  1. Aug 6, 2018 at 10:37 AM
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    She’s here. Now do I go gun metal or black powder coat??
  2. Aug 6, 2018 at 11:09 AM
    trooper669
    trooper669 New Member
    2018 1794 MGM
    TRD front and rear sway bars/ CAI. Recon smoked tail lights. LED Bed Lights. LED grill lights Bilstein 6112 front and 5100 rear. RC 1” rear block. RC lower grill LED bar. Nitto Ridge Grapplers 295x60x20 on Fuel D-251 couplers. SDHQ ABS covers. Rear under seat storage. Body mount rebuild. Color matched mirrors, handles. Raptor step bars.
    d556 couplers in dark tint, yes sir!
  3. Aug 6, 2018 at 11:20 AM
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Gun metal! Black would just blend into everything else.
  4. Aug 6, 2018 at 11:29 AM
    trooper669
    2018 1794 MGM
    Agreed, keep the red accents!
    jaredmillerdvm likes this.
  5. Aug 6, 2018 at 12:17 PM
    Beni36ti
    Beni36ti New Member
    2017 SR5 CrewMax
    Fender Flare test installation, what do you think?
    The black grille now gets some black compagnions
    4x4_Angel likes this.
  6. Aug 6, 2018 at 3:39 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    How 'bout MGM???
  7. Aug 6, 2018 at 3:57 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    What is the rear camera always on mod? Different from frac?
  8. Aug 6, 2018 at 4:14 PM
    zeke7681
    zeke7681 New Member
    Zeke
    PA
    2018 Black TRD Sport CM
    Not installed yet but, I just ordered Go Rhino RB20 running boards and a TruXedo Lo Pro QT Tonneau cover.
    4x4_Angel and RW-3 like this.
  9. Aug 6, 2018 at 4:33 PM
    FortSantiago
    FortSantiago New Member
    Poor man’s FRAC.
    Hondoman[QUOTED] likes this.
  10. Aug 6, 2018 at 4:37 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Howd ya do it?
    sprtbkr likes this.
  11. Aug 6, 2018 at 4:40 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Ok...so as noted in the last post here below are some more detail/pics on the passenger-side, grab handle suede and leather wrap.
    @Cfincke and @Pudge
    Just tagging you two gents since you asked about the handle detail.
    First, I wrapped the passenger pillar. The prep for the pillar was same as in the last post. On to the handle, below....
    For the handles:
    I started by making a pattern from blue painters tape. I cut the leather a little bigger, then trimmed it for a tight fit on the handle.
    I then skived the ends. While the outside of the leather has a great finish and look, the underside was unfinished and had a lot of fibers. This makes it a bit thicker and more difficult for tucking in around the small gaps of the handle once reattached. Trick is, not to go too thin...basically going for a thick suede feel. Here's the basic shape cut and after a little skiving (note the color difference).
    Next was the stitching. Pretty simple, over-under stitch from one end to the next. Then back from the end to the beginning, stitching the opposite gaps. Used the same needle and (spool) red thread that came with the steering wheel cover.
    As noted, I cut it so it was relatively tight to the handle. With the center area being a bit thicker leather (because it wasn't skived), it didn't stretch as well. A little warm water to dampen the leather gave it just enough flexibility. Once test fitted, I applied the contact cement, starting at the center line on one side, working around to the other. Important for being able to reinstall; I only glued the handle around the middle, and on the inside line where the stitch lines meet.
    Glued and starting cross-hatching, just like the steering wheel pattern...Double thread, looping into every other stitch, one side to the other.
    All done, until reinstall. I leave the ends unglued to access the caps/ bolts.
    Once reinstalled in the truck, I'll glue the leather down, trim the edges to allow about 1/8" - 3/16" to tuck under the edge of the handle.
    Reinstalling this evening...I'll post a final pic when done.
    hypa, Grumpy Uncle, aperezsh and 9 others like this.
  12. Aug 6, 2018 at 4:42 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Wow man that's a lot of work really looks great. Nice custom touch
  13. Aug 6, 2018 at 4:51 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Thanks bud!
    Second time around was obviously a lot quicker. Made for a easy Sunday afternoon project.
  14. Aug 6, 2018 at 5:02 PM
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Installed Bilstein 5100 rear shocks and SDHQ ABS guards. Holy crap, I cannot believe the difference in how the truck rides compared to my 60k mile yellow TRD shocks. I've had the Radflo/Toytec front coilovers for a couple months but hadn't taken the time to change the rears. Feels like a totally different truck. Much more stable at speed and a lot smoother over bumps.
