  1. May 7, 2021 at 6:11 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Installing my Hellwig swaybar, however the exhaust exits out the side right at the axle which is right where the right hand end link needs to be.
    Time for the sawzall I think? :sawzall:
    Always kind of wanted to do a through the bedside exhaust..
  2. May 7, 2021 at 6:28 PM
    Grumpy74
    Grumpy74 New Member
    2005 White Tundra SR5
    I finally stepped up to LED headlights and I got new headlight buckets too. I got the buckets and side marker light housings from yitamotor.com and the headlights off of Amazon. The light housings were $140 shipped and the bulbs were $45 shipped. I'm looking forward to being able to see at night.
    IMG_20210507_191830463.jpg IMG_20210507_191750317.jpg IMG_20210507_192113340.jpg IMG_20210507_192105302.jpg
  3. May 7, 2021 at 6:52 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That same guy sells repair kits for that. Not expensive either. Apparently it's fairly common on the first gen.
    NUDRAT and bmf4069[QUOTED] like this.
  4. May 7, 2021 at 7:56 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Got the foglight pods mounted in the buckets and the adapters wired up. I used marine grade heat shrink tubing that has adhesive inside so they're self sealing. I had to paint the buckets because I didn't realize that they sent me two different brands and they were two different colors. Tomorrow they get installed and connected to the foglight switch.
    MS22, bmf4069, Trailscape and 3 others like this.
  5. May 7, 2021 at 9:03 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This is great work! Do you think there will be enough airflow behind the lights for effective cooling?
    Might be wise to drill some ¼" holes in the back of the filler cup for airflow. You could arrange them so they'd be hidden by the lights.
    NUDRAT and SoCalPaul[QUOTED] like this.
  6. May 7, 2021 at 11:02 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Toyota meet tomorrow in the OC.
    NUDRAT and bmf4069 like this.
  7. May 8, 2021 at 6:00 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Oh they're fubar alright. During a storm a while back my door slammed on me and in a blind rage I threw the door open. Not my finest hour. :oops:
    Sampson, MS22, CodyP and 3 others like this.
  8. May 8, 2021 at 6:03 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I dunno, that whole mounting part is torn metal.
  9. May 8, 2021 at 6:51 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    You could go in for inspection a little early....
  10. May 8, 2021 at 6:58 AM
    Professional Hand Model
    Hand Protectors
    The other day when doing the Tweeter Install, I decided to Grease Up the Door Handles from inside. In doing so, I messed up the Cable Mojo leading from the Lock. My Hand ever so slightly moved the Cable when going into the door.
    Result: Door Lock Problems on that door (driver side).
    Fix: Remove door panel again :annoyed:and readjust the Cable Mojo (ever so slightly).
    Conclusion: Cable very sensitive.
  11. May 8, 2021 at 8:34 AM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
    21 years and over a quarter millions miles... Mcguires Scratch-X works pretty good on headlights. Wish it would remove paint chips too. haha
  12. May 8, 2021 at 1:32 PM
    Trailscape
    Alabama
    2006 Tundra SR5
    Hellwig rear sway installed..
    Exhaust getting all up in the way.. I'll fix that.
    oscardog86, Darkness, NUDRAT and 4 others like this.
  13. May 8, 2021 at 2:03 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I like the way that looks!
  14. May 8, 2021 at 2:09 PM
    KarmaKannon
    Utah
    Some junk
    True. I think around here you can do an inspection up to 60 days before the registration runs out. I'll be doing mine a little early this year too. Never know when a secondary air injection or gas cap throws a light.
    NUDRAT[QUOTED] likes this.
  15. May 8, 2021 at 2:12 PM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    X2
  16. May 8, 2021 at 2:33 PM
    Trailscape
    Alabama
    2006 Tundra SR5
    Lol.. 30 seconds with the sawzall beat having to take the whole sway bar off. Since adding the new leafs I was already having issue with it occasionally bouncing off the exhaust tips. Hence the section of pipe I stuck between the hanger bushing.
