  1. Sep 30, 2018 at 2:45 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Added some power distribution in the cab. Set it up to only be hot with the ignition on by using a continuous duty solenoid after a breaker/disconnect. I used a 6 port fuse box with a ground bus. In addition, I added dual qc usb ports inside the console and a dual usb port for the rear seat (may add another). Used #6 wire from the battery to the fuse box. I need to clean it up some, but it's more or less done.
    20180930_151725.jpg 20180930_150422.jpg 20180930_150448.jpg 20180930_152749.jpg
  2. Sep 30, 2018 at 3:06 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    1 down, 3 more to go. Custom door handle bling to match the custom floor mat bling.
    driverdog, GAknight, Pudge and 4 others like this.
  3. Sep 30, 2018 at 4:21 PM
    mgm16trdpro
    Northern NJ
    I just finished, tried banging out during Giants halftime, unfortunately didnt realize he sent me 2 different sets so had to remove 2 and essentially placed on perfectly 6, got done 4 minutes left in 4th, damnit lol.
    20180930_190416.jpg 20180930_190146.jpg 20180930_183547.jpg 20180930_183508.jpg
    And 1 more showing off all that sexy amber coming off the front. Everyone says theres no mistaking my truck coming down the road. I've had people stop in the middle of the road in pitch black knowing it was me lol.
    I got them from Josh Portillo, his on tundra crew fb his biz is StickE Customs.
    TundrAZ, driverdog, Skippy and 2 others like this.
  4. Sep 30, 2018 at 4:37 PM
    snarkscarbine
    snarkscarbine New Member
    Alex
    Dallas
    2014 Silver Sky CM Ltd 4x4
    Bilstein 5100s Footwell LEDs Fold-A-Cover g4 elite TRD 18s
    @mgm16trdpro could you show where/how you mounted the rear footwell LEDs? Light throw looks great and mine are either too far under the seat or keep falling off.
  5. Sep 30, 2018 at 4:55 PM
    mgm16trdpro
    Northern NJ
    Tnx. The things I do for u guys. U got me crawling in the back of my truck with the doors shut and camera flash on lol. It's so hard to show but I tried my best. U can kinda make it out. On both seats theres a circular tab under it, on 1 side it's white, other its black. I've had the same problem as you with just about every strip but under the drivers front dash has come off once. So my fix, least for now is I've put gorilla tape on the ends of each strip. So far it's holding but when I just went under there the 1 side looks like it starting to pull off. Trust me I know what u mean about it being hard to find a spot. But if u go just behind toward the front of both those tabs theres a thin line of plastic under there. I've found that's the best place to mount them. I just need to find a more permanent solution to keep them there like u.
    Hope these help because they weren't exactly easy to get.
    20180930_194429.jpg 20180930_194400.jpg 20180930_194352.jpg 20180930_194141.jpg
    snarkscarbine[QUOTED] likes this.
  6. Sep 30, 2018 at 4:57 PM
    mgm16trdpro
    Northern NJ
    Welcome Ron, hes a good dude, fellow tundra owner.
    Watt maker likes this.
  7. Sep 30, 2018 at 4:58 PM
    snarkscarbine
    Alex
    Dallas
    Lol I feel your pain. me and about 187 mosquitos were doing that the other night. Thanks for the pics. I’ll give that a try and post up if I come up with something more permanent.
    mgm16trdpro likes this.
  8. Sep 30, 2018 at 5:12 PM
    mgm16trdpro
    Northern NJ
    Alex I can tell u this, as far as the mounting location for the light throw it's perfect. It's also the only spot that's teally even an option under there. It's flat, hard, and plastic. Besides that theres wires, carpet, and foam everywhere else. So I can tell you it's the best spot for both output and for it to hold. The only thing that can use some improvement is instead of gorilla tape, theres got to be a better solution to having it remain in place better, yet still be able to be removed if for some reason the strip goes dead and needs replacing.