  15. Aug 6, 2018 at 5:39 PM
    wrtnaz
    wrtnaz New Member
    Tucson, Az
    2018 MGM Tundra SR5 CrewMax
    Wireless Charging Center Console Tray 6 3/4" Antenna Mast OEM Bed Mat Weather Tech In-Channel Low Profile Wind Deflectors Chrome Mirror Caps/Handles Limited Grill w/Chrome Surround Ionic 5" Oval Stainless Step Bars Center Console 110v and USB Power Converter Black Tundra Door Sill Protecters Undercover Swing Case Wireless LED Bed Light Strip Toyota Chrome Exhaust Tip 18" TRD Wheels
    Same here. I am super happy with the WeatherTech in-channels. They help keep my truck a little cooler when I am parked in the 110
    Same here. I am super happy with the WeatherTech in-channels. They help keep my truck a little cooler when I am parked in the 110 AZ heat believe it or not and they are really clean looking on the truck
  16. Aug 6, 2018 at 5:42 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Recoat the front bumper and add new lettering to the grill. :mudding:
  17. Aug 6, 2018 at 5:50 PM
    wrtnaz
    wrtnaz New Member
    Tucson, Az
    Nice do you have a like for that?
    Sas[QUOTED] likes this.
  18. Aug 6, 2018 at 5:58 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  19. Aug 6, 2018 at 7:26 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    My kid’s summer swim team is over for the season so I unloaded all of the gear that I have been hauling around all summer:
    • 6 camp chairs
    • roll-up table
    • camp cot (for the 2-day meets)
    • lightspeed instant pop-up sun shelter
    • 10’ x 10’ pop-up canopy
    • folding wagon
    • picnic blanket
    4x4_Angel and SteadfastZach like this.
  20. Aug 6, 2018 at 8:26 PM
    jaredmillerdvm
    Anderson, SC
    My powder coat guy doesn’t think he could match it. I would definitely go MGM if I could!
    aperezsh and 4x4_Angel like this.
  21. Aug 6, 2018 at 8:38 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Ahh...Didn't catch that you were powder coating. Being under the truck, I bet the gun-metal will look close to the MGM.
    Do you have the front TRD sway?
  22. Aug 6, 2018 at 11:28 PM
    ZPMAN
    Minnesota
    Took my boy and his friend out to the pratice track in the back 40.
  23. Aug 7, 2018 at 12:15 AM
    2017 TRD PRO
    2017 TRD PRO New Member
    NEW ENGLAND
    2017 TUNDRA TRD PRO DC
    Tuffy Security center console safe, WeatherTech TechLiner bed liner and tailgate liner, Are Cap, Interior LED light upgrade, White Knuckle Sliders, SDHQ A-Pillar Mounts, Rigid D-Series Pro's, Rhino-Rack Pioneer Platform Rack, DIY Custom Draw System.
    Nice, I was thinking about doing the same red accents, brakes and tow hooks. Looks good !!!!
    Jim LE 1301 likes this.
  24. Aug 7, 2018 at 3:36 AM
    That's what I did.
  25. Aug 7, 2018 at 7:45 AM
    yt-1300
    yt-1300 New Member
    2021 white sr5 crewmax 4x4
    Got my yodagan stickers on. 94B78D5D-B7B3-4F8A-8633-48FE56CBA60F.jpgF5F516E1-7B7E-4C3E-93E9-A77B49E62A75.jpg
    4x4_Angel and Sas like this.
  26. Aug 7, 2018 at 10:10 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Did a little steering wheel detail work over the weekend. Did vinyl on the plastic trim pieces and GF stitched the leather cover on. She said it was fairly easy with the trim and airbag out, and tucking in was super super easy when putting the trim pieces back in. Volume button is sticky now but I rarely use it, and I think it's almost better this way as I can press it and it holds it down to really crank up the sound.
    equin, mgm16trdpro, CCLJ03 and 7 others like this.
  27. Aug 7, 2018 at 10:19 AM
    phnominon
    phnominon New Member
    Rich
    Upstate NY
    Blue 2015 SR5 Crewmax
    I really like that.
    GiantsFanDan[QUOTED] likes this.
  28. Aug 7, 2018 at 11:11 AM
    jaredmillerdvm
    Anderson, SC
    Nope. Heard it didn’t make a huge difference.
  29. Aug 7, 2018 at 1:52 PM
    Ortho281
    Ortho281 New Member
    Paul
    Katy, TX
    2016 White Tundra 1794 Edition
    4.5" BDS Fox Coilovers / Total Chaos UAC's / 20x9 KMC XD820 / 295/60R20 Toyo AT II / SDHQ Hidden Winch Mount / Warn 10S Platinum / HR 32” LED light bar / Amp Research Power Steps
    Got her a little dirty in the Sam Houston National forest with the Houston Overland group. :)
    WeakSauce01, equin, aperezsh and 14 others like this.
  30. Aug 7, 2018 at 2:15 PM
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    Installed SwingCase today on passenger side. I have the Extang SolidFold 2.0 and I had to trim the handle about an inch plus the screw that is inside of the handle via a hacksaw. Put the bolt back on the screw that holds the spring in place giving it tension and added some locktite to it. Wrapped the handle with some electrical tape to beef it up a bit so it sticks back into the cover like it did prior to me trimming it.
    BTW: I got this at AutoAnything. Ping @eccracer104 for a great deal.
    This is about how much I needed to trim (actually cut twice... since I needed a little more).
    Still has full function for the handle and keeps the cover on tight
    aperezsh, Ortho281, sprtbkr and 5 others like this.
