  1. Sep 12, 2018 at 7:32 AM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    Thank you. I may have the same thing going on. The only time I hear it is when I'm coming out of a parking lot or something at a slow speed. It make one ding and then nothing else.
  2. Sep 12, 2018 at 7:57 AM
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Yeah that’s how mine started, got progressively worse over time.
  3. Sep 12, 2018 at 8:04 AM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Thank you sir I'm gonna have them take a look.
  4. Sep 12, 2018 at 8:41 AM
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    2018 Midnight Black Tundra Limited 4x4 CM
    Rigid fog lights Interior Led light upgrade Spray in Bedliner CRUX Avity-01 VIM Bypass module 5% tint all the way around 50% on the windshield Wireless charger arm rest mod Amp Research Steps Bak Revolver X4 Tesla Style Headunit Procomp 4" lift Toyo M/T's 35x12.5xR22 Fuel Maverick D538 wheels 22x10 -24 offset
    Didn't do it today, but received my highly anticipated Tesla Style Headunit 7.1 Fastboot and installed it. Love it. I waited for a long time for them to get the "kinks" worked out. I must say the unit is perfect. Everything now works and exceeds my expectations!
  5. Sep 12, 2018 at 8:51 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Does this work on the non dual climate control models? (SR5, Pro)
  6. Sep 12, 2018 at 8:51 AM
    ZPMAN
    Minnesota
    Very sharp looking, hope I didn't make a mistake on getting it with the dials/knobs.
    Fiestee23 likes this.
  7. Sep 12, 2018 at 9:00 AM
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    I'm considering getting a tesla, so I looked at their screen and it has no buttons. Seeing that clean look plus it coming sooner is what made me get the knobless version haha
    ZPMAN[QUOTED] likes this.
  8. Sep 12, 2018 at 9:00 AM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Are there brackets for this position? Any pics or info on how it’s mounted?
  9. Sep 12, 2018 at 9:01 AM
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    I think I've seen someone that has the SR5 with one. They reported no issues. I don't know what the difference in interface choices would be though.
  10. Sep 12, 2018 at 9:05 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Obviously you feel more sway in corners. Otherwise the ride is appreciably smoother w/o them as the wheels are more independent. If you hit a bump on the left side it's not automatically transmitted to the right side via the sway.
  11. Sep 12, 2018 at 9:06 AM
    ZPMAN
    Minnesota
    monaco730[QUOTED] likes this.
  12. Sep 12, 2018 at 11:35 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Fine so far after my drive to work this morning.
    Tad bit of body roll but nothing serious.
  13. Sep 12, 2018 at 12:06 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    If u have it by dropping the skid you will see the wear marks on it. Mine already had the skid shim kit installed by the dealer and it worked perfect without any sounds. Then 1 day I decided to paint my calipers and in doing so I jacked up the truck in the front to get both sides up at once by doing it under the crossmember. Obviously I didn't feel the need to take the skid plate off since it looked like it butted up to the crossmember. But by doing it this way I must have either pushed or bent the skid plate up further to make contact on the crossmember.
    It sounded horrible for 2 months before I brought it in to get fixed under warranty. It would do just like u said, start and stop under slow speeds get a squeak and a grind like metal on metal. I live on a hill going up into my driveway so soon as the truck flexed on uneven ground it was pretty loud and annoying. Made my truck sound like a piece of shit. So the tech dropped the skid and was able to see I already had the shims in it. He could also see where the crossmember was rubbing on the plate just where I told him I was pretty sure it was coming from. Luckily, I knew him and he went the extra mile to add a little more space with washers to keep it off that. He also said he had an idea if it comes back to put a piece of leather between.
    Don't worry it's common issue and Toyota should fix it for free since there is tsb's out for it. It's an easy fix, they can put like a small shim in there to give a tiny space with some rubber bushings, you'll be good to go.
