  1. May 6, 2019 at 1:28 PM
    Lexus4jess
    Lexus4jess New Member
    jesse
    Magnetic Gray 2019 SR5 Tundra
    TRD shifter, painted grille Both, Black out tundra emblems
    Love the look, I may do it to my tundra.
    Ted4311 and JoshuaA[QUOTED] like this.
  2. May 6, 2019 at 4:01 PM
    P. Floyd
    P. Floyd New Member
    Kevin
    19 Cement Limited TRD
    New tuffskinz, 2nd pathetic attempt at wrapping chrome cup bezel and $8 shifter from Autozone. Toyota should contract with tuffskinz or make their own. Stuff rattling around on plastic is no good and I’m not sure what the pieces of felt are in the interior door handle? Looks like old attic insulation.
    Inquiringone, mgm16trdpro and Ostrich like this.
  3. May 6, 2019 at 4:33 PM
    Mks99
    Mks99 New Member
    2019 Barcelona Red Platinum
    got the Pop & Lock in this evening. Running the wire was the hardest part! I didn't go through the firewall like they recommend. Used one of the drain grommets in the rocker and the hole in the sill by the B pillar. First time I've used PosiTap's. Where have these been all my life?
  4. May 6, 2019 at 4:48 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Finally finished my mobile Ham radio install tonight. Yaesu FTM-400 mounted under drivers seat with a Rigrunner (both mounted to 3mm ply I had laying around). Ran 10 gauge directly to the battery with a 12v relay so it only goes on with accessory power. Head is mounted to windshield with factory suction cup mount. Antenna is a 2m/70cm mounted into a factory stake hole. Tonight I finished the install by finally mounting the external speaker on the dash.
    7EE13E16-4085-4A65-B5B8-83020E2464AD.jpg 8831D223-36FC-4401-91CC-416C40879886.jpg 512095BA-DCAD-4085-9219-2F712C895BFF.jpg CF9219DF-8D0A-4DF7-80CC-F6D87E2312E8.jpg
    Patch999, DeanO, mgm16trdpro and 4 others like this.
  5. May 6, 2019 at 4:52 PM
    Tundra17Tom
    Tundra17Tom Passin Thru
    South Carolina
    2017 4X4 Tundra SR5 Double Cab 1G3
    HR LED interior HR LED Cargo Light HR LED Backup Light Raised black TUNDRA letters on tailgate Rear and Front bumper painted black Bilstein 5100s front and rear Method NV305 Matte Black Blacked out badges Debadge Iforce and SR5 AVS window vent visors TRD Pro Headlights Auxbeam LED headlight bulbs Driver side Oh Hell Handle
    nice! 73s W4TDW
    abomb60[QUOTED] likes this.
  6. May 6, 2019 at 6:06 PM
    bhuff92
    bhuff92 “Hi, I’m Rod and I like to party”
    Ben
    Columbus, Ohio
    2018 Charcoal Tundra SR5 Crewmax
    Iron Cross Front Bumper with Grille/Brush Guard.
    Have been looking for another members post but haven’t been able to find it. He does builds for road shows. 2018 Blue tundra that is completely decked out. He does his write ups like Week #1: Did this. Week #2: did that.
    He does a phenomenal job at making these trucks look good. Hoping to find his post and check out his tie down bars on the bed. Thanks in advance.
  7. May 6, 2019 at 6:10 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
  8. May 6, 2019 at 7:30 PM
    JackWagon
    JackWagon Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    Finally did the CB Shims/LRO block.
  9. May 6, 2019 at 8:19 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    Installed mine Sunday and captured this beauty
  10. May 6, 2019 at 8:22 PM
    abomb60
    Massachusetts
    It’s nice when things are actually plug and play huh?
    Travo60[QUOTED] likes this.
  11. May 6, 2019 at 8:32 PM
    bhuff92
    Ben
    Columbus, Ohio
    Faht Nocker[QUOTED] likes this.
  12. May 6, 2019 at 8:32 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    Absolutely, the install was a breeze!
  13. May 6, 2019 at 8:36 PM
    abomb60
    Massachusetts
    Mine took me a little bit longer as the previous owner had some sort of aftermarket alarm installed. Just to be cautious I went to the local stereo/alarm/remote start install place and they actually helped to let me know it was an aftermarket immobilizer that was installed. So back home and 15 minutes later my remote starter was installed and working.
