a lot of what is left for the fire pit.
  18. Mar 27, 2021 at 3:59 PM
    #5868
    Tundra_Curt
    Tundra_Curt New Member
    Curt
    2021 Tundra Limited CrewMax
    Just getting started...
    Gutters for the Costco Gazebo. Once the sealer dries I'll cover up my incompetence with some brown spray paint. As a contractor, I make a pretty good accountant...D966B966-27DD-41F1-90D2-26FE0E82037D.jpg
  19. Mar 27, 2021 at 5:30 PM
    #5869
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    cement dudes, please HALP
    chose to pay bank for house in 2016, garage was built who the fuck knows, ~80s-90s
    appears to be uncoated, or the coating has been worn out. (salt drip from vehicles, etc)
    all surface has been removed about 1/8" throughout, looks like hardened clay with rocks
    what is my best option here for repair vs spending out the ass on a company coming in for this? 15x20' is the section that needs to be addressed.
    Epoxy / concrete coat?
    fresh concrete layer then epoxy coat after cured?
    my concern is hours and money spent to have the 'fix' not bond and cause issues in the next couple years.
    Any tips would be greatly appreciated! Thanks!
  20. Mar 27, 2021 at 5:54 PM
    #5870
    RainMan_PNW
    Casey
    Clark County, WA
    Pictures would help, cuz it’s hard to really know what you’re dealing with.
    Concrete “overlays” are hard to get to really work without using very expensive/specialty materials and a ton of prep... and also require the base material to be good as well. Bonding agents don’t really work on large thin surfaces, and having reinforcing bridge the seam is a big part of the strength. And epoxies aren’t going to build thickness without a lot of material (and cost).
    most garage slabs are only 3-4” thick anyway... you might consider jacking out the old and having a new one poured. At 15x20 you’re talking 300SF and probably very little prep work. 4” thick would be ~4 CY, but most slab finishers charge by the SF. I’d call a few and get some quotes.
  21. Mar 27, 2021 at 6:05 PM
    #5871
    MEWaters
    MEWaters New Member
    Maine
    pictures inbound, major PITA as i have a tracphone
    more info: Pretty humid in garage if there is any moisture in ambient air, you can see it collecting on everything. Detached, 3 feet from house and roof pitches toward house. No gutters were in place until I took out mortgage for home and installed in 2016. Since then continuous flaking of their paint cover job and top coat of cement. Garage itself is 20x20'
  22. Mar 27, 2021 at 6:12 PM
    #5872
    MEWaters
    MEWaters New Member
    Maine
    1E34D61B-5601-42C1-9DC1-27EF067CB047.jpg 1BC25906-9FC0-4CDE-BC32-DDD651100851.jpg
    crack runs left to right, house side to 13ft. This crack meets an identical crack that runs perpendicular 20’ from garage door rear wall
  23. Mar 27, 2021 at 6:25 PM
    #5873
    RainMan_PNW
    Casey
    Clark County, WA
    I’m not an expert, and it’s been over a year since I started at a Holiday Inn. I have worked in industrial construction for 23 years and have had to do some interesting and expensive concrete work.
    Doubt that floor ever had epoxy. The hard-trowel finish with a sealer would’ve been all it ever had, and years of road salt causes what you see.
    Good news is that it’s likely only superficial... but like everything there are varying degrees of cost in refinishing it.
    First thing to do would be to get that crappy red crack filler chopped off the surface (go light) and then give the whole thing a good thorough pressure wash (protect the walls and clear everything out first). See how much topping comes loose and blasts away from the pressure washing.
    Then look into a good polyurethane or other flexible polymer-based garage coating, and read up on the instructions for prep and install and follow them carefully. There are DIY options out there to save a little $$ but takes more work. Or get a few pros out to give you estimates. There’s no charge to get a quote.
    gosolo, ToyoMafia, Baja Mike and 2 others like this.
  24. Mar 27, 2021 at 6:28 PM
    #5874
    MEWaters
    MEWaters New Member
    Maine
    first pic is after a good pressure wash, i had done a cheap patch at door with some left over stuff from a deck repair couple years ago.
    I am not familiar with poly for concrete, is this like epoxy? Due to moisture, I would like to go best route
    ETA - concrete base first with a good cure then coat?
  25. Mar 27, 2021 at 6:41 PM
    #5875
    RainMan_PNW
    Casey
    Clark County, WA
    Honestly, I’d call a couple garage floor companies to come take a look. Ask them tons of questions about the process and different products. They won’t charge you to take a look and give you an estimate, and then you’ll have a better idea of what the pros would do.
    gosolo and TaquitoBandito like this.
  26. Mar 27, 2021 at 7:44 PM
    #5876
    AZTundra
    Paul
    Phoenix, AZ
    Bathroom drywall was started today. Doing the smooth finish on this one too. New box mounted in living room for a ceiling fan after electrical is run to it. Nothing going on with the pool yet, hopefully they start next week.
  27. Mar 27, 2021 at 9:00 PM
    #5877
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Repaired a hole in the floor of a house my buddy is trying to sell. Installed a curved shower rod in my hall bathroom and caulked the surround. Applied sealer to about half of the granite counters in my house, gotta finish up the other half tomorrow
    8BE10FEB-34AE-4733-B425-7480769CB449.jpg EB18C04B-BA6C-42E7-A46B-E9092F014FBE.jpg 87529AE6-DA84-407E-8B4D-A81DF3C2016F.jpg 9C28E6D0-463F-4460-8BE0-9999A5FDD195.jpg FC95F3FC-7207-4983-90BB-38395296E505.jpg
  28. Mar 28, 2021 at 6:22 AM
    #5878
    Patriot
    Patriot Member
    Thanks for the compliment. We looked at Airstreams and did a deep dive on the Airstream owner forums before going to a dealer in Greensboro, NC. Take a real hard look on the forums before purchasing..just a thought.
  29. Mar 28, 2021 at 7:55 AM
    #5879
    Made the house even more attractive after getting Betsy 2.0 home from her facelift
    Tyman, gosolo, mdavis and 14 others like this.
  30. Mar 28, 2021 at 4:17 PM
    #5880
    4x4platinum
    4x4platinum New Member
    18 platinum
    Started some landscaping this weekend..got 5 pallets of blocks ..only 3 1/2 down so far.
    gosolo, Fotnot, WAtundra4x4 and 8 others like this.
