  1. Feb 22, 2024 at 10:04 AM
    It is the wiring. If I remember correctly when I installed mine, it has something to do with the purple wire on the Pioneer side.
    Put s post in this thread and one of them will most likely remember.
    https://www.tundras.com/threads/new...600nex-into-a-2018-sr5-entune-non-jbl.100157/
    rdiddy5[QUOTED] and bulldog93 like this.
  2. Feb 22, 2024 at 10:20 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Just ordered a new passenger side wiper arm. Once delivered I will install it.
    Velocity72 likes this.
  3. Feb 22, 2024 at 10:20 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Hated airbags. I ran Firestone Ride Rites with Daystar cradles because I didn't want the bags ripping apart when articulating the suspension off-road.
    I couldn't find a PSI that wasn't noticeably bouncy when unloaded.
    Moved to HD RAS. All my problems solved and then some. I'm running the Pro suspension with a 2" lift up front, and I have what I would consider factory rake if not a little more than factory.
    That's fine with me. I can not stand the "leveled" look. It screams "I'm only here for the stance and don't ever use my truck as a truck" to me. Just my subjective opinion.
  4. Feb 22, 2024 at 10:37 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Well, have not done it yet, but these two boxes were dropped at my front door this morning!
    I’ll share pics of the install but I am looking forward to this ‘extension’.
    AstroDude likes this.
  5. Feb 22, 2024 at 11:11 AM
    Gecko.
    Gecko. New Member
    CT
    2014 Tundra DC
    Thank you for the input. Very helpful. If I can ask you two follow up questions:
    (1) The first is the same one I asked Eborseti22, with your truck's current stance being what "[you] would consider factory rake if not a little more than factory," are you using the white disc or the black disc on the RAS?
    (2) Second, can I assume the "Pro suspension 2" lift up front" that you used means a lot more suspension pieces than the Mammoth 2" spacer kit mentioned by Eborseti22, or is it basically the same?
  6. Feb 22, 2024 at 11:13 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Just for clarification....
    When you say you have a 2" lift up front, are you saying you have a 2" lift on top of the stock Pro suspension up front or the stock Pro suspension gave you a 2 inches of lift??
  7. Feb 22, 2024 at 11:21 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I ran them as well. I used the AirLift and I did not have the cradles. My issue is that they rode awful when not needed. I replaced them with SumoSprings and this was an excellent solution for me. It limited my squat without hurting my empty ride.
    My fear with RAS is that it stresses different areas of my leaf springs. It forces most of the work to be done with only the back half of the leaf because it limits the motion of the front. The result of this is increased stress and ultimately less life out of my leaves. If you want some extra height and suspension capacity do and add-a-leaf. I have used Alcan in the past and they make a great product.
    I am not in love with the leveled look but I love the way the Pro suspension works and rides so I will take the good with the bad. If my truck squats while working..... Well it shows that I have a great suspension that when needed it will flex to keep me comfortable. If you remove the suspension, your truck will never squat :)
  8. Feb 22, 2024 at 1:50 PM
    centex
    centex New Member
    11 spots of epoxy to fix this busted bulge. Brilliant design Toyota. Contemplating drilling a bunch of holes in the black part to let air vent out so there isn’t so much pressure build up there.
  9. Feb 22, 2024 at 2:13 PM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Mixed
  10. Feb 22, 2024 at 2:58 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Was able to snag a driver's side handle from a local salvage yard. Cleaned up well and was insanely easy to install. I followed the instructions riddled throughout the site, with one addition. I grabbed both factory bolts from the donor vehicle. Of course I don't have the receipt to confirm, but I was able to reuse them for the install. I believe it was a M6x1.00 thread and it was right next to the 1/4x20 (or whatever) the instructions recommended for the u-shaped nut. I'm sure this isn't news, but was for me in the hardware aisle finding a fit to factory bolts. The different size bolt heads would have driven me more insane than the mild imperfections in a plastic panel.
  11. Feb 22, 2024 at 3:21 PM
    Terndrerrr
    Music City
    6UR-FE
    I have the OEM Pro setup, which is 2” taller up front than OEM non-Pro.
    1. Black disk
    2. It just means that the coilovers (springs + shocks) are 2” taller. It makes the Pro trucks look more leveled, but also has longer suspension travel than OEM shocks.
    RAS has the added benefit of acting like a rear anti-sway bar. Less “floaty” in turns. The system somehow improves ride empty and loaded, and it still allows articulation for off-roading. I’m extremely impressed.
    Agreed on airbags and cradles: awful when empty.
    Interesting take on the RAS. I haven’t heard of anyone saying the system wore out their leaf springs faster. My problem with the Sumos is the lack of articulation when off roading.
    Velocity72, _none_, WFD473 and 5 others like this.
  12. Feb 22, 2024 at 3:50 PM
    InfernoTundra15
    InfernoTundra15 2015 TRD Pro
    Installed seat jackers today. Definitely improves the seat angle. If anything I feel like I sit a little higher than I would like. I think it will help with long drives. Without them the seat feels so flat and deep. As someone else said in another post, it feels like you’re sitting on top of the stock seat, not “in” the seat.
    bulldog93, Tripleconpanna and bflooks like this.
