  1. Mar 31, 2021 at 10:39 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    I highly recommend either an upgraded front sway bar, adding or upgrading a rear sway bar if you already have one to significantly reduce body roll. Keep in mind if you you moderately off-road, the sway bar will hinder articulation.
  2. Mar 31, 2021 at 12:07 PM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    New brakes and rotors. New rear drum too
    hammeron, Thrussn, speedtre and 6 others like this.
  3. Mar 31, 2021 at 12:14 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    He sleeps on my bed :rofl:
    He has a bed, he doesn't use it. I've put a treat back there but he ate it and jumped back over. The challenges of having a smart doggie.
  4. Mar 31, 2021 at 12:40 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Came out to a flat today. WTH nonsense is that 3 part thumbscrew together rod to lower the spare? Could not get it to set into the lowering thingy, even from under the truck. Dumbass didn't think to grab the one-piece rod from the Tacoma.
    Hella.
    and I've got a bad shoulder, healing slow. Using the jack damn near made me cry. Really should be on Oxy or something 8-\
    Grabbed a summer tire/rim from garage, jacked up truck, removed the nuts, dam tire rusted solid to the drum/hub whatever. Now late/missed my 8:15 mtg.
    Tightened it all back up, put air pump on the tire - she holds.
    Notice the big ass bolt sticking out of the tire, between treads, not sidewall - winning!
    Drive to tire shop, get tire patched. Call off work. Too late to be worth going in, plus a lot of other personal crap happening today.
    I gave up - Murphy wins. Murphy's law say someplace that Murphy always wins?
    Anyway, got a flat fixed. That damn truck just hates me. But i do love that seed of satan. oh well.
    hammeron and Jack McCarthy like this.
  5. Mar 31, 2021 at 2:06 PM
    Pearl-snap
    Pearl-snap New Member
    Added some missing bolts, clips, and plastic retaining pins to the front bumper with OEM parts.
    hammeron, standard, NUDRAT and 5 others like this.
  6. Mar 31, 2021 at 2:53 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    past week I've done oil, filter, air filter, ATF drain and fill, diff drain and fill, spark plug change and ordered 2 coils
    wife says, "you're finding a lot wrong with your truck" :duh:
  7. Mar 31, 2021 at 2:53 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    That's why I carry a Safety Seal kit.
    Air it up a little, pull the puncture, push a plug in, trim it, and head on the down the road.
  8. Mar 31, 2021 at 4:20 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Been talking to a coworker who left today to begin retirement at 60. I talked to him about what he’s going to do with his free time after already cutting up 3 cords of wood for his wood stove.
    Found out he’s interested in taking welding classes like myself at the local high school. I might be joining him this fall. Definitely a skill I’ll need if I want to fix the holes in my frame.
  9. Mar 31, 2021 at 4:38 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Swapped access cab glass today. Picked up two tinted ones for $10 ea. in pristine shape. Also scored a 3rd light lens and fog light switch...
    standard, NUDRAT, Darkness and 4 others like this.
  10. Mar 31, 2021 at 4:47 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Who’s running the “upgraded” one piece key fob and key? And are you double or accesscab.. I’m
    Having issues with the key I got
  11. Mar 31, 2021 at 5:54 PM
    speedtre
    speedtre New Member
    Inland Northwest
    I have both the flip and non-flip version...both work great. DC....used the programming instructions in the FSM for a DC.
    theblurry1, 912 and standard like this.
  12. Mar 31, 2021 at 5:56 PM
    empty_lord
    05 rollover special
    figured. different FCC IDs
    standard likes this.
  13. Mar 31, 2021 at 6:21 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Same here. I have the one piece key and works fine with the instructions. Sorry.
    #singlecabproblems
  14. Mar 31, 2021 at 7:19 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Installed the T100 brake booster and Master Cylinder today. The pedal feels great. The brakes will lock up by the time the old MC would be beginning to engage.
    The total install took me about 2.5 hrs to do and I wasn't in any rush.
    Before
    After
    The install was very simple too. I made a little write up about it here:
    https://www.tundras.com/threads/t100-brake-booster-upgrade.86375/
    theblurry1, Voss, oscardog86 and 11 others like this.
  15. Mar 31, 2021 at 7:20 PM
    Thrussn
    Gabe
    NM
    I'm also selling my factory booster and master cylinder to anyone who needs it. I'd be happy with like $20 plus shipping lol
    standard and Darkness like this.
  16. Mar 31, 2021 at 7:45 PM
    empty_lord
    05 rollover special
    how was everything on the pedal bracket side for bolting up?
  17. Mar 31, 2021 at 7:48 PM
    Thrussn
    Gabe
    NM
    Everything went smooth and lined up right on the inside. I had to cut that inside shaft of the booster 1/4" and I had to pinch in that one bracket on the outside that connects to the studs. Everything else bolted up as if it was made for it.
  18. Mar 31, 2021 at 8:29 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    The crinkly plastic stuff is known as a wire loom.
  19. Mar 31, 2021 at 8:33 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    A few months later and my roll of SMD LED's showed up.
    Removed the old orange LED's from the 4runner switch and installed the new white ones. Haven't put it in the truck yet, verified they worked with a 9v battery.
    theblurry1, hammeron, 912 and 2 others like this.
  20. Mar 31, 2021 at 8:49 PM
    empty_lord
    05 rollover special
    I need to find someone who can do this. My hands just aren’t steady enough
    theblurry1 and NUDRAT like this.
  21. Mar 31, 2021 at 9:02 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Once I swap this in, I still have the switches in my truck I can do this to if you want.
    theblurry1 likes this.
  22. Mar 31, 2021 at 9:03 PM
    empty_lord
    05 rollover special
    Oh you still have the other switch’s? I’d be willing to work out a deal
    honestly I’m looking for the OEM green.. just need the Bluetooth side, I swapped the volume side
    theblurry1 and FrenchToasty like this.
  23. Mar 31, 2021 at 9:03 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Come to think of it, I've got a tire patch kit in the basement. Forgot about that.
    Voss and FrenchToasty like this.
  24. Mar 31, 2021 at 9:31 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Shiiit... I think only like 34 of those Bluetooth side switches were ever made. If you come across a spare set, any color, I would always be in the market.
  25. Mar 31, 2021 at 9:32 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Truck looks awesome! How did you do the marker lights for the grill?
  26. Mar 31, 2021 at 9:36 PM
    empty_lord
    05 rollover special
    hmm? mine is the black style. super common. if your looking for the other colors, limited siennas had them. they pop up from time to time, but are rarer
    NUDRAT likes this.
  27. Mar 31, 2021 at 9:38 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I’ve seen the black and really dark gray but did the Sienna or Highlander have the light gray option?
  28. Mar 31, 2021 at 9:41 PM
    empty_lord
    05 rollover special
    sienna limited.
    controls are worn away on this one, BUT you can see it. there was tan and light grey
    NUDRAT and theblurry1 like this.
  29. Mar 31, 2021 at 9:42 PM
    empty_lord
    05 rollover special
    heres the grey
    NUDRAT likes this.
  30. Mar 31, 2021 at 9:49 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
