DIY: remount front cam from Toyota emblem to Pro grill.
Discussion in 'Audio & Video' started by ZPMAN, Aug 4, 2018.
  1. Aug 4, 2018 at 11:37 PM
    ZPMAN
    ZPMAN [OP] 2nd place is the 1st looser
    Minnesota
    Just installed my Pro grill and had to find a new location for my cam. The cam that i am using is one of these https://www.amazon.com/dp/B00P2EN5J2
    Since it fit nice in the Toyota emblem i was not sure if i could fit that cam in the Pro grill.
    After checking a few different palaces to mount the cam i decided to mount it at the top of thr Y because the shape is very similar of its previous location and had the right angle.
    Added a few washers to keep it centerd.
    Then a bigger washer to secure it.
  2. Dec 21, 2019 at 3:47 PM
    silber
    silber New Member
    2016 Black Tundra 1794
    Dirty Deeds exhaust, 6 inch lift, Grind wheels, Amp Research steps, NSV light bar, TRD Pro front and rear sway bars, FRAC harness.
    Hi, since your camera is a little off from the center, would you have a pic of what the video looks like?
  3. Dec 21, 2019 at 7:46 PM
    ZPMAN
    Minnesota
    This is all I have right now, will try to get a bettor video when I get some time.
    https://youtu.be/03y3v6Fi80g
  4. Dec 28, 2019 at 1:26 PM
    silber
    silber New Member
    Cool. Thanks for the video.
  5. Dec 28, 2019 at 8:21 PM
    ZPMAN
    Minnesota
    It would be hard to tell if the cam is off center by a 1" or 2
