  1. May 14, 2021 at 8:52 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I’m in Waxahachie, a relatively small town about 30 miles south of Dallas. When I made the police report, they said they were hitting Tundras and Priuses more and more all over the country.
    Someone else told me it’s the platinum inside them that makes them valuable. I had no idea they had platinum in them. With the price of metals increasing, I can see these kinds of thefts becoming more frequent.
  2. May 14, 2021 at 8:58 PM
    RobertD
    Robert
    DFW, Texas
    I knew you were Waxahachie just wasn't sure if thats where your truck was hit. I used to live in an apartment by the HEB. Sorry your truck was hit and I hope you get replacement cats quickly.
    equin[QUOTED] likes this.
  3. May 14, 2021 at 9:26 PM
    SAGE63
    San Diego County
    Yes they are...
  4. May 14, 2021 at 9:30 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    You need one of these now. Welcome to the club :thumbsup:
  5. May 14, 2021 at 9:38 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Are the slider plates actually touching the frame and welded to it, or are the welds between the frame and the sliders, which is what it looks like in your pics?
  6. May 14, 2021 at 10:01 PM
    beowulf
    beowulf New Member
    Dave
    2021 Toyota Tundra SR5 4WD Double Cab Long Box
    Boost Auto Tow Mirrors w/motorized fold upgrade
    Hey: Tundra newbie here. I’ve installed the Boost Auto tow mirrors too, and am now also trying to figure out how to tap into the cargo light circuit. Just wondering whether you finally figured out which wire to tap?
    Also, while I was poking around under the dash today, I think I shorted something because my sound system, charging ports, and display all went offline. I checked the “Radio” fuse under the dash, and it’s fine. So I looked at the engine compartment fuse box and couldn’t positively identify anything that relates to the sound/info system. There’s a big 30A item (fusible link?) that says “AMP” but I’m not about to do anymore guesswork. If you can point me in the right direction to troubleshoot that too, I’d really appreciate it. Thanks.
  7. May 14, 2021 at 10:07 PM
    SAGE63
    San Diego County
    The Rail supports are welded to the frame.
  8. May 14, 2021 at 10:14 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Not yet. I was looking over the wiring diagrams but ran out of time. I’ll spend some time looking again later this weekend.
    I am afraid I can’t help with the other issue. The electrical items are definitely not my strength. Hopefully someone else here can help.
    Also, welcome to the forum!
    beowulf[QUOTED] likes this.
  9. May 14, 2021 at 10:30 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Dan - The cargo lamp +12V on your truck is going to be pin 28 coming out of connector 3K from the main fuse/relay/ECU panel in the driver's side dash (it is pink on 2020-2021, and Lavender w/ Red Stripe on 2018-2019). Remember, the terminals are numbered based on looking at the PIN end of the connector, not the wiring end.
    You could follow that wire out along the wire gutter once you find it.
    Wallygator, a522467, GELCW and 4 others like this.
  10. May 14, 2021 at 10:33 PM
    Dsptundra
    Austin TX Area
    I think I owe you a few Great Notion beers! Thanks Casey!
  11. May 14, 2021 at 10:43 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Dave,
    There's a lot of different fuses feeding those various circuits, from ECU-ACC fuses that control relays to send/kill power to various things, to dedicated fuses (such as for the charging outlets), to an additional USB-specific fuse, to any number of other ECU fuses. There isn't a single dedicated fuse feeding anything in these trucks any more.
    I'd recommend hitting the wiring diagram collection thread and download all of the different PDFs that pertain to the 2021 truck. Start by reading the intro/how to stuff to understand how to read those diagrams, then start digging through the diagrams for each of the affected components and see which ones might be the affected fuse.
    In a quick look, you might want to confirm the 5A ECU-ACC fuse didn't get popped. It's in the cabin fuse box. Also check out the ECU-DCC No. 2 fuse (another 5A) in the same box.
    The 30A AMP fuse only pertains to trucks with a separate amplifier - not sure what radio you have in the truck. But that is one case where the fuse is specific to a single item (though that amplifier also has power from the 5A ECU-ACC fuse).
    Wallygator and beowulf[QUOTED] like this.
  12. May 14, 2021 at 10:44 PM
    carsonhudson
    carsonhudson New Member
    Nothing new. But she looked good while playing a round of frisbee golf today.
  13. May 14, 2021 at 11:00 PM
    equin
    Ed
    DFW, TX
    Thanks. Are you still in Waxahachie? I’m about 2/3 of a mile from HEB in some apartments behind Hobby Lobby and Tractor Supply. We’re here temporarily til our house gets finished.
  14. May 14, 2021 at 11:35 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    If I ever get my TRD OR wheels back from powdercoat you might be able to talk me out of them, they will be "triple bronze". For a negotiated price of course...:spending:
  15. May 14, 2021 at 11:39 PM
    Clemshady
    Jeff
    That is a heck of a trip. What we do for our kids huh? You sound like a great Dad. Drive safe.
  16. May 15, 2021 at 2:13 AM
    RobertD
    Robert
    DFW, Texas
    I do not, I'm north Fort Worth now. I was in apartments by the Civic Center. Congrats on the house!
