  1. Jun 3, 2021 at 11:48 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    You got a link for these?
  2. Jun 3, 2021 at 11:51 AM
    Richid
    Richid New Member
  3. Jun 3, 2021 at 11:52 AM
    Professional Hand Model
    Hand Protectors
    Got them from a site aka big gurl. These are everywhere online in the $7-12 Range. Be careful of the trickery on fleebai. Both sites actually. Make sure you order one pair and not two. Also, watch the lead times trickery.
    I wanted the black ones but they only are sold with the double paired pack so ended up with silver.
  4. Jun 3, 2021 at 11:55 AM
    Hand Protectors
    Removed the Handle and ‘punched’ the inner rod out with the provided removal rod and some light hammer taps. Everything else is a press job using the Large Channel Locks with the press rod. Press on. Press off. Carefully.
    Richid[QUOTED] likes this.
  5. Jun 3, 2021 at 2:19 PM
    Hand Protectors
    @bmf4069
    You can order some SheepSkin for your motorbike seat. At least get some for your gurlfren. Its therapeutic.
    Voss, FrenchToasty and bmf4069 like this.
  6. Jun 3, 2021 at 2:24 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Might help soak up all the gooch juice.
    Voss, CodyP and abcinv like this.
  7. Jun 3, 2021 at 2:26 PM
    Hand Protectors
    There is a Natural Lanolin Quality about these... another therapeutic benefit.
    CodyP and FrenchToasty like this.
  8. Jun 3, 2021 at 2:43 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Damn! They now come with an extra pin??? Mine did not, but I got mine 2 years ago.
  9. Jun 3, 2021 at 3:04 PM
    Hand Protectors
    Its a push pin.
  10. Jun 3, 2021 at 3:08 PM
    Jack McCarthy
    Bill
    North of Boston
    Missed that in your instructions earlier. I think I have a punch pin set; if not, I guess it's a trip to Harbor Freight.
  11. Jun 3, 2021 at 3:11 PM
    Hand Protectors
    You could probably find a properly sized nail and cut it into a push pin.
  12. Jun 3, 2021 at 3:21 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    By Southern California standards if you can't smell what your neighbors are cooking, you are in a rural area :rofl:
    If I sneeze my neighbor says bless you.
    NomadicFrog, NUDRAT, bmf4069 and 3 others like this.
  13. Jun 3, 2021 at 3:26 PM
    hammeron
    hammeron New Member
    2002 Tundra v8 Blue 2wd
    Check Engine Light came on earlier this week, pulled over and hooked up my OBD reader, P0161.
    Got home looked it up, logged on to Rockauto and ordered a Denso. Received it today, laid down
    some cardboard and slid under.
    Old one out, nickel anti seize on the studs and new one on. Could not be easier.
  14. Jun 3, 2021 at 3:29 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I think they might even be able to hear me flick my bic
    I often wonder anyways
  15. Jun 3, 2021 at 3:38 PM
    Jack McCarthy
    Bill
    North of Boston
    In certain Boston neighborhoods and the surrounding area where the triple deckers are located, if your neighbor enters your apartment, you may have left your window open.
  16. Jun 3, 2021 at 5:28 PM
    Azblue
    The Dirty T ( ^_^)_且
    I bought a set of those a few years ago and only ended up installing 1. If I can find the other one, I'll ship it to any of of you guys that need it. I'll update if I find it.
  17. Jun 3, 2021 at 5:31 PM
    Hand Protectors
    Nice! Might not be worth the shipping because they are so cheap and break in pairs. They look like they might make a good single earring, though.
    Voss and Azblue[QUOTED] like this.
  18. Jun 3, 2021 at 7:12 PM
    lc69hunter
    lc69hunter New Member
    Don
    2001 Black Tundra SR5
    gooseneck hitch, trailer brake
    OK, oh wise ones. I just spent 2 hours trying to get a rusted drum off. Sprayed PB blaster on it before I quit tonight. Unless someone has an easier idea, what I plan to do tomorrow. Put the truck on jack stands, loosen the rear lugs so that the wheel is not up against the drum, and then pop it into drive, and then reverse several times. The lugs have enough play that they may break the drum loose. What say you?
