  1. Mar 22, 2021 at 2:10 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I think it also has a lot to do with JBL/non JBL and 6 disc/non 6 disc. It seems that the trucks with the disc changer and non JBL have the remote amp that mounts behind the hvac controls since the radio doesn’t have room for the internal amp.
  2. Mar 22, 2021 at 2:12 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Gotcha.
  3. Mar 22, 2021 at 2:37 PM
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    A buddy gave me the same set, that he got from his Dad. I spent time with an OptiVisor and sewing machine needle, pick cleaning each file, then cleaning the case. Good tools that bear a heritage are worth restoration.
  4. Mar 22, 2021 at 3:10 PM
    I can't tell you how many times I used these damn things to fix threads on ground down bike wheel and skateboard truck axles! Case is ratty but the files are still good as ever!
  5. Mar 22, 2021 at 3:20 PM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    I will find out
  6. Mar 22, 2021 at 4:28 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    anyone?
  7. Mar 22, 2021 at 4:43 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    FME
    Filthy Mos Exhaust.
    All and all it turned out pretty good, it sounds nice, I still need to take it on the highway and see how it drives and how it sounds, probably have to tighten things down after some heat cycles. It was definitely a pain in the ass for sure, but well worth it for me. Definitely more power, but it’s hard to notice because
    I’m tuned into the sound, then I look and I’m doing 30 over........
    I either have a leak or just a tick sound in the notes somewhere? Seems to be from the passenger side which is a relief if anything. Rear O2 extension harness should be in this week, let’s see if some stacked Fowler’s take care of any cels! BB9762BA-B5B0-448E-99C4-711BA9AF6EFE.jpg6AFCF692-A666-4B03-A270-5801CCDA2344.jpgD7F3A6FC-70DD-408D-AA6F-378B7B2D1484.jpgBB5D3014-286B-494B-A5A4-3D44C5C9C231.jpg
    Also, it was sooo damned windy today!!!! It was nice to take it all inside and weld it up; which I didn’t wear long sleeves......... so I’ve got some sweet arc sun burn on my guns, the redness highlights my freckly muscles, thankfully I live where you can walk out your door, cut some aloe, fillet it, and rub it all over!
    BubbaW, alb1k, Voss and 13 others like this.
  8. Mar 22, 2021 at 5:37 PM
    https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-714#post-1869210
    Meanwhile, on the steering wheel ... I know you just bought a new cover. You should've just bought a factory leather-wrapped wheel (used, eBay) with the correct cover. With controls etc. Would've saved $$ in the long run. That's ultimately what I ended up doing. It was, like, do I want to spend $60 and 2 hours on the Loncky wrap, trying to get it right, or just buy a nice used 2004-2009 4Runner or similar SUV wheel for $101 shipped. I opted for the latter. Here's the guy and the auction number I bought from (it's a different steering wheel now, not leather-wrapped! But check his other stuff). For another $80 (I think?) he was throwing in the airbag, front cover and controls.
    FrenchToasty likes this.
  9. Mar 22, 2021 at 5:44 PM
    I have an access cab, non-JBL, 6 disc. @912 sending you a PM in a sec.
    912 likes this.
  10. Mar 22, 2021 at 6:18 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I used to have that problem with kingpins all the time. I eventually learned to flip the kingpins so that the nut is in the truck base and the bolt head gets ground instead.
  11. Mar 22, 2021 at 6:58 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Is there a how-to or a list of wheels that will work on our trucks? Is it the same for all years of first gen Tundra?
  12. Mar 22, 2021 at 7:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    4th gen 4runner, 05-11 Tacoma, 1st gen sequoia, 03-06 Camry, and some Lexus all had the wheel that will be “bolt on” technically any toyota wheel from like 05 and up will work with 04-06 tundras if you repin the controls. Airbag will plug and play.
    SouthPaw likes this.
  13. Mar 22, 2021 at 7:10 PM
    Yup, didn't figure that out until about 5 years in. Sadly, with how many stairs and handrails I hit, no good solve for axles.
    What he said VV - @empty_lord is who provided direction for me at the start. It just so happens the 4Runner seemed to be the most readily available, despite the amber (vs. green) controls.
  14. Mar 22, 2021 at 7:12 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The last time I asked, it seemed like it was going to be a ton of work to get audio controls added to my 02. I'd be happy with just a nicer feeling and more modern looking wheel. I'll start looking on eBay.