  14. May 6, 2019 at 11:44 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    After having it sit on my to-do list for nearly a year, finally installed the Pop-n-Lock last week. Like others have noted, I added sound matting to tailgate and to cover plate (that's removed for install). From the driver door, you have to intentionally listen for the lock.
    Added some more interior mods this weekend...
    Safe and tray. Customized the tray with a little suede, same material I used on the A-pillars.
  15. May 7, 2019 at 5:48 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    My only problem is getting the damn kick panels back I place correctly.
    Myhobbes25 likes this.
  16. May 7, 2019 at 6:50 AM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    My kick panel is still just held on by the push pin in the back. Have no patience to get it back on. There has to be a trick to it. :confused:
  17. May 7, 2019 at 7:22 AM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    I think the question is how does it go back in after you put the clips in place? What is the motion, insertion angle and or any other variable to get the dang panel back in place.
  18. May 7, 2019 at 8:01 AM
    jawjatek
    jawjatek New Member
    N GA
    2019 Tundra DC TRD
    Installed my freshly painted bumper ends. Some of the nuts are a bit hard to get to; the 3 inside that hold the bumper end to the center piece, just be patient. A 10mm ratcheting box end wrench is the trick here.
  19. May 7, 2019 at 8:40 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    Did you get those from sparks? Looks great
  20. May 7, 2019 at 9:11 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Which init is this?
  21. May 7, 2019 at 9:39 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
  22. May 7, 2019 at 9:55 AM
    SnrDisregardo
    Wade
    IL
    THANK YOU! I have learned to live with it, but it has always been in the back of my mind. Not all hero's wear capes.
    NewImprovedRon likes this.
  23. May 7, 2019 at 10:23 AM
    sweatypowderpig
    sweatypowderpig New Member
    sierra nevada
    2019 Cement Limited DC TRD Off Road
    thanks man, i just installed the pop n lock today and couldn't get the kick panel to sit perfectly flush. sparks has a great installation on 19s for the pop n lock for whoever's wondering. wiring diagrams and all. sealed the rubber grommet with shoe goo :thumbsup:
    http://toyotaparts.sparkstoyota.com/install/00016-34092inst-2019Tundra.pdf
    also put on black limited emblems. they ended up being bigger than the chromes so i just centered em.
  24. May 7, 2019 at 11:44 AM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Changed out the SCS for Method wheels late last week:
    A few of the Method MR312 rims:
    Patch999, Major, JoshuaA and 14 others like this.
  25. May 7, 2019 at 12:23 PM
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    cjmay13, Watt maker, Ted4311 and 5 others like this.
  26. May 7, 2019 at 12:51 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Looks great! What’s the offset on those Methods and what size tires are those?
    Faht Nocker likes this.
  27. May 7, 2019 at 1:08 PM
    jawjatek
    jawjatek New Member
    N GA
    2019 Tundra DC TRD
    No, from Cool Springs Toyota (@Roman), and I had them painted MGM (1G3).
    Roman likes this.
  28. May 7, 2019 at 1:50 PM
    itsdchz
    Clovis, CA
    Thanks!
    18x9
    Offset 18mm + Spidertraxx 1.25" Spacers
    295/70/18 Trail Grappler MT's
    equin[QUOTED] likes this.
  29. May 7, 2019 at 1:58 PM
    Haslefre
    Haslefre New Member
    TN
    Installed a USB-C/USB port in one of the many lighter outlets we have. Took about 30 total. Had to change one of the connectors as the positive didn't fit the new receptacle.
    Patch999, Reelman, Fotnot and 3 others like this.
  30. May 7, 2019 at 3:08 PM
    Gary86
    Gary86 New Member
    Gary
    2024 SR5 TRD Off-Road
    6" Readylift|Hostile Rage 20x10|Toyo OC R/T 35s|TRD Sway Bars| 2019 PRO Headlights w/ @iHacker harness|Morimoto Foglights|5% Tint
    Dropped the truck off for the lift/wheels/tires; color match stuff is in the garage; front sway bar, rear sway bar, and morimoto fogs on the way. Once I sell the stock wheels I'll be ordering the 2019 Pro headlights from Sparks and @iHacker harness.
    equin and iHacker like this.
