ARB diff breather - install guide
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueBottle, Dec 28, 2017.
  1. Dec 28, 2017 at 10:31 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Every truck that may have a chance to do any water crossings should have this mod done.
    Our trucks has a one-way breather on the diff itself. Which means if the diff ever gets submurged under water, your diff/axles become a pressurized system and If there’s any kind of vacuum while under water, you would suck in water into your axles, etc. there is a mod to extend the stock breather but that still leaves you with a one-way breather that can cause water to seeP in through axle seals.
    So saw the ARB kit and thought, well these guys builds lockers so they should know what’s good for diffs! I went ahead and purchased the kit not knowing if it would fit our diff bolt on.
    The kit I purchased. It includes everything needed for the install including ARb zip ties! Purchased it from here http://toyteclifts.3dcartstores.com/ARB-170112--ARB-Differential-Breather-Kit_p_1504.html
    ARB 170112 - ARB Differential Breather Kit
    Tools needed
    • Wire cutters
    • 2.5mm Allen wrench(to install plugs)
    • Plastic pry tool(to remove tail light)
    • T-30 socket(to remove tail light)
    • 13mm ratcheting wrench(tighten arb fittings)
    • 14mm deep socket(to remove stock breather)
    • Blade(to cut tubing to length)
    It ptetty straight forward. Remove stock breather. Install ARB connector which is already prepped w Teflon tape. Just snug it tigh when it bottoms out. Do not overtorque it. Run you air line giving enough slack for suspension travel. Use zip ties as needed and I ran it inside the frame rail up into the drivers tail lamp. Be careful w the tubing as it doesn’t like sharp bends and kinks easily. Use big radius bends as much as possible. The tubing just snaps into the connector when you push it in. It is air/water tight. I zip tied the unit behind the tail lamp and the tail lamp clears it when put back together. Don’t forget to plug the other ports you don’t use.
    Done! You now have a diff breather to keep your diff fluids cleaner longer.
    B0FE8A08-9FB5-4BA0-864C-BA8BB0025E44.jpg DC4FD9C6-6CD0-4F3D-A4B4-20A10CF8F337.jpg FE43CD88-64DE-4923-8655-186A98B1F34F.jpg A3C89BD5-B83F-49B3-BE62-1D3906912529.jpg 65ACF637-ADBF-4368-89E0-E09E4AD4C004.jpg 9931040F-A50F-4293-978F-4882022FD8C0.jpg
  2. Dec 28, 2017 at 11:42 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Reminds me of my old Titan. Titans had/have an issue with the rear axle seals leaking, and most of us did a similar mod. The fix, just like this, was to run tubing from the axle vent up into the rear tail light housing, then install a small fuel filter on the end. For about $10-$15 worth of parts it was more than worth it to prevent leaking axle seals.
    I wasn't aware our Tundras had a similar issue, so this is good to know. :thumbsup:
  3. Dec 28, 2017 at 11:56 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I don’t know if they do either! Just a precautionary measures. I’m sure you can use the toyota union, some fuel lines and a filter just like you said to save some coin. Essentially does the same thing which is give you a two way breather above the water line. If you have water above your tails you are in trouble!
  4. Dec 29, 2017 at 12:02 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  5. Dec 29, 2017 at 12:09 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I got this from the ARB site....
    A differential / axle breather serves the important purpose on a 4WD vehicle of venting the air pressure in drivetrain assemblies such as the differentials, transmission and transfer case. Under normal operations, these assemblies heat up and the air inside expands, increasing the pressure and thus the need to be vented to the atmosphere is created. When the drivetrain assembly cools down the air inside contracts and creates a vacuum.
    Many drivetrain assemblies are fitted with a breather from the factory. These factory breathers are usually a one-way valve mounted directly to the housing or remotely on a short tube. The shortfall with the factory breathers is that driving through water crossings creates a vacuum caused by the drivetrain assembly being cooled rapidly by the water. This vacuum will tightly close the valve shut causing air to be instantly drawn into the assembly through the seals. Many times the seals are still submerged below water, leading to the water being drawn into the drivetrain. This will contaminate the oil and possibly damage drivetrain components or your Air Locker.
    The ARB Differential Breather Kit is designed to eliminate these shortcomings by providing a high flow, zero back pressure, zero vacuum breather system. This is achieved with a high flow air filter within a central manifold that will allow up to four drivetrain assemblies to be vented to one central location, ideally somewhere on the vehicle that will be above the water level at all times. This kit is intended to replace your factory breathers and contains enough fittings and tubing to connect at least two drivetrain assemblies. More tubing and push-in fittings can be purchased separately to connect up to four assemblies to the central manifold (Part Number 170113).
