  1. Aug 20, 2022 at 4:50 PM
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    I used the white. The rear leafs on my truck were really flat before this. I think 5 years of overloading it might be why the RAS made it so high.
  2. Aug 20, 2022 at 4:54 PM
    That is possible. Toyota leaf springs are too soft. Mine went bad on my 2020 at around 13k miles.
  3. Aug 20, 2022 at 5:16 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What shackles are you running?
  4. Aug 20, 2022 at 5:30 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    I’m assuming this is the extension bracket needed when adding lifts or longer shocks to the rear, correct? If so, what’s the verdict on the orientation? I’ll be installing the FOX pro suspension and want to make sure in install it correctly.
  5. Aug 20, 2022 at 5:55 PM
    Uturn09
    Uturn09 New Member
    Roscoe
    Damn, 13k! Mine has 127,000. How did you know? Only way I ever knew a spring was bad is if it was cracked or completely broke in half.
  6. Aug 20, 2022 at 5:58 PM
    Uturn09
    Uturn09 New Member
    Roscoe
    Just plain old factory ones.
    ZPhilip[QUOTED] likes this.
  7. Aug 20, 2022 at 6:05 PM
    They started creaking and had a gap in between them.
  8. Aug 20, 2022 at 6:46 PM
    Uturn09
    Uturn09 New Member
    Roscoe
    Oh crap, that is crazy!
  9. Aug 20, 2022 at 7:27 PM
    ZPhilip
    Philip
    West Chester, PA
    Ok thanks. I’m trying to figure out if the RAS works with CB +1 shackles.
  10. Aug 20, 2022 at 7:43 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    - Re-Lubed my TC UCA
    - Changed the oil
    - Rotated tires
    - Also broke the key lug so I swapped them all out with standard lug nuts
    pvn.beluga likes this.
  11. Aug 20, 2022 at 7:48 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    I got a replacement grill for my truck. Found it locally on FB marketplace. It had some damage to the outer chrome so I had to swap the chrome parts so the insert had to come out of my limited grill.79B7DA43-B270-4D11-B76E-93C3CEE8EA14.jpg
    hi_rawb, Jego, shawn3210 and 5 others like this.
  12. Aug 20, 2022 at 8:33 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
  13. Aug 21, 2022 at 4:58 AM
    mav7021234
    mav7021234 New Member
    Beesta likes this.
  14. Aug 21, 2022 at 6:48 AM
    Junior 88
    Junior 88 New Member
    Junior
    18 tundra Sr5
    7inch bds on 35s
    mav7021234[QUOTED] and bulldog93 like this.
  15. Aug 21, 2022 at 7:36 AM
    ZPhilip
    Philip
    West Chester, PA
  16. Aug 21, 2022 at 7:48 AM
    Bergy24
    Bergy24 New Member
    Installed the Husky XAct fit rear mat and installed thicker nylon shims between my TRD skid plate and crossmember to help eliminate noise between the 2.
    cartage1 likes this.
  17. Aug 21, 2022 at 8:41 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Sexxy
  18. Aug 21, 2022 at 8:42 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Sexy B !!
  19. Aug 21, 2022 at 8:52 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
  20. Aug 21, 2022 at 10:40 AM
    joey2018
    joey2018 New Member
    Nothing like a shiny black truck!
  21. Aug 21, 2022 at 6:20 PM
    imcalister
    imcalister New Member
    Scott
    Van Alstyne, TX
    2020 Tundra CM Attitude 5.7L 4x4
    Installed a Bakflip MX4 today. Found it used locally for $300. It’s not perfect but for the price couldn’t pass it up. Was considering a cheap cover for around the same price.
    also installed a console organizer.
  22. Aug 21, 2022 at 7:15 PM
    Enviroman
    Enviroman New Member
    2020 Limited CM
    Rigid Spots in rear bumper, TRD Dual Exhaust, Weathertech Floor Mats
    Exactly what do you mean by resealing the light housings? What areas need to be sealed better. I’d like to try some lights like that, but I don’t want to have it quit working. Thank you all!
  23. Aug 21, 2022 at 7:29 PM
    RobertD
    Robert
    DFW, Texas
    Sealing the ends of it where the ends caps attach. Often the aftermarket lights tend to have failures in the seal so water or dirt gets into the main section. Folks have found that by re-sealing the lights from the start, really improves how long they last.
  24. Aug 21, 2022 at 7:45 PM
    Enviroman
    2020 Limited CM
    Awesome. I wasn’t sure if they were talking about resealing along the entire lens, or the ends, or both. Thank you for clarifying that.
    RobertD[QUOTED] likes this.
  25. Aug 21, 2022 at 7:54 PM
    RobertD
    Robert
    DFW, Texas
    I've only heard of resealing the ends, but if you have visible seams along the entire lens, it might not hurt to throw a bead a sealer along those as well. As long as its not going to obscure the light output, it really can't hurt to over seal more of it.
  26. Aug 21, 2022 at 8:42 PM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    Put on the door overlays to cover up the silver trim.
    This completes my interior chrome/silver delete. I left the radio and the climate control area OEM. It gives it just enough contrast. Everything else either had overlays or outright replacement. AJT, Meso and Amazon got alot of biz out of me.
    https://www.amazon.com/dp/B0B1ZJKCKZ?ref=ppx_yo2ov_dt_b_product_details
    They fit OK. No real issue.
    Someone earlier in the forum said the tape was not as good so I replaced the center piece with some real 3M tape I had from an earlier project.
    Jcmf52, welshmike, Beesta and 6 others like this.
  27. Aug 22, 2022 at 12:13 AM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Not today but Friday, tried out my new drone thanks @AZBoatHauler , also got to see the rare South Western lights, they're just like the Northern lights but completely differentdji_fly_20220820_135334_2_1661070807410_photo.jpg dji_fly_20220820_173930_9_1661070486354_photo.jpg 20220820_191119.jpgzoom in on the last one to see the lights
    Wallygator, Bowzer, Major and 18 others like this.
  28. Aug 22, 2022 at 3:27 AM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    Looks good. They going to get my money too.
  29. Aug 22, 2022 at 4:29 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Very cool. That almost looks like a Sprite. What is it?
  30. Aug 22, 2022 at 4:32 AM
    Which drone? I haven't flown mine in quite a while.
