  1. Apr 24, 2021 at 4:00 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    I have a feeling you all aren’t going to like this but I do and that’s all that matters.
    edit; I had to make my own bracket to fit the grill and modify the screws for the bracket to make this work. Just in case someone tries in future... you gotta shorten the screws that come with this badge or else they’ll tear your driver side horn off when you open the hood.
  2. Apr 24, 2021 at 4:16 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    Ya, i didn't think about the gap until today. Thanks anyways!
  3. Apr 24, 2021 at 4:45 PM
    Voss
    2003 AC TRD 4x4
    My exhaust guy kept warning me about the gap cause I wanted it closer to body to avoid issues on the trails.
    maybe with the tip it’ll be better?..
  4. Apr 24, 2021 at 5:23 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Got the side window in the shell! Not to bad of a job, a corner gave us a little fight but I just had to stretch some metal, no biggie. I’ll need to trim or Massage the window molding, not letting it slide completely closed
  5. Apr 24, 2021 at 5:49 PM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    The Other Guy on youtube talks about the problem with the SPC arms and this lift and then found the adapter that fixes it.
    I do plan to talk to Tuff Country and emailed them Thursday and called Friday but their tech guys were out. Evidently they'll call me back. In the mean time, because of @KNABORES suggestion, I took the coil/strut apart after seeing that the isolator had squished some and gotten caddywompus:
    The bushings holding the top mount I think were also on the wrong sides of where they should've been.
    After fixing that the spindle still got into the coil, at full droop on the jackstand, but it would pop back out.
    I also listened to @RUSTYNUTS and torqued the LCA bolts with them in the "close enough while jacked up" position and also Josh at 1stgenoffroad.com suggested attaching the sway bar links prior to dropping the wheel.
    The combination of those three things got me to this spot when on the ground:
    The isolator is still wonky but at least its wonkiness is working for me for now. I'll see if it lasts.
    I drove it around the block and over some speed bumps then took it to get aligned.
    Drives good. Hit some speed bumps at 20 on the way home and didn't hear anything get bound up.
    Thanks all for your help
  6. Apr 24, 2021 at 5:55 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup, thats the guy I was referring to but couldn't recall his name. Nice to see there is an adapter, last video I had seen he was SOL.
    Your swaybar should limit the droop by close to 2" and that might keep the contact from happening, assuming it was not connected while you experienced the problem.
  7. Apr 24, 2021 at 6:28 PM
    jImmegart
    Jonah
    California
    Not sure, I just dont want it to hit my bed or anything. Not in a big hurry but Might cut it like @Darkness to clean up the sides. Still haven't decided though.
  8. Apr 24, 2021 at 8:05 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Installed my Mishimoto radiator, 170degree thermostat, and a new MAF sensor. I’ve only taken 1 drive so far, and so far, a 5 degree improvement. We’ll see if the temps stay down while towing.
    bmf4069, NUDRAT, Voss and 6 others like this.
  9. Apr 24, 2021 at 8:17 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Nice!
    lsaami[QUOTED] likes this.
  10. Apr 24, 2021 at 8:19 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    What's not to like? Have a link? In case someone wants to copy you.
    Voss[QUOTED] and Pearl-snap like this.
  11. Apr 24, 2021 at 8:23 PM
    alb1k
    Left Coast
    It's good
    I think that’s an access I have a DC, did yours come with the fog lights? I need to do some research, lol
  12. Apr 24, 2021 at 9:06 PM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Darkness and alb1k like this.
  13. Apr 24, 2021 at 9:08 PM
    alb1k
    Left Coast
    It's good
  14. Apr 24, 2021 at 9:17 PM
    912
    2005 DC 4x4
    Lol the funny thing is, I'd consider it if they didnt say Darrell Waltrip on them. I hate NASCAR #cantturnrright
  15. Apr 24, 2021 at 9:21 PM
    alb1k
    Left Coast
    It's good
    Buhaaaaaaaaaafffff!!!!
    KarmaKannon likes this.
