  1. May 8, 2021 at 8:15 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I broke one of those bolts trying to use a torque wrench. The LBJ has some sort of rubber boot that keeps compressing. I don't think my torque wrench could ever figure out when I'd hit the magic #.
  2. May 8, 2021 at 8:25 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The boot is worn out then. The rubber should have a metal washer in it
    des2mtn likes this.
  3. May 8, 2021 at 9:38 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I always liked those. It wasn't going to work on my ranger when I planned to do one. I guess I forgot about it for the tundra. Maybe after I get fiberglass bedsides. I say you do it! Their prices aren't too bad either.
  4. May 8, 2021 at 10:50 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Keep us updated. Mine squeak like crazy
  5. May 9, 2021 at 4:59 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I'm super glad you guys are talking about squeaks in the leafs... let me know what you come up with.
  6. May 9, 2021 at 5:59 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Door is back together and works great. Put Sil-glyde on any moving parts I could find including the door handle, super smooth and like new. :yes:I had to go to the dealer for some rod snaps and got a new door check too. Stuck the plastic back to the door with some epoxy. Sucks spending money on this type of stuff but it also sucks having things that don't work 100% correctly. I also don't want to take door apart at a later date to replace the door check.
    We have power to the rear pods.
  7. May 9, 2021 at 6:20 AM
    Professional Hand Model
    Hand Protectors
    Whats your thoughts on the Hellwig Bar with drive time on her?
    theblurry1 likes this.
  8. May 9, 2021 at 7:28 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Still using the truck to move. Almost done. It's been easier to back it right up to the front porch. Neighbors probably think we're strange.
  9. May 9, 2021 at 7:48 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    A few weeks back I noticed my truck was sounding way more awesome than usual. Sure enough, the exhaust pipe cracked before the muffler. First priority was to drive the nearly open-pipe V8 like a hooligan for two weeks. Goodness it was fun to watch the 2nd and 3rd gens retreat in shame to the mall parking lots when I pulled up and revved the 4.7 monster.
    Unfortunately, all things must end and the time to fix it arrived yesterday.
    Pipe completely severed, the pipe is also separating from the muffler. While the hangers look solid, it appears it needed an additional hanger in this area for support.
    Repair parts...
    No exhaust repair is complete without a tin can. I sourced a 24 oz tomato can as the perfect solution for this application.
    Temporary repair complete...
    I'm anticipating that the internet experts will rake me over the coals for paying for the fancy pre-fab hanger and stainless band-aid when I could've used baling wire and a tin can but it's nothing but the best for my FGT. :rofl::rofl::rofl:
  10. May 9, 2021 at 8:01 AM
    jimf909
    Washington or Idaho
    @des2mtn, I've been tempted to experiment with cheaper door-check parts or even screwing bottom head screws into the bumps in the plastic arm to increase the resistance but would probably end up spending more time and money that way. Did you pay about $85 each for these? upload_2021-5-9_7-57-38.jpg
  11. May 9, 2021 at 8:24 AM
    des2mtn
    SW
    Tonto cover
    Yeah, I put some thought into how much I use the door and also about the time-effort-cost of fixing, going mickey mouse, or going cheapo. Paid about $86.
    I called multiple parts program dealers in the area and found one available for pickup same day. Told them I was going to order online and pick it up the same day and they said okay and fulfilled.
  12. May 9, 2021 at 8:24 AM
    Hand Protectors
    Thanks for the recco @bmf4069
    Used this Dremel that was Awarded to me at a Hand Model Conference for Those Most Likely to Succeed at Automotive Things.
    Got the Ports rounded off and the Edges knocked down as best as possible without going all @FrenchToasty on it. The Dremel came with a hard case and not a Purse. It even came with some cool accessories.
  13. May 9, 2021 at 8:27 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Shweet flow!
  14. May 9, 2021 at 8:34 AM
    Hand Protectors
    Yeah. I overlayed the Percy Gasket over the Header and then Sharpie’d the Round as a guide. Stoked.
    KarmaKannon likes this.
  15. May 9, 2021 at 8:39 AM
    Hand Protectors
    That Dremel has made me $$$ when cutting out old failed between floor PVC Shower Pan Drains from the topside. Put a cutter wheel on it and drop it down the drain to cut from the inside.
    Slip Joint Repair to new drain $$$. :yes:
    RUSTYNUTS, MS22, onesojourner and 2 others like this.
  16. May 9, 2021 at 12:38 PM
    gcholmes1
    gcholmes1 New Member
    2006 Tundra SR5
    Did my first ever timing belt job/water pump over the weekend. I'm only at 80k miles on my 06, but i have no records of the belt ever being changed by the previous owner. Decided to play it safe and replace since its 15 years old. Job wasn't as bad as I thought it would be, took me Friday evening and Saturday morning. Belt appeared to still be in decent condition, but the water pump had alot of crust under it, so I'm glad I got it all changed. also replaced all the drive belt components and thermostat while I was in there
    Had some trans fluid drip out of the hose when I disconnected it from the radiator (maybe about 1/2 cup)....is that a big deal? do i need to top off the trans?
