Android Headunit
Discussion in 'Audio & Video' started by bryanpwatson, Sep 1, 2017.
  1. Sep 11, 2018 at 2:21 PM
    #1561
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    With buttons
  2. Sep 11, 2018 at 2:31 PM
    #1562
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    2018 Midnight Black Tundra Limited 4x4 CM
    Rigid fog lights Interior Led light upgrade Spray in Bedliner CRUX Avity-01 VIM Bypass module 5% tint all the way around 50% on the windshield Wireless charger arm rest mod Amp Research Steps Bak Revolver X4 Tesla Style Headunit Procomp 4" lift Toyo M/T's 35x12.5xR22 Fuel Maverick D538 wheels 22x10 -24 offset
    THANK YOU!!! I officially have no further reservations about this unit. Doing this not only made it sound better than stock (I have the pos "JBL premium sound upgrade package"), but it opened up more settings to adjust. For instance, from what I can tell, if you adjust the bass under that amp sound level it actually sounds like it turns up the bass in what JBL is calling a sub in the back seat and not just dumping a bunch of bass to all the speakers (like adjusting the bass would typically do).
    If you are on the fence about this unit, get off of it. Everything works. I have an Iphone and the system works flawlessly with my phone. No excuses.
  3. Sep 11, 2018 at 2:32 PM
    #1563
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    The ones with buttons aren't Going to be shipped till 2 weeks after the ones without . That was stated in the group buy message. Since it was a new version they needed a little more time to get there stock up I think
    D3Tundra likes this.
  4. Sep 11, 2018 at 2:34 PM
    #1564
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    The one with button were supposed to ship out 1-2 weeks after the ones without shipped. So that's probably why nobody knows because they just started shipping the w/o buttons late last week. So I wouldn't be surprised if you received a dhl email/text late this week/early next week stating when your unit will arrive. The only thing I would do is verify Phoenix got your order. When I first did it I called to make sure they received my order, come to find out my card blocked the charge because they thought it was fraud. So double check with them then be a lil more patient haha
  5. Sep 11, 2018 at 2:59 PM
    #1565
    dud13
    Ahhh, well aren’t I a dumbass. Lol
    Did not see the different ship times for button configurations.
    I will shut up now.
    AK-in-MI and sprtbkr like this.
  6. Sep 11, 2018 at 7:41 PM
    #1566
    borntostun
    borntostun New Member
    So it sounds like the fast boot version has all the HVAC bugs worked out?
  7. Sep 12, 2018 at 9:01 AM
    #1567
    TheTripleLindy
    TheTripleLindy New Member
    only problem i am having with mine on hvac is it either says hi or lo. i cannot seem to get any temp numbers to display. it is probably a setting but i have not found it. anyone have a suggestion/fix?
  8. Sep 12, 2018 at 9:07 AM
    #1568
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    I think they did that intentionally. I think they weren't able to figure out the code behind the temp numbers so they just used hi/lo. I run mine on Auto and if you adjust just the temperature, you'll notice the fan speed change as you filter through different levels of hot/cold temp. It seems as if its for example 1-20 clicks (1 being the coldest 20 being the warmest). Half way through itll switch to "hi" which is as if you had the temp knob halfway between the hot and cold. ...if that makes any sense. I'm starting to get a feel for where the temps are. You can feel the air get hot/colder. Like I said running it on auto seems to me like the best way to gauge the temp. I used to always run my truck on auto at 77 degrees so I know about what temp that feels like.
  9. Sep 12, 2018 at 9:15 AM
    #1569
    Yotaman18
    Yotaman18 New Member
    Corey
    Houma, LA
    2018 Platinum 4x4 Bitching Blue
    I think ya'll have me sold on this new version. Hopefully another group buy will come up soon :fingerscrossed:
  10. Sep 12, 2018 at 11:13 AM
    #1570
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    I'm also in if another group buy comes along.
  11. Sep 12, 2018 at 12:34 PM
    #1571
    zeekworld
    zeekworld New Member
    Hi, new to this forum and interested on one of these radios. Can someone explain the "group buy" thingy?
  12. Sep 12, 2018 at 5:07 PM
    #1572
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    Here is a little video of my HVAC... Showing the temps
    https://youtu.be/cL8xlEYz-Dc
    Watt maker likes this.
