What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Aug 24, 2023 at 12:10 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    With the transmision for $50?
    I'm assuming you will be a custom drive shaft and prop shaft?
    07 Tundie likes this.
  2. Aug 24, 2023 at 12:20 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Yes, they included the trans, but it's a core only. They had torque convertor/trans issues that caused them to pull the entire unit and swap with a junkyard pair.
    For the driveshaft, you get the OEM driveshaft shortened 1-1/2", rebalanced, and it's GTG.
  3. Aug 24, 2023 at 12:33 PM
    Retroboy1989
    Northern Utah
    Is there a thread on this? What about wiring?
  4. Aug 24, 2023 at 1:03 PM
    VWTim
    Corvallis, OR
    MTRock likes this.
  5. Aug 25, 2023 at 7:44 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  6. Aug 25, 2023 at 8:02 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    https://www.tundras.com/threads/how...013-tundra-to-full-time-awd-capability.54474/[/QUOTE]
    I bought a set of 5 steelies off ebay for my 1st gen years ago. I imagine a search there would provide results you're looking for. Think i paid around $100 a wheel with free shipping.
  7. Aug 25, 2023 at 10:58 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    Finished replacing the radiator, thermostat, water pump, serpentine belt and upgraded Mishimoto radiator hoses. Drives, doesn't overheat or leak.
    Overall it was a challenging 8-hour project, largely spent fighting with hard-to-access bolts and hoses. Both my hands bled multiple times. There's a very specific order for reassembly and nobody tells you that order, so I had to disassemble a few times to access hoses or bolts that I missed and had blocked (by, say, installing the thermostat housing). Still, I got it done and I'd never done anything similar before. I used several YouTube videos.
    I can't fully recommend the Mishimoto radiator. It's very high quality but the plastic side mounting brackets don't mount flush at the bottom; they stick out about half an inch. I had to use a jack and a wedge to flex the brackets over enough to mount them in the existing mounting points... And those bottom screws are already extremely hard to install because you have to line them up through a small hole in the bumper with about 18" of extension and a wobble joint.
    Anyway here's a before picture:
    Note that my hood lights were very useful and my voltage cutoff worked properly and turned the lights off before draining the battery too far. It left me enough juice to start and automatically turned back on when the alternator charged the battery.
  8. Aug 27, 2023 at 2:55 PM
    c24680
    c24680 New Member
    Craig
    KY
    08 Silver Tundra Crew
    Finally got around to swapping parking brakes with a buddy
    Now need to adjust so they actually engage and work.
    The adjustment but and lock nut are rusted and will require some penetrating oil.
    That's work for when it's not a million deg outside
    joseph_womack likes this.
  9. Aug 27, 2023 at 3:17 PM
    Retroboy1989
    Northern Utah
    There was a video in the gen 2.5 thread. You are supposed to adjust just like old school drums. The star adjuster.
  10. Aug 27, 2023 at 5:49 PM
    skan
    skan New Member
    2007 Toyota Tundra CrewMax
    275 60r20 toyo open country at3 on vision seven 20*9 +12 offset
    morimoto xb headlights
    Grille from Ali baba
    Plastidip the front bumper&rear
  11. Aug 28, 2023 at 7:58 AM
    iDon’tRead
    iDon’tRead New Member
    Had to get new tires so decided to get new rims too method 316 with falken wildpeak
  12. Aug 28, 2023 at 8:27 AM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Much better!
  13. Aug 28, 2023 at 9:00 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    What mirrors are you running? I'm leaning towards the signals on my mirrors.
    Anyhow, the new shoes look nice. Wild peaks will last long than the Goodyears too.
  14. Aug 28, 2023 at 10:38 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Those look much better.
    When I was growing up, there was an elderly retired gentleman living down the block who would trade in his car for a new one whenever he needed new tires.
  15. Aug 28, 2023 at 11:48 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    Replaced the front rotors and pads, and it took about an hour. I would have been less but wrestling those tires back on is a challenge. Have to let my back recover than do the rears next weekend. I can't believe the dealer wanted $1200 to do front and rear.
  16. Aug 28, 2023 at 3:34 PM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    Well, it's been a fail today for me. I tried gravity bleeding brakes, so I squeegee out old brake fluid(which looked fine btw), put new fluid back in. Go to rear left tire, open nipple and .....and? No fluid is coming out:frusty: So, thinking it's probably not enough suck, I try opening right rear as well, but she's too tight. In fact, the nipple rounded out:frusty::frusty::frusty:
    :angrygirl:why, gang!!!
    Anyways, tightened everything back up and proceeded replacing steering fluid. That actually went very well. Uneventful.
