  1. Aug 4, 2022 at 1:48 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Cutting out some additional unused brackets that were hitting or could potentially rub in prep for the dune run tomorrow. Also painted the inner fender wells with steelit to clean it all up a bit. Jacked it up to work on it. Check out that droop! Still had more room to go before it was maxed but don't think I have the ceiling height in the garage left.
  2. Aug 4, 2022 at 1:54 PM
    DacianDesignLLC
    DacianDesignLLC New Member
    2021 Tundra
    Yeah just saw your thread, huge difference, looks like the integrity of the stock surrounding was ruined by cutting the ends of the black abs backing. And the grille itself has a gap in between the top hat also not good. The mesh looks to flimsy on that one too. Ours is built very different and solid when mounted.
    NewImprovedRon likes this.
  3. Aug 4, 2022 at 2:10 PM
    Post #23 is pretty much the same as the grill that I tried. You can see the tabs that I was referring to. https://www.tundras.com/threads/after-market-grilles.107190/#post-2760791
  4. Aug 4, 2022 at 2:24 PM
    king.cong.1119
    king.cong.1119 New Member
    thanks man. I’d get the rock worrier but I don’t want to run spacers to fit my tires. Also I believe these icons have more weight capacity over the rock worriers.
    PermaFrostTRD[QUOTED] likes this.
  5. Aug 4, 2022 at 2:27 PM
    DacianDesignLLC
    2021 Tundra
    Once done and released you will see the rest of the pics, the grille you installed is totally different. A lot of weak points based on the pics you posted on that grille. And you either have no bottom mounts or they are separate brackets where ours are built in the grille on the bottom as well to make it one true piece. Plus we use 2 sheets of stainless steel together for the grille and mesh. It’s as solid as it gets, Again we have had it on our test truck 9 months no issues, we also been designing this grille for over a year almost before we knew we had something ready for the consumer.
    There will be a spot for the sensor as well, that’s in its final stages along with couple options like center logo and choice between powder coated bolts or bare stainless look. There is a lot that comes into play when building a great grille, most grilles on the market are quick builds and lack attention to detail. Thanks !
  6. Aug 4, 2022 at 3:07 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Thanks for the info. When you installed the PRO suspension, did you install this bracket too? Is it Necessary?
    https://parts.conicellitoyotaofcons...toyota-tund-speed-sensor-bracket-ptr6134190sb
    Badknees[QUOTED] likes this.
  7. Aug 4, 2022 at 4:01 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Now you're just showing off!!!! Look how long it is!! :rofl::rofl::rofl:
    GODZILLA, RobertD and Taco-Spike like this.
  8. Aug 4, 2022 at 4:04 PM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Yes I installed he bracket and yes I think it is important. The Fox shocks have more travel length than stock. This bracket prevents putting stress on the speed sensor cable at full suspension travel. I did cut off the “ear” on one side to clear the RSB mount U bolt.
    Bergy24[QUOTED] likes this.
  9. Aug 4, 2022 at 6:17 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    I’ve had my HiRev tail lights on for a year now and have grown tired of them. Should have went with the smoked ones instead of clear. I put my originals back on. I’m fixing to have my HiRevs posted in 2.5 Marketplace if anyone is interested.
  10. Aug 4, 2022 at 6:32 PM
    Bergy24
    Bergy24 New Member
    Anything else needed when installing the PRO suspension? I occasionally tow a small trailer (about 1500lbs empty & 2000 lbs +/- loaded). My truck really doesn’t sag at all with the stock TRD off-road suspension. I know it will have less rake if any with the PRO suspension. Should I see what it looks like before adding anything to the rear?
  11. Aug 4, 2022 at 6:43 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    From there web site same time with Gears
  12. Aug 4, 2022 at 6:50 PM
    Spray them......
  13. Aug 4, 2022 at 7:05 PM
    Clemshady
    Jeff
    Not a bad idea. Might do it to my factory ones. Of course someone who shall remain nameless has sent me the link to Hot Tails. Geez, the mods never stop. :rofl:
  14. Aug 4, 2022 at 7:06 PM
    :spending:
    Henry1jg and Clemshady[QUOTED] like this.
  15. Aug 4, 2022 at 7:17 PM
    the ER kid, HulkSmurf14, WBW and 3 others like this.
  16. Aug 4, 2022 at 7:20 PM
    RobertD
    Robert
    DFW, Texas
    :anonymous:
    I would never try and spend more of your money.
  17. Aug 4, 2022 at 7:23 PM
    Clemshady
    Jeff
    French Avocado, GODZILLA and RobertD like this.
  18. Aug 4, 2022 at 7:30 PM
    Lol.....I know I've been cohersed into spending money in this forum. Hell, I bought a whole damn truck after seeing the 2022 and how hideous it looked and no 5.7 lol.
    Wallygator, Ace96, texasrho83 and 4 others like this.
  19. Aug 4, 2022 at 7:32 PM
    Clemshady
    Jeff
    IKR? Ain’t no way I’m buying one either.
  20. Aug 4, 2022 at 8:20 PM
    sta_f0u
    sta_f0u New Member
    Jon
    Nevada
    2017 White Tundra Limited 4x4
    Ya its the taco knob, I don't like how long the tundra knobs are with the shift boot. It's fits on normally , just need a boot so it doesn't look funny.
    Bergy24[QUOTED] and reywcms like this.
  21. Aug 4, 2022 at 11:54 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Another AJT design door handle and trim panel. Now have all there parts
  22. Aug 5, 2022 at 2:18 AM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Been meaning to post this for awhile now, easily added 10hp to the 2020 Platinum thanks to our guy @Tundra234
    now I gotta find where I wanna put one on the ‘22 TRD Pro, thanks George!
  23. Aug 5, 2022 at 2:33 AM
    Nice! I added 5 hp to mine lol. Sprayed with matte clear. No more sun in the eyes.
  24. Aug 5, 2022 at 2:36 AM
    2020Platinum
    Patrick
    Northeast PA
    Lookin good!…hated that chrome…haha…I’ll let ya know where I decide to put your decals on the new truck, thanks man!
  25. Aug 5, 2022 at 4:38 AM
    PermaFrostTRD
    Northern NY
    Just matte clear turns the chrome around the shifter that dark? Or did you paint that first?
  26. Aug 5, 2022 at 4:40 AM
    He matte cleared the shiny black around all that stuff. The chrome was painted before that. The pics are direct before and afters.
  27. Aug 5, 2022 at 4:42 AM
    PermaFrostTRD
    Northern NY
    Ahhh got it. Makes sense. Looks good. Wonder how hard it is to get that silver piece off?
  28. Aug 5, 2022 at 4:49 AM
    Depends on which "silver piece" you are talking about. Lots of people call the matte silver around the whole shifter chrome, or silver, and then the shift gate gets called chrome or silver as well. The matte silver (two arrows in the pic below) just pops off with a pry tool, IIRC. The chrome shift gate (one arrow in pic below) requires cutting/breaking some plastic welds from the underside.
  29. Aug 5, 2022 at 4:57 AM
    PermaFrostTRD
    Northern NY
    Very helpful @GODZILLA thank you.
    I meant the “one arrow” chrome part. My bad. Looks like plastidip and some tape and #25 blade it is then.
  30. Aug 5, 2022 at 4:59 AM
    Don't give up too easy. Lots of people pop it off, paint it, and then glue it back in with no issue. AJT does sell a cover for it as well if you want easily reversible and don't mind spending a little money for it.