    Anybody got a better, less likely to fall off solution than gorilla tape, but it can't be permanent in case it needs to be replaced? I got a ton of ideas I thought about for a permanent hold, but I'm hesitant to do so in case the strip goes dead. Anybody?
  9. Sep 30, 2018 at 5:21 PM
    mgm16trdpro
    Northern NJ
    See as simple as that idea is I just didn't really consider yet. I'm not sure if they can get in there around that plastic strip but if the can that might be perfect. Tnx Ron and that's why this site is invaluable. I think I'm going to try that now.
    NewImprovedRon and Watt maker like this.
  10. Sep 30, 2018 at 5:23 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Zip tie them that's exactly. What I did. Feed it up and behind the support bars. I
  11. Sep 30, 2018 at 5:26 PM
    mgm16trdpro
    Northern NJ
    Awesome tnx to both of u.
  12. Sep 30, 2018 at 5:28 PM
    War_Wagon312
    Rich
    Stock horse
    No problem sir. what are you running for the amber running lights?
    mgm16trdpro[QUOTED] likes this.
  13. Sep 30, 2018 at 5:35 PM
    mgm16trdpro
    Northern NJ
    Just stock but down the road might go vled Triton. Just haven't decided yet if keeping the pro lights or going to go with +18 LEDs or something else yet. The BD s8 lightbar actually throws off a decent amount of amber. So just between the amber stock daytime running lights plus side markers plus the s8 amber backlight theres quite a bit of amber during the morning, day and dusk. If I knew I was definitely keeping the stock pro headlights I'd get the Triton, I'm just not sure yet plus got other more important things I want to do first. Between the H R kit, bd fogs, and bd light bar, I have way more than enough light that I need right now. If anything I'd look to get further long distance like a LP9 before anything else right now.
  14. Sep 30, 2018 at 6:20 PM
    mgm16trdpro
    Northern NJ
    Hey Alex use my spot and take the advice of Ron and Rich. They were right. I just threw a total of 4 zip ties right around my gorilla tape for a little extra cushion between the wires and zip ties. It worked perfect. 1 zip tie on each side of led strip.
    Tnx again guys, see this is why I love this site and try to help others anytime I'm asked. I'll go out of my way guys to help you all because anytime I've ever needed any advice or an idea I've been helped. U can ask anyone on here, I'll go above and beyond for u guys because I know when and if I need the help the favor will be returned. There's definitely a good group of guys on this site and I'm glad I'm a part of it.
    There u have it Alex. Great advice from 3 great guys. Take the spot I showed u in pic and use zip ties around that plastic bar I showed u in pic. Don't forget the next time someone asks u a question to pay the help forward.
  15. Sep 30, 2018 at 7:41 PM
    snarkscarbine
    Alex
    Dallas
    I was going to try some 3m tape and sticking the strip to magnets that would grab through the carpetish flap under the seat onto another magnet placed on the inside, but zip ties seems like a no-brainer. Thanks y’all.
  16. Sep 30, 2018 at 7:43 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I put mine on with heavy duty velcro and backed that up with a few zip ties, same locations as @mgm16trdpro
  17. Sep 30, 2018 at 8:08 PM
    mgm16trdpro
    Northern NJ
    I'm not saying yours is a bad idea or wouldn't work. I do however think it's probably a bit more involved, not quite as simple and effective as just slapping a couple zip ties around it. I didn't think there was enough room to get anything between that white plastic strip I showed u in pic and the bottom of the foam seat cushion. However, after their simple and effective idea, I went out and tried it, I'd say within 5-10 minutes I was done with it and very confident I won't have to crawl back under there again like I've done a time or 2 on each strip over the past year or so. Assuming my led strips stay working I think I can forget about having to do anything else for them for a long time. The throw and location is perfect and so is the zip tie idea. Like you I immediately went into over thinking it and looked right past such a simple and effective solution. Go for it as we suggested, I'm confident u will be happy with it. Then take the time, energy, and money u save doing it this way and put that toward another nice addition to your ride. Good luck and take care.