  13. Sep 12, 2018 at 5:16 PM
    #1573
    valeoray
    valeoray New Member
    Hi everyone,
    I have a similar unit for my Lexus IS250. I'm writing here because my forum doesnt have much info in this regard.
    The major issues I have are:
    1) I have to manually connect to my phone hotspot evrye time I turn on the car. Sometimes the connection drops and I have to manually reconnect.
    2) Bluetooth call volume is really low compared to the radio, so when you hang up, the radio will be at full volume killing your speakers and ears. I adjust the radio volumes and Bluetooth volumes in the hidden menu, but it doesn't do anything.
    3) I bought a USB Android cam for the DVR, but selecting DVR shows no signal.
    Do you guys have similar issues?
    Thanks
  14. Sep 12, 2018 at 5:35 PM
    #1574
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Post 1484 page 50
    ZPMAN likes this.
  15. Sep 12, 2018 at 6:37 PM
    #1575
    TheTripleLindy
    New radio is looking better than my team :(
    PapaGrizz, ZPMAN and Watt maker like this.
  16. Sep 12, 2018 at 7:19 PM
    #1576
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    A group buy is when a group of people make a deal with a vendor to sell them a product for a reduced price if the group brings them a certain number of orders. In this case we got a significant discount and as a group placed over 50 orders from this vendor.
    Fiestee23 likes this.
  17. Sep 13, 2018 at 6:08 AM
    #1577
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    Yours came with the temp already showing? Or you changed something to put the temp in there?
  18. Sep 13, 2018 at 10:17 AM
    #1578
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    I'd be in for another group buy as well.
    Moon Puppy likes this.
  19. Sep 13, 2018 at 3:52 PM
    #1579
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    It came out of the box like that
  20. Sep 14, 2018 at 5:21 AM
    #1580
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    hmmm. Maybe its because yours is a platinum. I shoulda got a platinum smh
    AK-in-MI[QUOTED] likes this.
  21. Sep 14, 2018 at 1:34 PM
    #1581
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    im in for a group buy too.. these seem great
  22. Sep 14, 2018 at 2:29 PM
    #1582
    zeekworld
    I'm in for the group buy too, who is in charge of this?
  23. Sep 14, 2018 at 2:38 PM
    #1583
    sprtbkr
    Scott
    Denver, CO
    There is a group on Facebook that put together the last group buy. Your best bet is to get in on that group.
  24. Sep 14, 2018 at 3:05 PM
    #1584
    zeekworld
    Thanks, I will drop them a FB message.
  25. Sep 15, 2018 at 5:26 AM
    #1585
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    It took a lot of work and time to get this group buy. Jodi Miller on that group did all the legwork.. Don't think there are enough people for another you need at least 50 people but you might be able to contact the company and tell them you missed out and they might honor the group buy.
  26. Sep 15, 2018 at 7:07 AM
    #1586
    zeekworld
    Thank you for the info.
    I pulled the trigger last night and used a 5% off coupon on the V2 fast boot.
  27. Sep 17, 2018 at 4:50 PM
    #1587
    TheTripleLindy
    I spoke to Phoenix today. They confirmed they have set the Hi/Lo on purpose and are still trying to work out the degrees (with numbers)
    D3Tundra[QUOTED] likes this.
  28. Sep 18, 2018 at 3:10 PM
    #1588
    Fiestee23
    SOCAL
    White sr5 4wd
    What additional items do I need before I receive my radio. If you have this and added something can u post the link for the accessories?
    IE:
    External mics, odb2, USB or HDMI ports, additional headrest monitors, anything would be helpful
    Yotaman18 likes this.
  29. Sep 18, 2018 at 6:31 PM
    #1589
    ZPMAN
    Minnesota
    get a front cam for the grill and mount/wire it. https://www.tundras.com/threads/front-cam-install-for-phoenix-android-hu.22363/ https://www.tundras.com/threads/this-is-for-anyone-installing-a-camera.22927/
    https://www.tundras.com/threads/diy-remount-front-cam-from-toyota-emblem-to-pro-grill.29539/
    Fiestee23[QUOTED] likes this.
  30. Sep 26, 2018 at 3:14 PM
    #1590
    dud13
    Anyone from the group buy receive the “knobbed” ones yet? They should have shipped this week or late last week.
