Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Apr 27, 2019 at 5:04 PM
    916tundra
    916tundra [OP] New Member
    Ken
    2017 Tundra Crewmax
  2. Apr 27, 2019 at 5:11 PM
    916tundra
    Ken
    2017 Tundra Crewmax
    619Tundra likes this.
  3. Apr 27, 2019 at 5:13 PM
    916tundra
    Ken
    2017 Tundra Crewmax
    Not sure why some of the links for AliExpress don’t work. See attached if the links work.
    _SP_, Dgjman, Mounts99 and 2 others like this.
  4. Apr 27, 2019 at 5:15 PM
    916tundra
    Ken
    2017 Tundra Crewmax
  5. Apr 27, 2019 at 6:23 PM
    minter66
    minter66 2007 TSS CrewMax
    I’ll be fish out of water here as I drive a second generation Tundra (2007)
    As far as I know I’ll be the first to put it in a 2nd gen, but boy would I be happy if someone else was first.
    After some negotiating with Dasaita they gave me a pretty good package deal.
    Android 9.0 Headunit with dual processors (dual core CPU and quad core CPU) 4/64gb RAM
    Canbus Adapter for Toyota (I can only assume it fits 2nd and 3rd gen Tundras - I’ll let you know)
    Apple CarPlay Dongle so you can run CarPlay from the HU
    $480 shipped
    Link:
    https://www.amazon.com/dp/B07QV6RQ4N?ref=myi_title_dp
    Thanks to 916Tundra for letting us discuss, research and troubleshoot a LOT in his build thread.
    To me this headunit is better than the Secane / Tesla units, but that’s pure opinion
  6. Apr 27, 2019 at 6:44 PM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    I had to do quite a bit of messaging back and forth with Dasaita through Amazon. They just needed to make sure that I am getting the right Canbus/harness (which is not a bad thing). Apparently it will be different than @minter66 canbus/harness. I told them that I knew the CB004 Toyota Canbus will work for my vehicle, but they still needed me to send pictures of my dashboard. Hopefully they received my photos and can confirm then ship.
    Thanks again @minter66 for the deal you negotiated.
    Dgjman, tinman10101 and 916tundra[OP] like this.
  7. Apr 27, 2019 at 7:26 PM
    minter66
    Happy to save other members money on a newer unit, granted you can save roughly $60 buy getting the 8.0/8.1 unit.
    Also I did send them a picture of my dash and the back of the radio connectors (eBay auction photo of same radio) so hopefully the matched it up correctly
    tinman10101, VTYOTA and 916tundra[OP] like this.
  8. Apr 27, 2019 at 7:36 PM
    916tundra
    Ken
    2017 Tundra Crewmax
    For those who needs to send them a back photo of the factory HU, use this.
  9. Apr 27, 2019 at 7:55 PM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    In your audio thread, you mentioned that you had the non-JBL system correct? It's probably just poor wording on Dasaita's part, but you found that the CB004 Canbus works with the non-JBL system as well?
    Also, I found this gloss black version of the dash kit for "Gen 3". A little cheaper. Couldn't find the share button to get a link on the mobile app so a screenshot will have to suffice.
    SiberianTundra likes this.
  10. Apr 27, 2019 at 7:57 PM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    I like to think of it as only $60 more dollars for a newer unit.
    McMason likes this.
  11. Apr 27, 2019 at 8:35 PM
    916tundra
    Ken
    2017 Tundra Crewmax
    Yes I have a non JBL. Dasaita should have word it “JBL compatible”. The canbus should work with both systems.
    619Tundra and VTYOTA[QUOTED] like this.
  12. Apr 27, 2019 at 10:13 PM
    minter66
    omgboost, VTYOTA and Wynnded like this.
  13. Apr 28, 2019 at 6:58 AM
    minter66
    Also, if you use the Amazon 9.0 link, a message from the seller:
  14. Apr 28, 2019 at 7:06 AM
    Black Wolf Unsupervised in Alamosa
    I'm liking this option for my 07 too.
    CaptSpaulding likes this.
  15. Apr 28, 2019 at 7:09 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    My order has shipped!
    Since I have traffic and weather on the OEM head unit (no nav), I'm assuming I already have a GPS antenna?
    916tundra[OP] and tinman10101 like this.
