Putco Blade LED Tailgate Light Bar
Discussion in 'Lighting' started by Storm, Oct 1, 2018.
  1. Oct 1, 2018 at 8:56 AM
    Storm
    Storm [OP] Elite Member
    2018 TRD SPT
    I was looking to add a tailgate light bar and came across the BLADE by Putco. I think what makes this light bar stand out from the rest is the fact it is a full LED strip and doesn’t show gaps between the diodes creating a clean strip of light. Another large plus is the fact it can be installed with the supplied clips which allows for easy removal should you need to access the spare tire opening. Overall it is super bright and operates with your running lights, brake, reverse, and turn signals. I wasn’t a fan of splicing the original wires so I purchased their quick connect harness which makes for a plug and play installation behind the bumper allowing for a clean install. Also, it still enables you to have full functionality of your trailer light connections. The adapter is part number 529004. Happy viewing!
  2. Oct 1, 2018 at 9:02 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    I have the same one, first mod I did to my truck, I love it! I did splice my wires though, wish I had known about the connector!
    Something I've been thinking about recently: Is it possible to lower the spare now? since it blocks the access hole?
    Storm[OP] likes this.
  3. Oct 1, 2018 at 9:08 AM
    Storm
    2018 TRD SPT
    I didn't attach the 3M strips to the back of the light bar itself. I used the 4 brackets it came with which will allow the light to be removed should you need to access the spare.
    ChrisTRDPro[QUOTED] likes this.
  4. Oct 1, 2018 at 9:12 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Could you get a picture at night with reverse lights on? I'd like to see how much it illuminates behind the truck. Thanks in advance
  5. Oct 1, 2018 at 11:54 AM
    Very nice. I picked up the same one. Guess I'll order the plug adapter. Don't you have to run 1 wire for the reverse light? @Storm
    Storm[QUOTED][OP] likes this.
  6. Oct 1, 2018 at 12:02 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I like this LED.
    To clarify: this LED when mounted obstructs the spare tire hoist access? If so, the LED has to be removed to access? That sounds like it could be a PIA if on side of the road somewhere.....
  7. Oct 1, 2018 at 12:03 PM
    It clips to brackets, easy to unclip.
  8. Oct 1, 2018 at 12:57 PM
    ChrisTRDPro
    MT
    It’s BRIGHT! It’ll light up everything in your rear camera and then some.
  9. Oct 1, 2018 at 1:00 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    What length did you go with? Also is there a delay when you hit the break? I like the tail lights light up before the light bar
  10. Oct 1, 2018 at 1:11 PM
    Storm
    2018 TRD SPT
    Yes, the plug harness has a white wire which I connected to the white wire on the light bar. The upside is you don't have to splice any of the wires on the truck.
  11. Oct 1, 2018 at 1:12 PM
    Storm
    2018 TRD SPT
    60" the part number is 92009-60. As far as a delay, it actually lights up in sync with the brake lights, may be a little quicker. In terms of timing down to the millisecond, the LED bar lights up quicker being LED vs the filament type tail light bulbs that come on the truck.
  12. Oct 1, 2018 at 1:14 PM
    :thumbsup:
  13. Oct 1, 2018 at 1:15 PM
    Pudge likes this.
  14. Oct 1, 2018 at 2:31 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Pudge likes this.
  15. Oct 1, 2018 at 3:10 PM
    Sarge33
    Sarge33 New Member
    Sierra Vista, AZ
    '18 Tundra SR5 DC 5.7L TRD Off Road 2WD- MGM
    Very nice write-up and pics. Thank you! I installed the 48-inch version with the Curt connector. I also used the clips so that it can easily be removed, if required. Looks great. No issues in the three months that I've had it. It comes with a three year warranty. I receive positive comments from neighbors, friends, and even stangers.
    Storm[OP] and Watt maker like this.
  16. Oct 1, 2018 at 5:57 PM
    Storm
    2018 TRD SPT
    @jewsNbrews here are some photos with no flash and a slow shutter on the camera
  17. Oct 1, 2018 at 5:58 PM
    Looks great.
    jewsNbrews and Storm[QUOTED][OP] like this.
  18. Oct 1, 2018 at 7:12 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Looks awesome, i have the same in my truck, also i wish i knew about the adapter. Hard wired mine.
    ChrisTRDPro likes this.
  19. Oct 1, 2018 at 7:47 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    How much does this run. It looks good. Are the turn signals sequential? That would be cool
  20. Oct 1, 2018 at 7:55 PM
    Sean, I paid $120 for mine at the Lake George car show last month. They normally sell for $160+
    Not sequential...…………….
    https://www.youtube.com/watch?v=J1HNQY6384I
    Pudge[QUOTED] likes this.
  21. Oct 1, 2018 at 8:09 PM
    @Pudge
    Sean My friend offered me this light bar, brand new in the box for $50. It is the ANZO #531058, it does have sequential turn signals. I can see if he still has it if you want, I'm about 35 minutes west of Danbury . I could meet you there if you want or I can go over to Colony Pizza in Milford, that's about 1.5 hours away, the pizza is worth the drive. Just let me know and I will ask him. This is the light...….
    https://www.youtube.com/watch?v=f3xtaiKyl3Q
    Pudge likes this.
  22. Oct 1, 2018 at 8:14 PM
    Pudge
    CT
    Wow that's really nice of you Jim and thanks for the offer. I think if I'm gonna get one I'd want the same one you got. I really like the look of it and how bright it is. Thanks for the offer though!!!
  23. Oct 1, 2018 at 8:18 PM
    :thumbsup:
    It's bright I haven't hooked it up yet....like everything else :rofl: Family comes first, I need 2 days to myself to do all my mods stored in the bed of my Tundra.:D Plus I'm waiting on the harness now, that was a great idea that @Storm had. I went with the Curt one though for 1/2 the price.
    Storm[OP] and Pudge[QUOTED] like this.
  24. Oct 6, 2018 at 3:40 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    What is the Putco part number? I looked on Amazon and there are 3 kinds. Autoanything has one kind but just asks if you have the tow package or not.
  25. Oct 6, 2018 at 5:41 AM
    Storm
    2018 TRD SPT
    60" the part number is 92009-60. I purchased from the manufacturers website.
  26. Oct 6, 2018 at 5:47 AM
    Noice!
  27. Oct 6, 2018 at 8:29 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Very nice looking tailgate led bar! I went with the 60” and 48” OPT7 leds. I’ve been very happy with them. Their 60” version has 1,200 leds on it! It has three rows of leds. Top row for signals, middle for reverse and bottom row for brake lights. I think the Putco looks great!
    D4x4TRD, Toyotoholic, Pudge and 7 others like this.
  28. Oct 6, 2018 at 8:48 AM
    WTS?!?!?! U landing planes in S.A.? Just kidding! Noice!
  29. Oct 6, 2018 at 9:20 AM
    1UPPER
    TEXAS
    Flux capacitor!
    Yup! Since the Tundra pulled the space shuttle, I’ve being trying to land me a Gulfstream or Boeing 777. Follow my runway lights!
    :mudding: :plane:
  30. Oct 6, 2018 at 11:28 AM
    G10dra
    G10dra Not a New Member
    @Storm I think if you change all your brake/backup lights to LED then it would all sync up and light up in sync.
    Edit - I"d suggest going with V-LED Vtriton. I"'ve had great experiences in the past with those. click here
    anthonygan and Storm[OP] like this.