    @BuckWallace
  6. Dec 29, 2017 at 12:10 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yep, did the breather mod. But the ARB is really clean.
  7. Dec 29, 2017 at 12:11 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    joonbug[QUOTED] and dcsleeper408 like this.
  8. Dec 29, 2017 at 9:19 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    aperezsh and dcsleeper408 like this.
  9. Dec 29, 2017 at 10:33 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I bought the parts listed in one of the DIYs here and installed it a long time ago. It's clean but your ARB looks even cleaner. Sometimes the creek below me will flow over the road in 4 locations. (not this year) I haven't seen much more than a foot of water but it's such an easy and inexpensive mod, I did it for peace of mind. I put split loom over the hose for abrasion protection.
  10. Dec 29, 2017 at 10:59 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Do you remember who wrote up the DIY? :rolleyes: It was probably Mark’s.
    That mud pit we dropped into counts and that was at least 3 feet deep at the deepest. Here’s about 3 feet of water at Mojave.
  11. Dec 29, 2017 at 11:02 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Make sure you used the front breather part that Mark provided and not re-use he one way from the rear diff.
    dcsleeper408 likes this.
  12. Dec 29, 2017 at 11:04 AM
    I went with the ARB breather. Your breather is located exactly where I attached mine..:thumbsup:
  13. Dec 29, 2017 at 11:05 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Great minds think alike!
  14. Dec 29, 2017 at 1:03 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Have you checked/cleaned your filter yet? Wonder how often to do it.
  15. Dec 29, 2017 at 2:02 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wait, why? I reused the one from the diff.
  16. Dec 29, 2017 at 2:11 PM
    Haven't been in any deep water yet.
  17. Dec 29, 2017 at 2:25 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Read what I posted. One way vs two way.
    Post #5
  18. Dec 29, 2017 at 2:33 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    You probably should check your diff fluid now. :eek::mudding::itllbuffout:
  19. Dec 29, 2017 at 4:15 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    Thanks for the nice post. I have had the ARB kit for awhile now but I have not gotten around to installing it. It's on my list with all the other stuff I need to do.
  20. Dec 29, 2017 at 5:47 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    It’s pretty straightforward. Took me under an hour. Didn’t need to drop the spare either. Just be careful with the lines as they don’t like to be bent.
    Otaku4life69[QUOTED] likes this.
  21. Dec 29, 2017 at 7:18 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Ouch! I know it's not a cheap fix if you have someone do it. I got lucky and never had any leaks on either of my two Titans--the breather mod may have prevented it. Cracked manifolds, on the other hand...
    SouthBoundSteve likes this.
  22. Dec 29, 2017 at 7:52 PM
    Munk
    Munk Vol For Life
    Mickey
    Bristol, Tennessee
    2017 Black SR5 Tundra Crew Max
    3/2 Lift
    So do you need one for the front as well?
    TheBeast likes this.
  23. Dec 29, 2017 at 9:44 PM
    TheBeast The Beach
    I was gonna say the same. line can probably be routed to the rear breather since it has multiple inputs
  24. Dec 29, 2017 at 9:54 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    The front is already in the engine bay and I believe it is a 2 way valve. You can tie it into the arb if you really want though. Might be best to install the arb unit and run the rear to the front instead though.
    Black Wolf and Munk[QUOTED] like this.
  25. Dec 29, 2017 at 10:11 PM
    Munk
    Munk Vol For Life
    Mickey
    Bristol, Tennessee
    3/2 Lift
    Thank you sir.
  26. Dec 31, 2017 at 5:16 AM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Looks like something I may pick up. Website says you need to tie in tranny and transfer case. Anyone know where the vents are on those?
  27. Dec 31, 2017 at 5:27 AM
    I believe only rear diff wasn't connected to a breather.
    BlueBottle[OP] likes this.
  28. Dec 31, 2017 at 8:42 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You're right, looked up the the DIY I used for parts and it was Mark's. Thanks, yet again @dcsleeper408.
  29. Feb 5, 2018 at 3:19 AM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Nice write up! Adding to my list for sure, ARB is just too clean to pass up :thumbsup:
  30. Feb 5, 2018 at 5:34 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Did this mod on my Titan and my Tundra. I did it both times the cheap way with a fuel filter.
    BuckWallace[QUOTED] likes this.
