  1. Apr 25, 2021 at 10:09 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its really weird to see another truck thats identical to yours huh? When I helped out @jImmegart with his truck I kept getting deja vu. I kept remembering this scene.
    Voss, bmf4069 and jImmegart like this.
  2. Apr 25, 2021 at 10:11 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’m tempted to buy the URD replacement pump action for mine, that comes with a external filter, from a local cat in the 4runner club(it’s for a 2010+ runner, but trying to confirm from urd it will work w my truck) for 100$. Whenever you guys do yours I’ll be watching closely
  3. Apr 25, 2021 at 10:20 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Doing some touch up under the truck. Painted the new muffler and pipe one more time. Touched up some rust on my leaf springs and rear axle. Plus a few dashes of Fluid Film here and there.
    Looks like one more coat might be needed later.
    Filthyphil, Voss, BubbaW and 6 others like this.
  4. Apr 25, 2021 at 10:26 AM
    Professional Hand Model
    Hand Protectors
    Yeah. The 2002 comes with an external filter already and the Denso OEM Pump costs around $130 with all the shtuff. Not sure of the URd specs and what it would do extra in terms of performance, but you know what you are doing. Only reason I’m doing mine is from reviews with Pumps around the same mileage.
    There is a Fuel Pressure Test of which I don’t possess the tool. Must be the test they did on Blurrys. Here is the DMM Ohms Spec Test for the 2002 Fuel Pump once its removed. I’ll be doing this for grins at that point.
  5. Apr 25, 2021 at 10:35 AM
    FrenchToasty
    Mo
    Bone stock
    Nice, yeah I’m doing it so I can then have a external filter to replace at my Leisure. I’m not doing it so much for the pump performance, more so the ease of filter replacement. Have you looked into any fuel pressure testing gauges? I’ve seen the one everyone links that goes onto/tween the front banjo fitting, but the one I watched my mechanic friend use; basically unclips the fuel line back near the rear banjo(but not actually the banjo fitting itself) and basically adds a loop/t system that goes to a gauge and then back to the fuel rail.
  6. Apr 25, 2021 at 10:54 AM
    Hand Protectors
    I haven’t and probably won’t by a Gauge as a New Pump will keep things Spec. A Filter is a good idea for your year as it doesn’t have one. Mine was a little gunky with 30k on it. The little internal tank sock seems to catch big stuff but mostly look ok from pictures I’ve seen.
    I had an old Honda with an easily changed filter near the tank. I’d change it every 10k miles or so. It was clear plastic and you could observe the gnar gnar in it with a quick glance. Two spring clamps held the hose an made for an easy swap.
  7. Apr 25, 2021 at 10:56 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  8. Apr 25, 2021 at 11:01 AM
    Hand Protectors
    Tundra2[QUOTED] likes this.
  9. Apr 25, 2021 at 1:41 PM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    Prepped and painted my brake drums. I Added KSP 1.25 spacers Monday. Went to double check the torque as stated in the manual and when removing the front right wheel one of the studs on the spacer broke. Now I need a new lug nut. Grr. Off they come and back to Amazon. Too bad as I really liked the way it looked with them. Maybe I’ll try the spider trax brand if they ever go on sale.
  10. Apr 25, 2021 at 1:46 PM
    Hand Protectors
    SpiderTrax uses Crome Moly steel versus the KSP Pot Metal? on their studs. I like the look of the Spacer too, but its Scary Larry!
    jImmegart and jerryallday like this.
  11. Apr 25, 2021 at 1:52 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
  12. Apr 25, 2021 at 1:59 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I dare someone to find my twin truck!
  13. Apr 25, 2021 at 3:43 PM
    shoe07
    shoe07 New Member
    Ohio
    They were stamped 10.9, but wasn’t to hard to break. The sad part is I actually followed the directions and didn’t use an impact at all. All by hand and torqued to spec.
    I had bought the spidertrax and returned because I thought I was getting a set of 4, they’re flipping expensive.
    I returned those and bought the ksp and another brand, the ksp looked much better, and had generally favorable reviews.
    live and learn
  14. Apr 25, 2021 at 3:57 PM
    Hand Protectors
    Everyone swears by the Spiders. I bought some Lug Extender Nuts along with 4 of those High Dolla Blue Spacers. The ET Nut bottomed out without slipping down into the bore so I said screw it. Went to Plan B and looked at the way the Provided Nuts from Spiders wobbled around with limited contact on the Lug and said foughetaboutit! Lots of great reviews, but Spacers aren’t for me.
    FrenchToasty likes this.