    Eventually, I want this...
    https://www.dirtskum.com/product/fender-exhaust-bezels
    CodyP likes this.
  17. May 8, 2021 at 3:46 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Tundra on call, this one kicked my ass.
    Both showers backed up, not until after I called the plumber, that I added the double drop shot swivel to make the stupid combo. My arms are on fire, I sent the snake down at least 15 times, pulled up two keepers that were thicker than my old dread locks, and the one that got off is what finally cleared the drain. Ran water for 30 mins and no more backup! AA36117A-C53D-4AD9-950B-43314AE6EEA0.jpg8449FF43-B544-4365-8492-169FB663E888.jpgDC313F02-A1C2-45B9-842A-81CB376D23ED.jpg
  18. May 8, 2021 at 3:51 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    that tire mount is sweet. Can you add some more shots and who makes/ made it.
    RUSTYNUTS likes this.
  19. May 8, 2021 at 3:59 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Tried to Wired up my third brake light on the snugtop. Couldn’t get it to work. Turns out the wires had fallen off the light, then when I tired taking out the light, it fell and the lens shattered. Hahahahaha
    New light is on the way. Also washed the truck.
    Old light mode number
    new light I ordered, the measurement match so we will see.
    Discount Camper Shells Snugtop Parts.com 716918 14 3/8 Brake Light. Fits Snugtop Campers, 14 3/8 Long
    MS22, Voss and FrenchToasty like this.
  20. May 8, 2021 at 4:15 PM
    FrenchToasty
    Mo
    Bone stock
    It’s a coastal off road DIY kit. It took some work to make it line up right. I tack welded it all together and took it to my buddy with a 220v unit to finish weld it all. I didn’t like/appreciate coastals customer service; so I designed and made my own swing out. It works well for me, but still need to add some accessories. I’m working on refurbishing a snug top as well for camping; should be a nice unit once I’m all done.
    I’ll snap pics after it cools off outside.
    NUDRAT, daveeasa, MS22 and 1 other person like this.
  21. May 8, 2021 at 4:27 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Today I finished installing the DuroBumps and LBjs.
    Thrussn, hammeron, NUDRAT and 11 others like this.
  22. May 8, 2021 at 4:57 PM
    NWPirate
    Zach
    WA
    Good stuff :thumbsup:
    Did you upgrade the bumps because you're lifted?
    Did you replace the 8 bolts for the LBJ's or just stick with the originals?
  23. May 8, 2021 at 5:30 PM
    Voss
    2003 AC TRD 4x4
    Did the durobumps cause lifted and thought it would help. I haven’t changed the original LBJ 8.... but if this is something we should do, tell me please lol.
  24. May 8, 2021 at 5:35 PM
    FrenchToasty
    Mo
    Bone stock
    Just order 8 new bolts from Toyota. Supposedly they can fatigue from removal and install.
  25. May 8, 2021 at 5:36 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    On 04 and older it’s best practice to replace the lbs bolts. Use a torque wrench!. 05-06 with the larger bolts your usually fine
    Thrussn, oscardog86, NWPirate and 2 others like this.
  26. May 8, 2021 at 5:37 PM
    empty_lord
    05 rollover special
    My leaf squeak is caused by the rivets on the AAL clamps. Should I shave the rivet down or just straight up remove the whole thing? [​IMG]
  27. May 8, 2021 at 5:44 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Took it camping
    Tuco came along and saw his first bonfire
  28. May 8, 2021 at 6:02 PM
    Voss
    2003 AC TRD 4x4
    I can see why he won’t stay in the back seat. Dudes got some attitude to him lol. Lov it
  29. May 8, 2021 at 6:02 PM
    NWPirate
    Zach
    WA
    Do you happen to know if this applies to the Sequoia too? 04
    I've looked for that part number before and couldn't come up with it. :anonymous:
  30. May 8, 2021 at 6:14 PM
    NWPirate
    Zach
    WA
    I'm lifting the Sequoia later this year, slowly gathering parts for a front end rebuild also. 2" Ironman lift.
    How does a guy know what length of bump stops to buy?
    Thanks fellas :hattip:
