  1. Jul 26, 2020 at 11:47 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    I got same slide but added the top and bottom side bins. Love it.
    ElNopal, NAFlash and ezdog[QUOTED] like this.
  2. Jul 26, 2020 at 11:54 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    As already mentioned, cut off the bed liner with a knife. It will peel off.
  3. Jul 26, 2020 at 12:08 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Did you change out the side rails on yours?
    Mine are really thin and do not take any standard T-Nuts that I have found but the newer versions seem to have an option for the rails that look like yours?
  4. Jul 26, 2020 at 12:11 PM
    Emmadog
    Emmadog New Member
    2020 Tundra Dbl cab limited
    stock
    thinking of the same thing. would love to see a picture.
  5. Jul 26, 2020 at 12:24 PM
    mgm16trdpro
    Northern NJ
    Yes I did, bedslide sells a conversion package so you can take from what you have now and turn into mine if you desire. Keep in mind, the exact bedslide you have now is what mine looked like before I made change adding the packages. 1000 pro se as u can see in pic. I found a great deal on it.
    ElNopal and ezdog[QUOTED] like this.
  6. Jul 26, 2020 at 1:15 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Yeah I saw that it was the same Slide but it also does not have the stock rails.
    I have no need for the boxes or different rails that I can think if and honestly they would not even fit through the doors on my Cap either.
    They also pretty much look like they are about to break off all the time to me as they always angle towards the unsupported side
    I got the Slide for $250 and it has new bearings and a set of spare new ones too so I am pretty happy with it the way it is and if anything I will build something over the slide like another level for ladders or lighter storage.?
  7. Jul 26, 2020 at 1:59 PM
    mgm16trdpro
    Northern NJ
    Sounds like u got a great deal too. I got alot of weight in my boxes being mostly tools and so far they've held up great. Every once in a while I'll lift up on them and tighten them down a bit so they're not on any angle. I'm pretty sure if u wanted to customize it to your liking it's possible since it's wood. For me, it does what I need, which holds all my tools and gear in place. Especially with the bed cover it's nice not having to climb up in the back to get something. Good luck with yours.
  8. Jul 26, 2020 at 2:00 PM
    kwebre
    kwebre New Member
    2020 Blck Tundra
    4" pro comp suspension lift
    Thought I had made the decision to go with the OEM bed extender but need some advise. I will mostly be using the extender folded into the bed to keep all my hunting gear and 120qt ice chest from sliding around. What does the forum say? AMP U shape or OEM
  9. Jul 26, 2020 at 2:05 PM
    biebs96
    PA
    Parked behind my dad at his house... he copy catted me.
    same cab style, same bed cover, same window visors, same floor mats, same remote start.
    ElNopal, GAknight, Cosmoblu and 7 others like this.
  10. Jul 26, 2020 at 2:11 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    made some wanna-be pro center caps using stickers
    biebs96, ElNopal, GAknight and 8 others like this.
  11. Jul 26, 2020 at 2:29 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Thanks!
    I found your install pics and still am not sure that they are the same exact slide though they are named the same.
    Yours looks to have standard L-Track side rails mounted on the decking but mine are some odd undersized slotted track that I can not get a fastener into except for a few really thin sheet t-nuts with 1/4" holes.
    I will probably just mount standard half thickness Strut instead and then I can can build off of that as I would anything else.
    Like I said I cant really mount anything outside the width of the decking as my doors only barely pass the deck itself and sure would not let anything wider go by!
    I also have this which I got with a different Slide that I found first and am not sure if I will adapt it to the Bedslide or not yet?
    Not sure it will be worth the weight penalty for the organization though it is also only 6.5' long on my 8' slide and would make for interesting storage for sure.
    Fotnot and mgm16trdpro[QUOTED] like this.
  12. Jul 26, 2020 at 2:31 PM
    PrivateMcMuffun
    PrivateMcMuffun New Member
    Devon
    2019 White Tundra TRD Pro
    Today I got around to installing a two-way rear differential breather after my fluid was tainted from a mysterious puddle that ended up being a lake.
    I'm sure this could have been done with $10 and a trip to the orange store, but I went the clean route of buying ARB's breather kit on amazon. It came with enough tube and fittings to do my front dif and my transfer case, even though those already have breathers.
    Unlike everything else I did to my truck, this one was actually a 15 minute job. @BlueBottle made a pretty good write-up in case you are interested in not have a leaky rear ;)
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Elfine, GAknight, kleiker0303 and 4 others like this.