  13. Feb 22, 2024 at 4:03 PM
    bflooks
    bflooks New Member
    Metrowest MA
    The support in the thigh is a big bonus on long drives. Nothing worse than getting a few hours into the drive and realizing you've been putting all the weight on your heel.
    bulldog93, Tripleconpanna and RobertD like this.
  14. Feb 22, 2024 at 4:50 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Woah with the go finally going in.
  15. Feb 22, 2024 at 4:53 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Sir!!! This is a safe for work forum! Stop dropping the porn!
  16. Feb 22, 2024 at 6:56 PM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    Stock air box mod today
  17. Feb 22, 2024 at 7:25 PM
    SAGE63
    San Diego County
    looks eh ok... lol
    JK... looks great
    reywcms[QUOTED] likes this.
  18. Feb 23, 2024 at 3:52 AM
    Kung
    KG, VA
    I felt the same for a week or so. I actually got my Katzkins and Seat Jackers installed @ the same time (the shop that did the Katzkins did the Seat Jackers @ no additional fee). I feel like they *could* be maybe a bit shorter, like 1/2" or 3/4" or so, but to be honest, the improved angle and the comfort resulting from it is such that after a few days I thought "Meh, this is fine" and now I love it. :)
    Wife loves driving the truck now - says it makes her feel like a 'big kid.' :rofl: She gets the occasional nod or whistle from other truck owners. :D
  19. Feb 23, 2024 at 6:07 AM
    ghost0211
    ghost0211 New Member
    San Antonio
    2016 Tundra CM SR5
    - 35x12.5 Atturo Trail Blade XT - Fuel Covert 17x9, -12 offset - Biltein 6112 (only 2" front) - Vivid Racing valvetronic dual exhaust system - VLAND LED headlights & taillights - AutoTecPro Tesla-style head unit - Bed liners & cover - Tyger running boards - Low profile bumper & 28" light bar - TRD Pro grille - TRD skidplate - Cab lip - Ceramic tint - Chrome delete - OTT Tuned "Super Spicy"
    Got the BMC knocked out and mounted my Fuel Coverts 17x9 -12 and 35s beneath a 2" Bilstein lift. Installed the Vivid Racing valvetronic exhaust system.
  20. Feb 23, 2024 at 7:55 AM
    TS1794
    TS1794 New Member
    Northern CA
    2019 Tundra 1794
    6" Lift 37X12.5X20 on here to get more ideas
    Ok guys,
    First round of modifications done:
    33” to 37” tires
    1/2” bumper spacer
    TRD grille with raptor lights
    Grille surround
    Hood bulge
    Black front bumper fascia
    Tyler Fender Flares
    LED Interior lights
    LED third brake and reverse lights
    Mirror covers
    Door handle covers
  21. Feb 23, 2024 at 8:09 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Heck of a transformation. Looks great!
    CaptRussia253 and TS1794[QUOTED] like this.
  22. Feb 23, 2024 at 9:24 AM
    Cliffy34
    Cliffy34 New Member
    Pittsburgh
    2018 White Tundra SR5 Crewmax
    Welp, my order was cancelled. Apparently there’s a “national shortage with no ETA”. Anyone have Crewmax bed mat recommendations?
    Tripleconpanna likes this.
  23. Feb 23, 2024 at 9:29 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    @roughfisher - I wonder if this air box mod makes the engine more susceptible to water ingestion and hydro lock when driving through deep puddles. It’s been reported on this site.
  24. Feb 23, 2024 at 9:46 AM
    RobertD
    Robert
    DFW, Texas
    You are confusing the Stillen with the SABM. The stillen potentially has issues since it adds an opening in the "grille" that goes to the airbox, so if you hit a deep puddle its more likely to add water to your intake. Which is why Stillen sells a system with a shut off plate so you can close the front entry point as needed.
    The SABM has the same risk as your stock intake, so your statement makes no sense since the normal intake has no issues with water ingestion.
  25. Feb 23, 2024 at 9:48 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I have the rough country bed mat for my tundra. Reasonably priced and good quality. I don’t necessarily like many RC products but this one is solid.
  26. Feb 23, 2024 at 10:03 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    I had a bed mat in my Tacoma, loved it. Heard good things about the RC bed mat too, but I opted for the BedRug this time around and love it more than the bedmat...Bed Rug.jpg
    Not the best photo of it, but I love it and would recommend it to anyone. Easy install as well.
  27. Feb 23, 2024 at 10:22 AM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Installed some Ebay door handles, not bad for the price. Some imperfections with the paint and the handles are certainly aftermarket units. The worst thing is they shipped them loose in a bag with bubble wrap.
  28. Feb 23, 2024 at 10:24 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    That looks and works just fine...door handles are almost the most used item...imperfections mean you use your truck!! Nice find!
  29. Feb 23, 2024 at 10:28 AM
    kbahus
    kbahus New Member
    MI
    Yeah I figured they would get scratched up pretty quick from keys and nails. Easy to swallow the price.
    HulkSmurf14 likes this.
  30. Feb 23, 2024 at 11:08 AM
    roughfisher
    JP
    Northern Minnesota
    Got my bullet point mounts installed and finally got my auxbeam switch panel harness fished though the firewall and installed the panel on the dash plate. Now I just need to get the fuse panel and circuit breaker installed in the engine bay then the switch panel should be operational