  18. Sep 30, 2018 at 8:11 PM
    snarkscarbine
    Alex
    Dallas
    Yeah not sure why I didn’t think to use zip ties already, considering I ziptied the wiring in place. :facepalm:got caught up over-engineering again.... thanks for the suggestions guys. Sounds like a winner.
    Pudge, Watt maker and mgm16trdpro like this.
  19. Sep 30, 2018 at 8:22 PM
    mgm16trdpro
    Northern NJ
    Same here, I have a tendency to get creative and overthink things sometimes. It works great some of the time and I come out ahead, other times, like this, it backfires and I either spend a bunch of additional time or energy over what's necessary to get the job done and move on. As I get older and keep adding additional responsibilities to my life I'm really starting to appreciate the simple and effective solutions. Unfortunately my mind has yet to accept that thinking. Maybe 1 day I'll learn.
  20. Oct 1, 2018 at 8:42 AM
    Storm
    Storm Elite Member
    2018 TRD SPT
    Putco Blade LED Light Saber :laser:
    JoshuaA, mgm16trdpro and 2018Tundra like this.
  21. Oct 1, 2018 at 9:04 AM
    Storm
    Storm Elite Member
    2018 TRD SPT
    What's awesome about this set up is it comes with mounting brackets allowing the bar to clip onto the truck and be removed if needed. I added a more detailed write up here...
    https://www.tundras.com/threads/putco-blade-led-tailgate-light-bar.32390/
    JoshuaA, Watt maker and fatalkhaos like this.
  22. Oct 1, 2018 at 9:08 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Damn those look great! I really want those for my MGM...
  23. Oct 1, 2018 at 1:17 PM
    Storm
    Storm Elite Member
    2018 TRD SPT
    I bought from the manufacture's website, Putco. The part number is 92009-60.
    JoshuaA, Pudge and NewImprovedRon like this.
  24. Oct 1, 2018 at 1:22 PM
    This plug is half the price of the Putco one. I just ordered it on Amazon for $28
    I may have to tap the reverse light wire but for half the price, I can do that.
    CURT 55384 Custom WiringConnector
    JoshuaA, Pudge and Watt maker like this.
  25. Oct 2, 2018 at 1:38 PM
    BEERS
    BEERS New Member
    2018 MGM Tundra Sport
    Toytec Boss Lift, Stuby ant, Clear bra, Remote start, Tinted windows, Console Safe, ABS Protectors and LED Cargo, reverse and brake lights
  26. Oct 2, 2018 at 2:46 PM
    Just finished welding up my trailer hitch cover. Thanks to @ARamirez73 for the most crucial part.
    Thanks Adam.:thumbsup:
    GAknight, Skippy, Filcat2000 and 8 others like this.
  27. Oct 2, 2018 at 3:20 PM
    adamjohn923
    adamjohn923 GFY... you know what it means!
    Surprise Az
    18 Tundra CM TRD OFFROAD 4x4 Limited
    Fox 2.5 coil overs with resi adjuster, Camburg UCA, Fox 2.0 rear shocks, Method NV, Cooper 295/70/18. Ajt shift knob and keyfobs, Baja Designs ditch lights with rago brackets. Debadged all around. Color matched door handles and mirror caps.
    Scheduled my install for suspension, uca, and rims and tires.. Can’t wait to get it over to SDHQ but have to wait until the 16th.
  28. Oct 2, 2018 at 4:50 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Good call. Just make sure to tell them that Dan200 is not allowed to drive your truck.
    adamjohn923[QUOTED] likes this.
  29. Oct 2, 2018 at 5:23 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Installed @Toytec Lifts's carrier bearing drop kit and greased the drive shaft zerks. See build link below for more info.
    Toytec Lifts likes this.
  30. Oct 2, 2018 at 5:32 PM
    Pudge and Jim LE 1301[QUOTED] like this.