  17. May 15, 2021 at 5:30 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Also, if this was an ask, I'm game to try. It'll mean a lot of hand holding - I'm not much with electronics, but I can turn a wrench. We can pull the convo to PM's if you want.
  18. May 15, 2021 at 6:42 AM
    beowulf
    beowulf New Member
    Dave
    That makes two of us. Thanks Casey!
  19. May 15, 2021 at 6:53 AM
    beowulf
    beowulf New Member
    Dave
    Thanks again Casey. I already know it’s not the ECU-ACC fuse ‘cause that’s the one my folding mirrors are tapped into and they’re working fine. I’ll definitely DL your wiring diagrams and have a look. It’s been a while since I’ve worked with electrical HW though, so I’m probably going to have to relearn reading those things.
    RainMan_PNW[QUOTED] likes this.
  20. May 15, 2021 at 7:11 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Finished surround today. Started out white. bulge started out chrome
    WFD473, Wallygator, Ostrich and 16 others like this.
  21. May 15, 2021 at 7:18 AM
    NIOSH
    NIOSH New Member
    2021 1794 CrewMax Army Green
    ELKA, 35", Harrop, lockers w 4.88
    For the Harrop tunes are needed for stage 1. And no tunes aren't out yet for stage two
  22. May 15, 2021 at 7:27 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Double check you didn’t knock a ground loose or forget to hook it back up. Unless you shorted something, a bad ground is a likely source of the problem.
    knock on wood, but in all the stuff I’ve done to this truck and all the similar stuff I did to my 2008, I’ve NEVER popped a fuse.
  23. May 15, 2021 at 7:28 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Dunno if I’d feel right experimenting on someone else’s truck, but when I do the right up for mine I’ll pull together the info on some ideas…
  24. May 15, 2021 at 8:18 AM
    RRR1C0
    RRR1C0 New Member
    2014 SR5 TRD CrewMax
    Riding on 275/70R18 Toyo AT3s w/ 1.75” RC leveling kit.
    Finally passed 60k on my 2014
    WFD473, Wallygator, Ostrich and 12 others like this.
  25. May 15, 2021 at 8:37 AM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    @RainMan_PNW - the great electrical wizard of Tundras - My 2020 Platinum has memory power folding mirrors. Currently, when I park I hit the button to fold my mirrors, turn off the ignition, then I hit the fold button again. Because the power is off the mirrors do not unfold but upon startup it "remembers" that I told it to unfold the mirrors and it does so automatically. How does it "remember" to unfold? On the four way mirror adjustment panel/switch my GS350 has an automatic button that does the auto-folding so I assume there is something in the door's ECU. Any reason that a Lexus ECU could not be substituted and make this work on a Tundra OR does it do other things (I call it things because I know nothing about ECUs) which would conflict?
    PNW_Husky likes this.
  26. May 15, 2021 at 8:43 AM
    1794TX
    Steven
    N.TX
    '20 1794
    :thumbsup:
  27. May 15, 2021 at 9:44 AM
    RainMan_PNW
    Casey
    Clark County, WA
    I’m far from a wizard. Just a hack that’s not afraid to short a few things in the interest of convenience.
    On the tundra memory mirror switch, does the fold button remain in a specific position? I.e. does it stay pressed in when folded and stay out when extended? Sort of like the clicker on a ball point pen? If so, then I think the same principal behind the Gen2 mod would work, but would require a separate relay in each door.
    As for swapping Lexus ECUs - that’s a gamble. I would have to find and compare complete wiring diagrams of ALL the functions each ECU handles (tundra vs gs350) as well as pinouts and even connector details. The internal wiring of the ECUs isn’t published, so figuring out the full function inside is a combination of logic testing and best guess.
    The auto button in the GS is sending a signal to the ECUs to perform the fold on power off as well as unfold on power on - i would also assume there’s a timer in there so the mirrors aren’t unfolding as soon as power starts. The logic is fairly simple but the details on how the ECU actually does it I’m not sure on. I’m not an electrical engineer. :D
    on the method i just did, you don’t have an “override” so the auto fold is always there. and the mirrors start to unfold immediately when the ignition starts - so they open a second until the starter engages, then stop until the engine starts and the system returns power to the rest of the truck.
    If i sat and thought through the logic a little more, I’m pretty sure I could come up with an override manual/auto selector - probably using a SPDT switch of some kind.
    Terndrerrr and PNW_Husky like this.
  28. May 15, 2021 at 10:43 AM
    SAGE63
    San Diego County
    Wallygator, Ostrich, jpod and 13 others like this.
  29. May 15, 2021 at 11:36 AM
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
    Bought the VLED brake lights and customer service said they would go right in and they don't. Does anybody know what adapter I need to add to this?
    3xYOTA, Jpd0144 and Toe404 like this.
  30. May 15, 2021 at 11:42 AM
    nmjameswilson
    James
    Kansas City
    I started the AJT interior dechrome... The shifter and cup holder is on the way.
    Ostrich, cutjob, nhw544 and 9 others like this.