  13. Jul 26, 2020 at 4:52 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Add the rear window ventvisor. Converted it from outside channel to inside.
    Tundra805, ElNopal, Cosmoblu and 8 others like this.
  14. Jul 26, 2020 at 5:20 PM
    mgm16trdpro
    Northern NJ
    That's what I was trying to say. The corner caps on the front and the rails that mount to the sides and back of the actual slide I put on after removing the same thin metal side rails that you have. Bedslide sells it as part of a kit, think it might be called a conversion kit, if I remember correctly. But yeah mine looked just like yours when I 1st got it. I then removed the side and rear thin black metal like you have on. I then installed the sides and rear what looks like L track around the same slide. After that I cut to size the rails then mounted bins, finished off with the front corner black caps that pop onto corners. I'm pretty sure they're exactly the same with the exception of length since I got crewmax.
  15. Jul 26, 2020 at 5:30 PM
    mgm16trdpro
    Northern NJ
    Here you go, I looked it up for you. It's the retro fit rail kit. It's basically L track that surrounds the sides and rear that you can then mount the newer rails to side and rear with tie downs and such. Hope this helps.
    GODZILLA likes this.
  16. Jul 26, 2020 at 5:39 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Very nice! I also did mine today with the ARB in the driver taillight.
  17. Jul 26, 2020 at 6:01 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Thanks now I understand better what you are talking about.
    I find their website pretty frustrating and I can rarely tell if I am looking at anything compatible at all?
    I am never going to get that kit though as it just gives me nothing that isn't already there really and since I can not use the boxes anyway there is just no utility in it for me for the price.
    I am going to mod mine with standard UniStrut like I do everything else for $50 and get something thats exactly what I need and a lot stronger too!
    Or I am not going to change anything and see how it works like it is before changing it.
    Or I am going to mount that giant box that I already have on it and then mount strut to that?
    Options are good thing!
    Thanks Again
    mgm16trdpro[QUOTED] likes this.
  18. Jul 26, 2020 at 6:49 PM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    Wife got me a center console organizer for my birthday last week. To use it, required me drilling out the existing rivets. I drilled out about 3 or 4 before saying hell with it and went got a sharp, flat head and a rubber mallet and just gave them a good tap. Hell of a lot less messy than metal shavings everywhere.
  19. Jul 26, 2020 at 6:56 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Been feeling patriotic so I pulled the trigger on a rear window flag. Middle slider was tricky but everything turned out great!
  20. Jul 26, 2020 at 7:11 PM
    Looks good. :thumbsup:
    Is the Charger a personal car or work car?
    Clemshady[QUOTED] likes this.
  21. Jul 26, 2020 at 7:11 PM
    NoCoToyo
    NoCoToyo New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    Thanks brother! Yeah I NEED those for sure, thanks for posting!
    What lift you running BTW?
  22. Jul 26, 2020 at 7:13 PM
    Clemshady
    Jeff
    Thanks! Work. Less than 8 to go brother.
    Blueknights75 and LyonKing like this.
  23. Jul 26, 2020 at 7:13 PM
    ;) Stay safe.
    Clemshady[QUOTED] and LyonKing like this.
  24. Jul 26, 2020 at 7:22 PM
    Clemshady
    Jeff
    Thanks. You do the same.:thumbsup:
  25. Jul 26, 2020 at 8:19 PM
    Will1606
    Will1606 New Member
    Will
    NJ
    2019 TRD DCLB
    :oldglory:
  26. Jul 26, 2020 at 9:55 PM
    ttime4four
    ttime4four New Member
    West Linn, OR
    '20 Tundra Limited DC TRD Offroad
    Huper Optik Ceramic i3 tint all around plus 56% on the windshield. While I've always tinted my windows on my vehicles, this is the first time to do the windshield. I'm very pleased with the overall performance.
    ElNopal, GAknight, junior and 12 others like this.
  27. Jul 26, 2020 at 10:06 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    I dig those minor details.
  28. Jul 26, 2020 at 10:12 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Thankyou both for your service. :oldglory:
  29. Jul 26, 2020 at 10:31 PM
    Lugnuts2020
    Lugnuts2020 New Member
    2018 crew max
    Pulling the whole bumper is without question much easier! Not that it helps you at this stage!
    silverhack and ttime4four like this.
  30. Jul 27, 2020 at 4:56 AM
    :hattip:
    NewImprovedRon likes this.