  17. May 9, 2021 at 12:56 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Probably fine. But it may be worth doing a trans drain and fill every oil change for the next couple of them.
    I'm at about 168k and no trans fluid was ever changed on mine til a couple weeks ago when I did 12 qts (4x drain & fills). I'll probably do a few more next oil change.
  18. May 9, 2021 at 1:46 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Noticeable difference right off, though I need to put some miles on and maybe adjust it to the middle notch.
  19. May 9, 2021 at 2:02 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I need to get some info on this and change mine sometime soon.
  20. May 9, 2021 at 4:01 PM
    Hand Protectors
    Cut El Gaskéts this evening from the Remfelx DIY Sheet. Top are the JBA provided which I used to template for the cut Final Product Bottoms.
    Shtuff is like a weird mix of Graphite, Aluminum, Mica, with a Fiber Mesh in the middle. Double Thickness over the JBA.
    Thrussn, hammeron, theblurry1 and 6 others like this.
  21. May 9, 2021 at 6:01 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I installed a diff drop today, pretty simple.
    The diff kit cost $38, came with good instructions, grade 8.8 hardware... and a bunch of swag. I like.
    [​IMG]2021-05-09_06-26-20 by GhostCreekMine, on Flickr
    [​IMG]2021-05-09_06-22-26 by GhostCreekMine, on Flickr
    Also painted my grille badging (gotta stick with the Deadpool theme). I picked up some rattle-can color matching paint (Toyota 3K4)... which turns out, is pretty hard to find. Gave it a few coats of that and two of clear-coat to top em off. Taping the "V 8" was a bitch but worth my time. Happy.
    They were previously bedlined black... by me.
    [​IMG]2021-05-09_06-55-00 by GhostCreekMine, on Flickr
    Now Deadpool red grille badging. Breaks up the grille a little better, the black-on-black was boring.
    [​IMG]2021-05-09_06-19-36 by GhostCreekMine, on Flickr
  22. May 9, 2021 at 6:13 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    That reminds me... do I need to get an alignment after the diff drop? Not sure if it effected the alignment. Felt good after a test drive.
  23. May 9, 2021 at 6:36 PM
    KarmaKannon
    Utah
    Some junk
    Looks good. I was just talking to my pops about painting my roof flat black. I was thinking my hood should get painted too. Later I'll probably paint my fiberglass fenders and the sides of the hood phantom grey again. Glad to see the black hood doesn't look bad at all.
    Darkness and Glock 40[QUOTED] like this.
  24. May 9, 2021 at 6:37 PM
    KarmaKannon
    Utah
    Some junk
    No suspension parts are changed. You should be good. It would be like changing a CV axle and needed an alignment. If you didn't move any suspension or steering then you are good.
  25. May 9, 2021 at 6:38 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Nope, unless you removed the control arms/tie rods or suspension.
    Also fyi grade 8.8 is similar to grade 5 hardware.
    Grade 10.9 is better and 12.9 is the best.
    Don't you unbolt the steering knuckle when doing that? Toe set is possibly needed, unless the knuckle has dowels. Can't recall lol.
    theblurry1 and Glock 40[QUOTED] like this.
  26. May 9, 2021 at 7:10 PM
    KarmaKannon
    Utah
    Some junk
    As long as you don't adjust anything it should go back together like you never touched it. Tapered tie rod and ball joint ends shouldn't move anything if they are removed from and put back on. If they do, something is wrong.
    Darkness likes this.
  27. May 9, 2021 at 7:22 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Oem optics are far superior too.
  28. May 9, 2021 at 7:25 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What fluid are you using?
  29. May 9, 2021 at 7:39 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I did 4 quarts of Toyota WS and then 8 of Valvoline Maxlife (WS rated). This was after reading about how OEM WS breaks down faster with heat (ie: towing). If I hadn't already bought 4 of the OEM I would have used only the Maxlife.
    ToyotaJim, CodyP and NUDRAT like this.
  30. May 9, 2021 at 8:53 PM
    Manimal45ACP
    Manimal45ACP New Member
    Josh
    2005 Double Cab Tundra
    Been a busy month on the truck. All the exterior bulbs have been upgraded to LED. Which has caused a few goblins to figure out but nothing terrible. Replaced upper and lower ball joints, new shocks and struts, added a leveling kit and bump stop extensions. Installed new leaf springs and went with a heavy duty set with one extra leaf,will most likely tear the old ones apart and add one of them as well. Added a lot of weight to the truck and have plans for more. Replaced tie rods and sway bar links while i was at it cause everything was already torn apart. 20210416_182033.jpg 20210418_183508.jpg Yesterday was spent wiring up some rock lights. Plan on finishing that up tomorrow after work. Although I will most likely end up getting a couple more ‍♂️
    Voss, oscardog86, des2mtn and 8 others like this.