  15. Mar 22, 2021 at 7:21 PM
    empty_lord
    05 rollover special
    Go on tacomaworld and look up then1st gen Tacoma steering wheel swap. It’s documented how to get the newer wheel working in the older trucks, but you will need an airbag and clock spring from an early sequoia
    mechanicjon was the OP, he’s worth getting a hold of if you have questions more than likely he can help
  16. Mar 22, 2021 at 8:06 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    Im still confused, does it only bolt on if its a 04-06 tundra? Or all Tundras 00-06
  17. Mar 22, 2021 at 9:29 PM
    empty_lord
    05 rollover special
    I know for a fact the 04-06 have the newer clock spring and dual stage airbags. 03 i don’t know for sure. 02 and older are single stage airbags with the same wheel as a first gen taco
    jImmegart[QUOTED] and Tundra2 like this.
  18. Mar 22, 2021 at 10:05 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Added the missing sticker that I forgot at home the other day.
  19. Mar 22, 2021 at 11:10 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Alignment. Then tried chemical guys black clay bar on the headlamps. That worked surprisingly well.
    NUDRAT and Tundra2 like this.
  20. Mar 23, 2021 at 1:17 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Not sure if this fella is sleeping for the night, or if he is dropping off a Tacoma in the morning. :p
  21. Mar 23, 2021 at 2:14 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Nothing wrong with that.....(awkward)
  22. Mar 23, 2021 at 4:54 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    empty_lord[QUOTED] likes this.
  23. Mar 23, 2021 at 10:03 AM
    Parts pickup ... at this point, preventative maintenance of tailgate rod clips (purple, orange, white), and proactive replacement of cowl clips, although I don't think mine's leaking yet. At an average of $1.50/ea clip, I figured I may as well replace them all while a 10% sale was goiong on at the local stealership and get one or two extras in case they get discontinued. Writeup for tailgate overhaul forthcoming!
    Oh, and got a good deal on the mesh back ball cap. My lucky old Pennington hat is on its last leg.
    alb1k, NUDRAT, hammeron and 3 others like this.
  24. Mar 23, 2021 at 10:40 AM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    This is what I think I remember from when I last had mine apart...I'll have to see what I get in there again.
    I'll look down there and see. Here's hoping!
    Thanks man, I've been watching eBay for a few months and jumped on this airbag and cover because it was well under $100 (best offer was accepted). I may go ahead and pick up a nice leather wheel with switches as well. Thanks for the PM!
    Thanks for all the info guys. Great discussion. Hopefully over the next few days I'll have some time to look into this on my truck. I'll snap some pics and post my findings in the hopes it might help someone in the future.
    NUDRAT likes this.
  25. Mar 23, 2021 at 10:55 AM
    I will say, that reply I posted a link to up above about steering wheel/controls overhaul ... at the end of that specific reply you'll see several threads externally, two of which were just linked by others. I tried to consolidate all the info into one place for when I did my Bluetooth controls add-on, and for future people searching the forum, I wanted to provide a one-reply basis for everyone to get the info they need, regardless their specific model. I have a replacement leather-wrapped 4Runner steering wheel for months now, I have the new right-hand controls, I have the ribbon connection cables... just haven't gotten off my ass to install. Too much going on.
    That said, I've got an aftermarket head unit so I installed a steering wheel control module (Axxess ASWC-1) that auto-detects what steering wheel switches you have and what your radio supports, then auto-configures the conversation between the two. No hacking, no fuss. Made it very easy. I believe adding the right-hand Bluetooth/phone controls should be a no-brainer, although I may need to reset that ASWC unit to detect? We'll see whenever I can get there.
    912[QUOTED] likes this.
  26. Mar 23, 2021 at 11:00 AM
    912
    2005 DC 4x4
    Thanks for your insight man. The post you linked above is golden!
  27. Mar 23, 2021 at 12:18 PM
    gcholmes1
    gcholmes1 New Member
    2006 Tundra SR5
    Had a close call the other day with a load resistor for my LED headlights catching fire. luckily I noticed the smell and popped the hood and noticed the fire just in time. I was able to get it put out before it got out of hand. The airbox caught fire and will need to be replaced, but it could have been a lot worse! PSA....Be careful with cheap resistors...20210319_140650.jpg20210319_141034.jpg
  28. Mar 23, 2021 at 12:24 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yikes. I probably would have parked the truck in my garage and let we rip for a while till the neighbors called the fire department lol
    FrenchToasty and Emartin like this.
  29. Mar 23, 2021 at 12:44 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    More China shit I'm sure. One of our goals for 2021 is to try and buy less junk made in China. It's not easy.
    Darkness, jImmegart, BubbaW and 3 others like this.
  30. Mar 23, 2021 at 12:47 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    It’s nearly impossible. I have no issues buying American stuff but when it costs 2-3 times as much and doesn’t last half as long I have issues. I would own a GM vehicle is they survived passed 150K miles but alas, that seems to be a pot of gold at the end of a non-reachable rainbow
