  1. May 24, 2021 at 12:28 PM
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    The shocks and coil overs are the Aluma series from toytec, and then I have 3 leaf add a leaf packs also from toytec and the one everyone knows about total chaos upper control arms lol. I’m almost 200k miles in with the original suspension and about 50k with a 2 inch spacer. So now I can finally replace majority of it and hopefully the ride will be better
    abcinv and chrisb like this.
  2. May 24, 2021 at 12:36 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Let us know how it rides. That seems like a great formula for when i want to step up to 33’s or 35’s
    potoghi likes this.
  3. May 24, 2021 at 12:55 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Fixt
    Darkness, bmf4069, NUDRAT and 3 others like this.
  4. May 24, 2021 at 12:58 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Get out the saw!
  5. May 24, 2021 at 3:29 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Oil change today. Still find this dipstick to be the most difficult I have ever encountered to get a good reading from. Next time, I am going to measure out the 6.5 qts.
    I used to be a real idiot on a sport bike. Last bike was a tracked-out sv650. Not much power for that engine size as it is a v twin, but with hotter cams, reworked needle jet/jet needle, penske double in the rear, complete gsxr front end with reworked internals: it was an absolute blast in the twisties. Now, I am the old man in the truck yelling at the bikers going up the mtn just like I used to...life is a trip.
  6. May 24, 2021 at 6:17 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I just went six to midnight.
    Darkness, bmf4069 and FrenchToasty like this.
  7. May 24, 2021 at 6:39 PM
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    For sure! I should have them installed either this weekend or early next week
  8. May 24, 2021 at 7:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Tore open my ECU today to see if these VVTI ecus have programming ports... and im happy to say, yes. they indeed do.
    SO there is tune ability to these. now to figure it out.. im going to source a used ECU and give it to my friend to see what he can dig through and see. maybe unlock more power?
    technically you can mess with most anything on the ECU with these ports if you know how to read the data. Rev limit, RPM. remove codes. ETC. but its all in hex.
  9. May 24, 2021 at 9:22 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Neat. Possibly improvement in gas mileage if these run extra safe/rich. Haven't tried looking at afr's when driving yet.
    Maybe speed limiter go bye bye?
  10. May 24, 2021 at 9:24 PM
    empty_lord
    05 rollover special
    you can modify ALOT. on the 3.5 they get higher rev limit, mess with fuel mapping. (the 3.5 is actually mapped up to 150% air volume... so they can take boost surprisingly well) VVTI angles... remove codes... ETC
  11. May 24, 2021 at 9:30 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Does it use a standard JTAG interface or something else like I2C or SPI?
  12. May 24, 2021 at 9:31 PM
    empty_lord
    05 rollover special
    that is a question im not capable of answering. i have a buddy that messes with this stuff. all i know is all the data is HEX.
  13. May 24, 2021 at 9:34 PM
    empty_lord
    05 rollover special
  14. May 24, 2021 at 9:37 PM
    Jack McCarthy
    Bill
    North of Boston
    Darkness and empty_lord[QUOTED] like this.
  15. May 24, 2021 at 9:38 PM
    empty_lord
    05 rollover special
    you know much more than i.. i just do the mechanical stuff and wiring.. i cant understand these fancy computers...
    yet.
    i do know that the photo i found of an 02 ECU Shows its the old style NON FLASHABLE setup
  16. May 24, 2021 at 9:45 PM
    Jack McCarthy
    Bill
    North of Boston
    Haha...yeah soon you'll be servicing electric motors, batteries and computers only.
    Non-flashable? So the configuration is burnt into the device? I don't see a UV erasable EPROM so that's what I'm thinking.
    Darkness likes this.
  17. May 24, 2021 at 9:50 PM
    daveeasa
    David
    Crushing my dreams right there :)
    However, might I ask what things might you want to change with a flash?
    AH, I see, more power is what you seek? No SC for you?
  18. May 24, 2021 at 9:50 PM
    empty_lord
    05 rollover special
    im not sure how its done. he knows way more than me. but the reason all the old school toyotas are impossible to modify 04-06 the transition to the new (now actually last gen as of a few years ago) ECU construction
  19. May 24, 2021 at 9:52 PM
    empty_lord
    05 rollover special
    if you mess with the fueling and VVTI angles, timing, ETC. you can squeeze more power out of your mods.. i bet theres an extra free 10hp to be found with some tunning from long tube headers.
    also. i could get rid of the air injection system without any physically obvious mods.. just completely kill the system
    NUDRAT, chrisb, bmf4069 and 4 others like this.
  20. May 24, 2021 at 9:53 PM
    daveeasa
    David
    It'd still for sure be ROM, just maybe not EPROM right? I'm thinking the EPROM vs ROM cost differential may have still been a margin into the early 2000's. Memory chips were super expensive in the late 90's, then the prices dropped through the floor.
  21. May 24, 2021 at 9:54 PM
    daveeasa
    David
    So that nobody thinks your cement grey 1st gen is modded? They assume it must be stock? :)
  22. May 24, 2021 at 9:56 PM
    empty_lord
    05 rollover special
    i just dont want that system to cause my emissions issues!
    but i also dont want to have to repair it.... when it fails.. because $$$
  23. May 24, 2021 at 9:59 PM
    Jack McCarthy
    Bill
    North of Boston
    Not necessarily, some of the early PLDs had fuse technology that were burnt in electrically to create the configuration. You could be right about it only being a ROM since I don't see a EPROM chip with a window to erase it with UV light.
  24. May 24, 2021 at 10:01 PM
    empty_lord
    05 rollover special
    to add. the hewitt kit works, but only if your system fails a certain way.
    onesojourner likes this.
  25. May 24, 2021 at 10:14 PM
    daveeasa
    David
    I haven't touched hardware in decades but top right ESPC looks like the cpu and then there is the crystal for timing. The big square in the bottom right could be the programmable chip for all the code? Outside of that, only 4 other chips are of any substance on that board, 300, 700, 701, 800.
  26. May 24, 2021 at 10:15 PM
    empty_lord
    05 rollover special
    CN200 is what he uses i believe. but thers cn100 too. those are the two "pinouts" i could see
    im going to find a used ECU and let him have it to mess with in his free time
    daveeasa[QUOTED] likes this.
  27. May 24, 2021 at 10:36 PM
    daveeasa
    David
    Yeah, that'd be where you'd solder in a connector to plug it in and have some fun. On a production board you aren't going to ever do anything with, you'd save the pennies by not putting that header on. Back in the day it probably made sense to skimp where you could.
    Jack McCarthy likes this.
  28. May 24, 2021 at 10:46 PM
    Jack McCarthy
    Bill
    North of Boston
    That's probably only a 2-4 layer circuit board to save cost. Years ago, when I worked with the guys who did a car radar, they had to keep the PWB design to only two layers and the cost to manufacture under $200. The manufacturer then turned around and sold it as an option to the consumer for $2-3K.
  29. May 25, 2021 at 4:16 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    My hopes and dreams are being crushed right now.
    How do these normally fail?
    CodyP likes this.
  30. May 25, 2021 at 7:31 AM
    empty_lord
    05 rollover special
    80% of the time the bypass works. BUT on their website they states there are certain codes you can’t fix.
    And yes I’ve ran into them at work