  19. Jun 3, 2021 at 7:25 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    I would recommend something I learned. Mix equal parts transmission fluid and acetone. It is incredibly effective at breaking rusted parts loose. Only prepare what you need at a given moment though because the acetone evaporates very quickly.
    NUDRAT likes this.
  20. Jun 3, 2021 at 7:25 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Nyet. Adjust the shoes in, and tap around the drum with a hammer. Go around the back a couple times, then the front a couple times. Or a small bottle jack between the spring and drum, and tap the other side.
  21. Jun 3, 2021 at 8:09 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I've seen the guy with the truck spray painting the brown lawns green out there.:rolleyes:
  22. Jun 3, 2021 at 8:57 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    After posting last night about finding time to do something to my truck... I swapped front sway bars.
    Apparently 03+ uses a 27mm front bar, 02 and older are 23/24mm. I put a 28mm one I grabbed from a Sequoia with a sunroof. Balanced out the front feeling a bit squishy with the rear sway bar I added previously.
    I also borrowed the A/C machine to check my system (was not staying cool at idle). After 16-17 years she was .6lb low.
    chrisb, Voss, NUDRAT and 5 others like this.
  23. Jun 3, 2021 at 9:19 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Anybody here ever replace their windshield themselves? There are very few reasons I’d ever let someone else’s tools touch my truck, but this is one of them. I’m not scared, it’s just the cost vs. hassle. The only reason I am contemplating it is because I have a minor rust issue under the windshield seal itself, and I know any windshield guy will just put the new seal right over it and for damn sure isn’t gonna sit and wait while I do whatever it is I decide needs to be done once I see it. I may remove it, fix it, then just have it installed, but at that point, seems like I might as well just install it myself. Make sense to anyone else? I might add, the rust is what actually cracked the glass in the first place, and if it happens again I’ll
    be kickin myself. Yup. Just talked myself into it so...... yeah, anybody here ever.....?
    onesojourner likes this.
  24. Jun 3, 2021 at 9:22 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I've removed them, never installed though. I would contact the glass company you're going to use and ask if they can remove the old one (for whatever the cost is) and then at a later date install one for you.
  25. Jun 3, 2021 at 9:26 PM
    Jack McCarthy
    Bill
    North of Boston
    I have the same issue with rust right along the top where they put in the cheap gasket replacement. I wouldn’t be surprised if the rust is their handiwork since they’ve replaced 3 of my windshields and that’s the only area of rust.
    NUDRAT likes this.
  26. Jun 3, 2021 at 11:31 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It’s fucking ghetto looking. But forthe first time in 1 3/4 years, I have a complete interior. All to hopefully have a peaceful rattle free 10 hour trip Sunday
    1Silverback, chrisb, JustJake and 9 others like this.
  27. Jun 4, 2021 at 4:18 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I assume I would be frowned open to pee off the front porch here?
  28. Jun 4, 2021 at 4:19 AM
    Hand Protectors
    Call them out to do the job in your driveway. Be prepared to step in with the proper primer and rust clean. There is a Quick Dry Rust Stop Shpray the window guys use. Maybe look that up and have it ready.
    If you have a big rust problem them DIY is best. Small problem let a window company do it and step in for quick Feather Dust Repairs. Under $300 in my driveway with Safelights.
    RUSTYNUTS[QUOTED] and bmf4069 like this.
  29. Jun 4, 2021 at 4:56 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I wouldn't mess with it. 1 wrong step and you just wasted a windshield. What if you pull it and fix what needs fixin, then have them install? You might call around and see if they'll do that.
  30. Jun 4, 2021 at 5:02 AM
    Hand Protectors
    Yeah. Assassin had a good idea above. I think another member did the same and had the company pull the glass and return later after repair.
    RUSTYNUTS likes this.