  16. Apr 24, 2021 at 10:06 PM
    Voss
    2003 AC TRD 4x4
    Here’s the link but at the moment it doesn’t have the red, orange, yellow option...
    Haitzu TRD Grille Emblem Badge Fit for Toyota 4Runner Tacoma Tundra, Decoration Accessories for Truck Sequoia Rav4 Highlander White/Grey/Dark Grey https://www.amazon.com/dp/B08K8QWJMY/ref=cm_sw_r_cp_api_glt_fabc_Q75DZM3JNQDJ1RTF5J57?_encoding=UTF8
    KarmaKannon[QUOTED] likes this.
  17. Apr 24, 2021 at 11:33 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Just a simple car wash and vacuum.
  18. Apr 25, 2021 at 12:26 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I bet I can find those new in a warehouse still for half
  19. Apr 25, 2021 at 5:09 AM
    06tacomadc
    06tacomadc New Member
    Motor City
    Tundra
    If you do and there are extras, I’m interested in a set
  20. Apr 25, 2021 at 7:33 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Anyone think i borked it myself by using dot4 instead of dot3? Almost everything ive read says theyre interchangable, but dot4 might be a touch thinner?
  21. Apr 25, 2021 at 7:35 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Aight guys I'm ordering the fuel pump stuff. Denso did have the lowest price at $109 (vs $350 at Stevenson Toyota) and it even comes with the little hose and clips, so thank you @Professional Hand Model. Getting the strainer, cushion, and tank gasket shipped from McGeorge for like $35.
    Should I get the entire fuel pump hanger (sender gauge and suction plate) assembly? You know, the rest of the stuff attached to the pump? In my opinion I bet I don't need to, but while it's out and accessible, could be a thought.
  22. Apr 25, 2021 at 7:39 AM
    Hand Protectors
    Your call. I’m taking the risk of not doing the sender based on others not doing them and not having a problem. Its not a normal problem that pops up here that I’ve seen. Just take care of the removal of the assy that you do not Mangle the unit. The sender adds another $85? Iirc.
    theblurry1[QUOTED] likes this.
  23. Apr 25, 2021 at 7:53 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    That's just what I was hoping to hear. And yes it's about that much additional cost, probably overkill. Thank you. Are you doing this job as well?
  24. Apr 25, 2021 at 7:56 AM
    Hand Protectors
    The best brake fluid out there for daily drivers is the Bosch DOT5.1
    Not sure what you borked but hope you can get it fixed soon.
  25. Apr 25, 2021 at 8:00 AM
    alb1k
    Left Coast
    It's good
    Dude, you stole my truck! Lol. Sweet all around!
    Voss likes this.
  26. Apr 25, 2021 at 8:01 AM
    Hand Protectors
    Yes as soon as time and weather allows. Had about 4 windows of opportunity to do this job since mkd March that got closed due to things beyond my control. Maybe another chance this mid week? Been driving on empty and refilling in 3 gallons increments for a month and a half now to keep the tank light as possible. :annoyed:
  27. Apr 25, 2021 at 8:01 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You should be fine.
    Are DOT 3 and DOT 4 brake fluid compatible?
    Yes, DOT 3 brake fluid is compatible with DOT 4 brake fluid. However, DOT 4 offers a higher boiling point.
    bmf4069, Darkness, Voss and 3 others like this.
  28. Apr 25, 2021 at 8:26 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Dang I wish I could help you or vise versa, I bet by the second pump replacement we could half the time required.
  29. Apr 25, 2021 at 8:58 AM
    Hand Protectors
    Yeah. Like stated in that other post, the electrical clip removal was the time consumer. The hoses/etc are easy to remove. I watched a youtubess vid with a guy that dropped his tank at his house. His little daughter was in the back round the entire time. She said, ‘Daddy can I light this match?’ :rofl:
    theblurry1[QUOTED] and Voss like this.
  30. Apr 25, 2021 at 10:03 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Hahahaha. That is probably why I am enjoy following your build. Feels like the work is being done on my truck.
    You have inspired me to take the seats out and wash the carpet and do a full detail inside. Just lacking the energy and commitment.
    Voss and Darkness like this.