  16. Apr 28, 2019 at 7:13 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm attracted to this as well, but if I'm honest with myself, 99% of my listening consists of my own owned music from a USB. I just set it to random and let it go...
  17. Apr 28, 2019 at 7:18 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    I'm hoping it will make my factory speakers sound a little better without having to replace them. Also, built-in Google Maps will be nice since I dont already have nav and the ability to add a second camera.
  18. Apr 28, 2019 at 8:56 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    you guys are killing me with this thread and @916tundra sound system thread. i order from aliexpress quite often for just misc crap but this is some cool tech. thanks for the heads up on this. you guys have solved the issue of current tech solution for our tundras.
    cheers
    tin
    Dgjman, stevolene, ntg and 1 other person like this.
  19. Apr 28, 2019 at 9:44 AM
    916tundra
    Ken
    2017 Tundra Crewmax
    It will sound better but I think you should upgrade your speakers as well. Factory speakers suck in my opinion. Look on top of your roof to see if you have the GPS antenna.
  20. Apr 28, 2019 at 9:58 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Thanks! I've got one then. Eventually the speakers will be replaced. Others mods are being prioritized over the speakers.
    916tundra[QUOTED][OP] likes this.
  21. Apr 28, 2019 at 10:36 AM
    JoshuaA
    JoshuaA GenX 2.5
    Ontario
    Blacked 2015 going strong!
    +1
    Tech12Volts Group Buy on 7 speakers and 4 tweeters for $320 was so worth it. Came with big MDF mounting brackets, and any connectors that one might need. Depth difference between dash corner stock speakers and Infinity Reference from James:
    The door speakers looked so cheap when I took them out. Everything what we got:
    For others who didn't, definitely jump on it if the Group Buy comes back. The Android HU boosts loudness. The upgraded speakers make the dash even more alive and overall clarity lets you hear sounds you never noticed in your music. This is without upgrading the amp.
  22. Apr 28, 2019 at 10:42 AM
    916tundra
    Ken
    2017 Tundra Crewmax
    That is a great deal!
    VTYOTA likes this.
  23. Apr 28, 2019 at 10:47 AM
    minter66
    The planets have aligned:
    My radio gets delivered Thursday
    Wife is taking BOTH kids out of town to Oklahoma for the weekend.
    I will be able to knock out every project on my truck this weekend, including the radio, so hopefully I’ll report back good news
  24. Apr 28, 2019 at 11:41 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    I would have done the speaker group buy, but I had already spent 3k in other mods at the time. Hopefully I can take advantage the next time.
    Dgjman likes this.
  25. Apr 28, 2019 at 12:15 PM
    JoshuaA
    JoshuaA GenX 2.5
    Ontario
    I hear ya, we have such reliable trucks we don't mind pumping mods in, so many, so little time!
    VTYOTA[QUOTED] likes this.
  26. Apr 28, 2019 at 2:38 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Wow that's like a modder's dream. Good luck to you.
    Please keep us posted on the install.
  27. Apr 29, 2019 at 12:21 PM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Yes! An install thread. Happy to answer any questions. Having the Waze app every morning is nice. I feel like it fits the truck well. I still need to look in to getting a USB modem... It's not that bad starting my hot spot every time I get in but i prefer convenience.
    916tundra[OP] likes this.
  28. Apr 29, 2019 at 12:29 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Hey @jmevis i thought that you just plugged your phone in every time you get in the car and use android auto to mirror your phone on the HU. That way there is no need for the HU to use your access point. Or am I missing something? Thanks in advance.
  29. Apr 29, 2019 at 12:34 PM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    I have an iPhone. So car play works, I installed the USB adapter to use the factory USB port in the center console and hid the carplay dongle behind the HU. But I don't like cables so I end up not physically connecting my phone to the HU. Thus... hotspot.
    tinman10101[QUOTED] likes this.
  30. Apr 29, 2019 at 12:41 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    got it ... thanks. So I am assuming with the canbus, install was like 30 mins? Seriously considering this ... I have the Frac Camera so I am hoping I could just use the plug and play harness TundraTex did to the Canbus. I like the idea of physical buttons to jump from Front Camera to Rear Camera to HU on the fly. I know when I use it now ... it totally throws off my GPS even when I just switch it for a couple of seconds. Wonder if it will do the same thing with this HU. Well this HU is a lot faster so it would retrack faster I suppose. Thanks again.
    Jjeielrod and SiberianTundra like this.
