  1. Apr 29, 2021 at 3:23 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    You know after seeing this, I wouldn't be surprised if that's how most of the moisture is getting into my tank nowadays from that gnarly, rusty gasket which is probably worse on my tundra. Seems like I'm always adding some heet every few months and the truck generally runs rougher after a rain storm. Great job, PHM!
    RUSTYNUTS, NUDRAT, Voss and 2 others like this.
  2. Apr 29, 2021 at 3:36 PM
    Professional Hand Model
    Hand Protectors
    Thanks. I read a review of one guy with 70k on his Tundra which was throwing codes. He did a ton of work fixing parts to clear the code to no avail. Ended up being his Gasket was gnar gnar.
    I really filed and cleaned it up as best as possible. The FIPG on Gasket should hold her into the future. Had to fill in those gaps with something.
    Voss and Jack McCarthy[QUOTED] like this.
  3. Apr 29, 2021 at 4:24 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Thinking on top of the box!
    Did a oil change after I got off work, that fumoto valve is handy randy! Greased all my joints, including UBJs, and I got super lucky, all my drive shaft zerks were aiming right down at me!!! I was digging thru the neighbors recycle to make sure they were compliant with the new non recyclable addendum. Found a sweet ramp so my frame wouldn’t get all oily when I pulled the filter! E8141671-EB1B-42ED-8156-39791F459567.jpg
  4. Apr 29, 2021 at 4:29 PM
    Hand Protectors
    @FrenchToasty
    1) I love it when the Zerks line up without trying. Its almost a Nirvanic Feeling.
    2) You scored a .5 on Wurrld Peas Credítz for reusing trash. Another .37 for picking through the neighbors cans.
    KarmaKannon, NUDRAT, bmf4069 and 4 others like this.
  5. Apr 29, 2021 at 4:32 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    About to order a master cylinder. Aside from oem has anyone used c-tek, raybestos, or buck arnley?
  6. Apr 29, 2021 at 4:35 PM
    FrenchToasty
    Mo
    Bone stock
    Thanks!
    I usually have to throw the “good stuff” in the neighbors can or the alley can............because........my mom digs thru mine!!!!! Then I find shit I threw away back at my house or over at hers!!! I even went as far as throwing Festivus decorations away at my kids school......she found those too!!!!!
    @Professional Hand Model
    Was it you who said you used some sand paper to get some lines going on the dip stick to make it read easier after a oil change? It’s like I filled it with water, can barely see it! I used my money makers and started to poke the dip stick above the high dot until it came up with a dab on my finger, just below the high dot.
  7. Apr 29, 2021 at 4:46 PM
    Hand Protectors
    Yeah. I never did it, but I saw someone recco cutting some hash lines on the stick for better readings.
  8. Apr 29, 2021 at 4:48 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The one I installed a few months ago is Raybestos from Rock Auto. No issues with it yet but I haven't had it long.
    NUDRAT and Sirfive[QUOTED] like this.
  9. Apr 29, 2021 at 5:58 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Well done sir! I've been waiting in anticipation for you to do this! Might message you with some questions, because I am very close to doing this job myself (Denso pump is on backorder but gaskets, etc. arrived). Any pointers for the task? Can't find that evap canister gasket part number, your tank looks different than the diagrams, but that super clean RTV job is tempting if my gasket is bad.
    When I towed my truck away from the shop that quoted me $2K for this job, they made up some B.S. about the sender unit absolutely needing to get replaced and that's why their price was so high. It made me scared since I am not replacing that, but I still didn't believe them.
  10. Apr 29, 2021 at 6:00 PM
    Azblue
    The Dirty T ( ^_^)_且
    Maybe, but also - .75 credits for turning a perfectly recyclable piece of cardboard into an oil soaked piece of trash.
  11. Apr 29, 2021 at 6:10 PM
    FrenchToasty
    Mo
    Bone stock
    Technically it did serve a second/better purpose, better than most. Maybe I could even tri-cycle it, and use it to light my smudge pot(I don’t own a smudge pot......yet)
  12. Apr 29, 2021 at 6:18 PM
    Hand Protectors
    Thanks. I just looked for that Evap Gasket and I think its part of the tank which is probably why it didn’t come off. I’d just FIPG it if I was you.
    When handling the Pump Assy be careful with it. Try to keep it flat without too much moving it. Its easy to bend or break one of those fine delicate arms or wires if not careful. I taped the Float Arm to the main body to keep it from rebounding back and forth when turning the Full Assy around to work the Unit. Just take your time and it will be fine.
    Most of my time was clean up using wire brushes, blowers, and micro fibers towels before during and after pulling the unit out. You’ll want to keep things as clean as possible to prevent debris from going down inside. Some stuff slipped by and dropped out in when I was filing. Next time I’d use a cardboard rectangle and tape it up inside the tank and throw a microfiber on it to catch the fine dust. I figure the filter will catch that little stuff that went down today. You just don’t want chunks of dirt and little rocks dow in there like was on mine when it was pulled out.
    That little clip on the bottom of the Pump is testy to install because its so small. I’d FIPG the screw/bolts next time if I could do it over again. The washers are split and maybe why the water intruded. I FIPG’d both sides of the Gasket matings and some did come up the holes, but I could have loaded up the split washer more once the Threading started.