    Lifted front and squeegied out old fluid in reservoir and filled new. Turned wheel like 20 times back and forth, started engine and did same another like 20 times. Squeegied out, new fluid in reservoir. Everything x5.
    Went through the whole quart. It was actually cherry colored when I started taking out 'old' fluid, which was maybe 7yrs old.
  17. Aug 28, 2023 at 7:31 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    New driver side front axle wheel bearing installed tonight. Purchased the preassembled Koyo bearing assembly off Ebay. Broke the abs wire bracket mounting bolt and the sorry ass dust shield is scraping like hell.......but the bearing isn't growling anymore. Front end alignment set for this weekend.
  18. Aug 28, 2023 at 7:38 PM
    iDon’tRead
    Just oem tow mirrors since I got a good deal on them .. only really tow during hunting season though
    Retroboy1989 likes this.
  19. Aug 28, 2023 at 7:57 PM
    Retroboy1989
    Northern Utah
    I wouldn't go back to standard mirrors, I tow only during the summer.
  20. Aug 29, 2023 at 7:02 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Rule of thumb for any project: Material is only 1/4 to 1/3 of the cost; the rest is labor. So, being most decent 4 rotor and brake pad kits are approx $400, $1200 is about right (especially for a dealer).
  21. Aug 29, 2023 at 9:19 AM
    BlueCrushSC16
    Charleston, SC
    Bought new front wheel bearing/ hub assemblies.
  22. Aug 29, 2023 at 10:36 AM
    EmergencyMaximum
    "What have you done to you're 2nd gem tundra"
    Does :spending:someone else to do it count?
    Anyways, to business: got my brakes flushed and they replaced rounded off bleeder screw. Also put red caps on them(adds 7hp per wheel). Also had them do diag. for tpms. Total was $160.
    They also added some other stuff that they recommend doing.
    Replace rear shocks $430
    Replace spark plugs $365
    Steering flush $130 (I actually did it myself yesterday)
    alignment $90
    They also said my front tpms need replaced. One is low battery and other isn't reading anything. $335
    I declined all other services. Do they look reasonable?:boink: btw, they said they reset tpms, but they might come back on. I drove home about 20 mins and nothing showed up yet.
    How do you know shocks are bad? My truck isn't humping its rear end
    Thank you gang!
  23. Aug 29, 2023 at 10:40 AM
    BlueCrushSC16
    Charleston, SC
    That is the only one I have an issue with. For that price, it better have included new ignition coils.
  24. Aug 29, 2023 at 10:44 AM
    BlueCrushSC16
    Charleston, SC
    Actually, I take that back. "Replace rear shocks $430" Those are super easy to change out. I hope they gave you upgraded shocks in that cost as well.
  25. Aug 29, 2023 at 10:53 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Agreed with the shocks, as I'm sure they put the cheapest units they could find on there and probably took all of 20mins.
    I feel like I spent well over $100 just purchasing OE spark plugs, and it might have taken me close to 2 hours for install... tho I did clean MAF and throttle body while I was in there. Either way, it's a far more time consuming job than rear shocks.
    PhotoNerd and EmergencyMaximum like this.
  26. Aug 29, 2023 at 11:08 AM
    EmergencyMaximum
    Thank you, gang. I'm planning to do spark plugs around 150m mills, that'll be probably take me little less than couple years to reach, I'm at 137k right now.
    To clarify, all those extras they tickled on were optional. They didn't do them. I only had my tpms diagnostic only and brake flush.
  27. Aug 29, 2023 at 2:01 PM
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    Today I installed the bed stiffeners I made.
    I carry steel on the bedrock and wanted to avoid any tearing.
    07 Tundie, Ohannon7, chugs and 9 others like this.
  28. Aug 29, 2023 at 2:20 PM
    EmergencyMaximum
    Those stiffeners don't look very convincing, gang.
    (To clarify, personal expert olinion:
    I don't think they extend far enough to be of much help and mounting bolts will probably back out or pull the frame. Better than nothing I suppose.)
    07 Tundie and shannon like this.
  29. Aug 29, 2023 at 4:23 PM
    Magnet18
    Magnet18 New Member
    Rob
    Oregon
    2008 Double Cab SR5 TRD
    Today: fender flares. Since I got the truck last week: fender flares, headlights, wheels & tires, the truck has cleaned up pretty well
  30. Aug 29, 2023 at 4:26 PM
    EmergencyMaximum
    It's like a whole new pickup! I bet those third gen gang would be envious right about now!
    :drunk:we got a gang of our own here!
    Magnet18 likes this.