  14. Sep 12, 2018 at 5:20 PM
    okieblow
    okieblow New Member
    Oklahoma
    2014 Tundra Crewmax Limited 4x4
    Did the drivers side grab bar upgrade today so my daughters, wife as well as shortie man friends can get in the drivers seat if needed. This ain't a Ridgeline, cmon Toyota.
    JoshuaA, NewImprovedRon, Sas and 5 others like this.
  15. Sep 12, 2018 at 5:34 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Thank you sir I'm definetly going to have them look at it.
    mgm16trdpro[QUOTED] likes this.
  16. Sep 12, 2018 at 7:39 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Made my spare 35s fit under my @bayareametalfab low pro and made mounts for my knock off recovery trax
    GiantsFanDan, Pudge, Uturn09 and 9 others like this.
  17. Sep 12, 2018 at 7:47 PM
    What's with the diff colors?
  18. Sep 12, 2018 at 7:55 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Its a timezone world map. Give u time change calc. From right to left. I figure it will come in handy once i take my Tundra on a world wide expedition.
  19. Sep 14, 2018 at 7:22 AM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Finally got around to breaking out the vibersaw to reinstall some of my under seat storage after adding a sub kit.
  20. Sep 14, 2018 at 7:31 AM
    TomC843
    Tom
    Charleston, SC
    Also got this out of the way. Will never be used as long as I have the truck but can be put back easy. Good old rear seat mod makes easy/
    mgm16trdpro and Sas like this.
  21. Sep 14, 2018 at 8:22 AM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    How did you release that buckle? It's not looking obvious to me on mine.
  22. Sep 14, 2018 at 8:37 AM
    hokiehead
    hokiehead New Member
    2018 SR5 Off Road 5.6l
    SDHQ sliders
    "headliner" like the interior ceiling of your cab? please definitely get some pix up when installed.
    Coolhardy[QUOTED] likes this.
  23. Sep 14, 2018 at 9:14 AM
    sprtbkr
    Scott
    Denver, CO
  24. Sep 14, 2018 at 9:41 AM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Hoping will get to it by the end of the month.
    Yup, its interior cieling
  25. Sep 14, 2018 at 10:04 AM
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    That's unique and u like it. Make sure to post lots of pix of the process and the completion
  26. Sep 14, 2018 at 10:58 AM
    TomC843
    Tom
    Charleston, SC
    pop the cover. Obvious then. Small blade screw driver to pop open.
    sprtbkr[QUOTED] likes this.
  27. Sep 14, 2018 at 1:19 PM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Changed out the gray plasti-dip to red on the center console and painted the tow hooks red with cherry gloss enamal paint.
    Coolhardy and mgm16trdpro like this.
  28. Sep 14, 2018 at 1:42 PM
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    wash and detail. took about 4 hours
    MotoTundra and Pudge like this.
  29. Sep 14, 2018 at 2:49 PM
    chadh1972
    chadh1972 New Member
    AB1EEE84-B8CA-4514-9A0C-AAF0C55034BE.jpg 5A2C1998-B934-4D96-8760-11651DD811D3.jpg 03D65ECF-B49A-4AEA-8AF3-39A6DD720A2D.jpg Finally got rid of the last bit of chrome. Now it looks right.
  30. Sep 14, 2018 at 3:25 PM
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    [Hurricane project
    I wanted to have a Fuel Can for piece of mind and generators. I hadn’t seen a good way to mount one on a tundra, then again I didn’t look to hard.
    My answer to this problem:
    5 gallon Jerry can
    Smittybuilt here can holder
    4’ of 1” x 3/16” strap steel
    (4) 5/16”x1” bolt w/ lock washers/nuts
    (2) 1/2”x1-1-2” carriage bolt w/ lock washers/nuts
    Paint
    Cut the steel in 20” lengths. At 1” from end drill 1/2” hole. At 13” and 18” bore 5/16” holes.
    Paint it up and bolt it up and use the carriage bolts in the rails.
    Also it fits nicely under my revolver bed cap.
    aperezsh, saybng, Pudge and 10 others like this.