    Other than that its easy stuff.
  13. Apr 29, 2021 at 6:19 PM
    Hand Protectors
    After further review, you are right. Also, I went back and saw the Pizza was a Triple Meat Lovers which is another .75 deduction. :rofl:
  14. Apr 29, 2021 at 7:12 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Best reduce
    Better reuse
    fun fact, You know that giant island of floating plastic in the pacific? That is almost entirely composed of plastic that the united states sent to China to recycle.
    KarmaKannon likes this.
  15. Apr 29, 2021 at 8:35 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    That is a nice use of materials. My immediate thought was, “it’s not delivery, it’s Digiorno.”
    bmf4069 and FrenchToasty[QUOTED] like this.
  16. Apr 29, 2021 at 9:13 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Windshield wiper arms were not coming all the way down and started to hit the side of the pillar. Tried to Loosen the bolts and readjust. The I applied to much force and something broke :sadviolin:.
    wipers won’t move now. Going to figure it out in the morning.
  17. Apr 29, 2021 at 10:22 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    FWIW, VW Vanagon gas tanks get all stinky and need to be re-gasketed at about 20 years (so just under 10 years ago for my 1990). Seeing some FGTs ready for a reseal in 2021 appears to be a similar timeline.
    Thanks for pepping my mindset with the tutorial.
  18. Apr 30, 2021 at 4:30 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Our 460 makes me want quieter tires. I haven't done the front floor or the roof yet, but I've done sound deadening about everywhere else on my truck. With quieter tires, a little more deadening, and wheel well liners, my truck could be gx460 quiet. At least road noise wise. My exhaust and intake are louder than the stock gx setup.
  19. Apr 30, 2021 at 4:37 AM
    KarmaKannon
    Utah
    Some junk
    So technically eating the animals is a reduction in methane right? That seems dependent on the end users exhaust setup though. I'd have to math it, but my gut says it's a wash.
  20. Apr 30, 2021 at 4:41 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I saved my packaging from last night's impossible burger to use next oil change. Doing my part, no pizza box here. Whirrled peas.
  21. Apr 30, 2021 at 4:51 AM
    KarmaKannon
    Utah
    Some junk
    The nissan titan has an even worse oil filter to cross member arrangements. I think it pours right onto a sway bar bracket that's shaped like a "U" and catches the oil. I adopted the method of using aluminum foil to make a little aluminum land bridge over frame bits so it would drain into the pan. Not sure a piece of cardboard would have worked for that one. Seems good enough for the slightly better toyota design though.
    des2mtn[QUOTED] likes this.
  22. Apr 30, 2021 at 4:51 AM
    Hand Protectors
    Yes it probably does wash out, but at least I feel better about not eating friends and the other best part is it makes me feel virtuous. I do have lots of extra flatulence, too. My flatulence smells better now than when eating meat so the extra flatulence I now have is an offset I can be happy about. Win win.
    des2mtn and bmf4069 like this.
  23. Apr 30, 2021 at 4:52 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm going to use an actual penguin to catch my oil next time. Just to offset whirled peas.
    NUDRAT, abcinv, CodyP and 4 others like this.
  24. Apr 30, 2021 at 4:55 AM
    KarmaKannon
    Utah
    Some junk
    You aren't preachy and that makes it virtuous. It's like that joke... "How do you know if someone has a rescue dog? They tell you!"
    If I could go without meat, I'd do it. More just because it would be great to grow everything I eat. Sadly, without meat I'd likely just gain back the 20lbs I just lost. So many carbs in everything tasty. I try to minimize that stuff unless I'm hiking or doing something pretty physical.
    bmf4069 likes this.
  25. Apr 30, 2021 at 4:56 AM
    KarmaKannon
    Utah
    Some junk
    Just don't use a duck. I think it just runs off their backs.
    NUDRAT, CodyP and bmf4069[QUOTED] like this.
  26. Apr 30, 2021 at 4:59 AM
    Hand Protectors
    Well stop doing less outside and breathing all that extra air our friends need to survive. Our plants depend on them you know. They need oxygen too!
  27. Apr 30, 2021 at 4:59 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Plus they're harder to catch. Little bastards just fly away. Then that damn dog laughs at you. Oh wait, that's something else. Nevermind.
    KarmaKannon[QUOTED] likes this.
  28. Apr 30, 2021 at 5:56 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    How are you guys liking the GX?
  29. Apr 30, 2021 at 6:05 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    It depends on your meat. As it turns out cows are supposed to eat grass not corn.
    @speedtre This is my top priority when comes buying local. There are obvious health benefits and it seems to be harder to control people who feed themselves.
    speedtre, Voss, bmf4069 and 1 other person like this.
  30. Apr 30, 2021 at 9:21 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Nobody:...
    Literally everybody:...
    Sirfive: pond update!
    180132981_10159073591605275_345105053835_6967f89b7e278971319c27b9a4170008102a99a0.jpg
    took advantage of some rain we got and marked the low level where the pond side is just trickling into the pump side. (Plus an inch or so).
    I know it doesnt have anything to do with my tundra, but this is the thread it came up in.
    this is just my template. 12mm thick liner will be stretched and trimmed.
    bmf4069, NUDRAT, FirstGenVol and 4 others like this.
