  1. May 27, 2021 at 1:54 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats a different topic.
    Sirfive[QUOTED] likes this.
  2. May 27, 2021 at 1:58 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I didnt realize how pinched the y pipe is. Sequoia is different. Maybe theres enough pulse to scavenge at the y, but think id prefer to run true duals with an x once i figure out who to sell my cats to.
    i would like to see an apples to apples between an x pipe and this.
    i doubt it would be worth the extra weight.
    Thrussn likes this.
  3. May 27, 2021 at 2:47 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I agree with everything darkness said.
    My 3" cat back sounded better than stock, but the exhaust scavenging is affected so much that the trans thinks it has to downshift on the slightest hills. I definitely regret buying the catback I have for that reason alone. That downshifting correlates more to throttle position and engine output more than o2 sensors. I would imagine a bottleneck at the end of an exhaust plays a more of a role with pressures and scavenging than it does temperature. It's really neat to know that exists though.
  4. May 27, 2021 at 3:48 PM
    Professional Hand Model
    Hand Protectors
    Truck has been driving great. No CEL from Short Header install a few weeks back. She sounds and runs Smooovvv. I'll be doing some longer drives soon and see how the MPG is doing with the New Headers.
    Voss, Glock 40, Thrussn and 6 others like this.
  5. May 27, 2021 at 7:23 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    who knows. but i'll try it if i can find some used.. it looks pretty. lol
    KarmaKannon likes this.
  6. May 27, 2021 at 7:54 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats a weird design there. Can't say I've ever seen that.
    Thrussn likes this.
  7. May 27, 2021 at 7:59 PM
    empty_lord
    05 rollover special
    Newer thing from borla. Only for mustangs as of now as a resonator delete. Supposedly 5% better flow than a traditional x pipe
  8. May 27, 2021 at 8:02 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I think its supposed to spread the pressure waves out.
  9. May 27, 2021 at 8:17 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I can imagine that section can handle more flow than a standard X since it has twice the pipe and no intersection but once you add pipe before and after I bet there is no benefit. Interesting design though.
  10. May 27, 2021 at 8:35 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Also 4 vortexes instead of basically 2 with a xpipe. Vortexes don’t help flow
    Darkness[QUOTED] likes this.
  11. May 28, 2021 at 3:07 AM
    empty_lord
    05 rollover special
    Collectors help the flow. At least in theory
    The mustang crowd has seen gains.
  12. May 28, 2021 at 4:30 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    One thing i forgot to mention yesterday, is a 4.7l engine running at 10% throttle is moving air more like a 470cc engine. Its not an exact analogy, but youre in the ball part. Which is how the vvt or vvl does its thing... if it takes 15hp to hold 60 mph, and you can make an engine make 15hp at WFO, you’ll have less pumping losses and be more efficient.
  13. May 28, 2021 at 4:37 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Today is oil and plugs day. The closest autozone didnt have iridium, so i got ngk platinum. Autozone guy said stock was copper, anyone know if beefier coils have been made? Pretty sure i did plugs 10 years ago or so, so it might have iridiums in it, just curious.
    bmf4069 likes this.
  14. May 28, 2021 at 6:59 AM
    empty_lord
    05 rollover special
    Stock is platinum on the VVTI motors if i remember right MSD sells coils. But no one has tested to see if spark is strong that the oems. Toyota’s COP setup has pretty strong spark as it is
    Sirfive[QUOTED] and oscardog86 like this.
  15. May 28, 2021 at 7:05 AM
    Hand Protectors
    Yeah. I’m using Copper NGK Plug ($1.50) with the New Denso Coils ($54). Smooovv.
    Copper Plugs don’t last as long but it seems they spark nicely.
  16. May 28, 2021 at 9:50 AM
    Orange devil
    Orange devil New Member
    1genjunky, NUDRAT, chrisb and 10 others like this.
  17. May 28, 2021 at 10:46 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats a tall boy. Looks good.
  18. May 28, 2021 at 1:02 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Nice work! I need to remove front and back pumpkins for a regear... how difficult as it to remove?
    des2mtn likes this.