  15. Apr 25, 2021 at 4:11 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Well finally got the wheels/tires mounted and installed. No rubbing. I think they stick out just about the exact same. Either way they stick out enough for me that I don't want to run the spacers I have so now I gotta try and recoup my money on them.
    In case anyone cares, I went from a:
    20x9 -12mm offset
    BFG A/T K02 275/60
    86.5lbs Load C (6 ply)
    to
    17x8 0mm offset
    Kenda Klever R/T 285/70
    87.5lbs Load E (10 ply)
    I'm really happy with the look. Would have rather had 6 ply tires since I really don't need to 10 but it does stiffen up body roll a bit so that's nice.
  16. Apr 25, 2021 at 4:34 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @CodyP that looks so much better. You can't even see black wheels from more than a few feet away. It just blends in with the tire. Good choice.
    jImmegart and Darkness like this.
  17. Apr 25, 2021 at 4:39 PM
    Mitch09
    Mitch09 New Member
    NC
    2022 SR5 TRD Off-road
    wheels/tires look great. Where’d you get those mirrors?
    Voss and shoe07 like this.
  18. Apr 25, 2021 at 4:40 PM
    Mitch09
    Mitch09 New Member
    NC
    Man you can have my stock carpet mats if you want them.
    912[QUOTED] likes this.
  19. Apr 25, 2021 at 4:49 PM
    Mitch09
    Mitch09 New Member
    NC
    Got hold of the truck with some more raptor liner...
  20. Apr 25, 2021 at 5:33 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Installed a low profile single row 31" Nilight light bar in the front bumper.
    Measured the actual amperage draw of the light bar with the truck running and it pulls only 6.3 amps so I didn't use a relay, ran it directly to the 10 amp rated switch with an inline fuse.
    bmf4069, abcinv, Beefnbread and 9 others like this.
  21. Apr 25, 2021 at 5:44 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Daylight and phone camera does it no justice, but installed LED reverse lights. That and I got a better angle on the incandescent. By eye it appears significantly brighter.
    Also went by my old neighbors house and borrowed his manual lathe to make a higher flowing fitting for my trans fluid filler.
    Left to right: original, modified and custom.
    Trailscape, bmf4069, des2mtn and 6 others like this.
  22. Apr 25, 2021 at 6:07 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Nice! Perfect fit in that bumper slot.
    (the camera adds 10lbs to you calves)
    bmf4069, Lil Steve[QUOTED] and Voss like this.
  23. Apr 25, 2021 at 6:27 PM
    Lil Steve
    Gilbert, AZ
    Dammit, I've lost 10lbs over the last 30 days, all for nuthin'. Guess I'll go make a sammich. :sandwich:
    bmf4069, CodyP, des2mtn and 2 others like this.
  24. Apr 25, 2021 at 6:34 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    @rock climber @Professional Hand Model @CodyP @2006 Tundra AC
    I towed 150 miles over the weekend. I estimate with the shell and stuff in the bed, around 500 pound and maybe 400 pounds of passengers and dogs in the cab. I am still a bit weak on weight distribution with the trailer but the springs still did great. I measured after we pulled into camp and I was right 21.5 in the front and back. To get this dialed in properly I am going to have to upgrade the spring bars on my hitch. My truck no longer feels like a turd when I go adventuring. I still have plenty of suspension travel with this setup.
    Unhitched, things went back up to 22 3/4.
    I put a tailgate spring bar in when I got to camp. I bought a returned one for $17. AMAZING.
  25. Apr 25, 2021 at 6:36 PM
    Lil Steve
    Gilbert, AZ
    Darkness likes this.
  26. Apr 25, 2021 at 6:40 PM
    empty_lord
    05 rollover special
    Oh please. Tell me more and why I should pay you for one of thsse
  27. Apr 25, 2021 at 6:53 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    It's the piece that goes between the plastic tube that sits inside the bottle and the hose.
    In the bottom left corner of this photo, where the clear hose meets the black threaded cap is where it sits.
    It goes from the original 1/8" or so I.D., to a 7/32" I.D. Which is the same as the I.D. of the inline ball valve I used.
    I haven't even tried it yet, if it's too fast I may have to go back to the modified one lol.
    RustyShackle323 and Darkness like this.
  28. Apr 25, 2021 at 6:53 PM
    empty_lord
    05 rollover special
    Oh damn. I thought it was for the transmission filter. DOH.
    assassin10000[QUOTED] likes this.
  29. Apr 25, 2021 at 6:58 PM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Took her for a walk today to Walmart.
  30. Apr 25, 2021 at 6:59 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Forum dyslexia. Gets all of us lol.