  19. May 28, 2021 at 4:38 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Should be as easy as sliding the axle shafts out, pulling the drive shaft, and unbolting the third member. This depends on how grooved out your drums are and how crusty the adjusters are I guess. That would be my biggest worry. Seems like a good time to go sequoia discs no?
    NUDRAT, chrisb and Voss[QUOTED] like this.
  20. May 28, 2021 at 4:53 PM
    Voss
    2003 AC TRD 4x4
    Thanks. Sequoia discs?... I was just thinking I should ask you all if there’s maintenance/upgrades I should do while I’m at it.
    Edit: you mentioned sliding axels out, I’ve read a few times where the rear axel seal? starts leaking if I’m not mistaken. This is what clicked in my brain that led to me realizing there’s work I can do while I’m removing the diff. Am I right about changing axel seals?
    appreciate you all
    des2mtn likes this.
  21. May 28, 2021 at 5:13 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    No need to pull drums. Disconnect park brake cable, remove 4 nuts, slide axle out a bit to disconnect brake line and cap it with a vacuum cap. Pull axle out with drums complete. Best to drain the diff first of course.
    NUDRAT, Thrussn, Darkness and 2 others like this.
  22. May 28, 2021 at 5:45 PM
    KarmaKannon
    Utah
    Some junk
    Supposedly first gen sequoia rear discs bolt right up. I think it's just taking everything from the axle housing out off the sequoia and bolting it on the tundra. Brake lines and e brake cables I don't know. I haven't heard anybody mention swapping axle shafts so I assume they work too. It's on my list because my rear brakes are in an unknown condition. I think I had the drums off once and I've adjusted them a couple times, but I'd rather go to discs than even put new shoes on drums. The parts from a u-pull yard should only be around $100-200 and if I can find one with decent looking rotors I'd probably just run them. Maybe with new pads or maybe give it a try with the used ones if they look alright. Wouldn't be the first time I've used u-pull brakes on my vehicle.
    oscardog86, NUDRAT, chrisb and 2 others like this.
  23. May 28, 2021 at 5:49 PM
    empty_lord
    05 rollover special
    the discs do not bolt up. The axle hub bolt pattern is different. You need the whole axle housing
  24. May 28, 2021 at 5:50 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I thought about it, still thinking about it, but somewhere i found backing plates to mount 13wl discs/calipers, and i cant find that anymore... post #13 kinda talked me out of it, but not completely.
    Voss likes this.
  25. May 28, 2021 at 5:52 PM
    KarmaKannon
    Utah
    Some junk
    Per posted link. I think this is what I saw before.
    "You will have to
    replace everything outboard of the
    axle tubes. The axles are the same for the Tundra and Sequoia. When you
    have removed everything
    needed for the conversion you will be left with the differential housing
    and the splined ends of the axles exposed.
    You will need R and L caliper mounting brackets, R and L calipers, R and L
    disc rotors, bearings, brake
    pads, custom fabricated brake lines (to reach the calipers in the new
    position) and a brake proportioning
    valve (available at most performance shops).
    If you have four wheels ABS you will need to modify the ABS wiring to reach
    the sensors in the new location."
    Edit- tag discs
    Voss and des2mtn like this.
  26. May 28, 2021 at 5:54 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    SOS Performance disc swap in the rear with Powerstop parts. F*** the instructions though. Rear discs is my favorite upgrade on my truck by far.
    oscardog86, bmf4069, chrisb and 2 others like this.
  27. May 28, 2021 at 6:03 PM
    Voss
    2003 AC TRD 4x4
    Thanks all, def will be looking into the sequoia swap.
    des2mtn and KarmaKannon like this.
  28. May 28, 2021 at 6:10 PM
    des2mtn
    Shady Grove
    Tonto cover
    Wheel with me when its done!!!! The SoCal shenanigans crew missed ya'll this weekend.
  29. May 28, 2021 at 6:11 PM
    empty_lord
    05 rollover special
    OH the sos conversion? Uses fj calipers now. That’s a different story. But I thought you meant using sequoia backing plates and all. That won’t work
    NUDRAT and des2mtn like this.
  30. May 28, 2021 at 6:19 PM
    KarmaKannon
    Utah
    Some junk
    Crazy. From the posted link it sounds like the guy used all sequoia stuff. That's also what I'd seen elsewhere. Maybe it's all fake news.
