  1. Mar 5, 2021 at 3:31 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Grease rub huh... I'll try it in a small area first and see how it goes.
    Will go easy on power wash. I've too heard several stories about it going wrong. Was mostly just planning on doing around rear axle and suspension.
  2. Mar 5, 2021 at 3:32 PM
    Professional Hand Model
    Hand Protectors
    I used my Gloved Hands as well for some of those tight areas where the thick sponge won’t fit or in the weird angles.
    I’ve erased most of my Truck Pics, but will snap a few next week when doing some other work.
  3. Mar 5, 2021 at 3:35 PM
    NWPirate
    Zach
    WA
    I picture you crawling out from under the truck with more grease on you than the frame got. :rofl:
    Am I wrong?
    CodyP, GavinG83, Darkness and 2 others like this.
  4. Mar 5, 2021 at 3:47 PM
    Hand Protectors
    Yes. You are wrong. The Grease is thick and attaches to the sponge (or your hand) like... grease. If you are somewhat contentious you’ll only dirty your Hands and maybe a little on your forearm/elbows. All the work is like smathering icing on a cake with the Hands.
    You be able to do most of the axles and frame in less than 8 hours. The rest of the truck I attacked as I did other fixes or inspections using the saved Sponge in a Tub for reuse. Its an old trick I learned from a mechanic. A little at a time and eventually you’ll get the entire truck done, but the frame and axles you can tackle in under a day.
  5. Mar 5, 2021 at 3:47 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    There's a picture of me on the lunchtable back in June or July.
  6. Mar 5, 2021 at 3:49 PM
    Hand Protectors
    Its funny how something so simple is baffling. :rofl:
    Turd Gen’rs would be in Brain Lock right now.
    Tundra2 likes this.
  7. Mar 5, 2021 at 3:56 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    Heres some photos, If there is something more specific you wanna see lemme know. I didnt get much photos with it all taken apart but I will when I wire the reverse in.
    oscardog86 and Darkness like this.
  8. Mar 5, 2021 at 4:01 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-144#post-1801417
    Dug deep into the archives for this one.
    That's perfect! Thank you!
    NWPirate[QUOTED] likes this.
  9. Mar 5, 2021 at 4:12 PM
    NWPirate
    Zach
    WA
    Awesome man :thumbsup:
    I got garage clothes for those days :D
  10. Mar 5, 2021 at 4:29 PM
    Hand Protectors
    Denso Fuel Pump came in today. Small little thing.
    9012 HIR Bulbs arrived, as well. Might tool on those tomorrow.
    NWPirate likes this.
  11. Mar 5, 2021 at 5:56 PM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    LED License plate bulbs. Old ones burnt out.
    Voss and hammeron like this.
  12. Mar 5, 2021 at 6:25 PM
    Tibetan Nomad
    Tibetan Nomad New Member
    oscardog86, Voss, Darkness and 2 others like this.
  13. Mar 5, 2021 at 6:28 PM
    NWPirate
    Zach
    WA
    CAT thief, big spike right now all over the country.
  14. Mar 5, 2021 at 6:31 PM
    Tibetan Nomad
    Corrected.
  15. Mar 5, 2021 at 6:34 PM
    NWPirate
    Zach
    WA
    Crazy people can be so bold, ripping people off in broad daylight.
  16. Mar 5, 2021 at 6:50 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
  17. Mar 5, 2021 at 6:58 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    My 9mm would keep that cat safe.
  18. Mar 5, 2021 at 7:34 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I installed that GM fuse diode mod for AGM batteries. I remember empty_lord talking about the slight voltage increase for healthier charging and posting a thread about the mod.
    Here's my Before voltages:
    Here's the installed fuse diode
    And here's the after voltage:
    I'm sure there will be even more of a difference when the engine isn't hot.
  19. Mar 5, 2021 at 8:13 PM
    fighthedude
    fighthedude New Member
    For the guys running down the frames.... Doesn't all the grease and oil your putting on underneath collect a ton of dirt and debris?
    Voss likes this.
  20. Mar 5, 2021 at 8:34 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Tell me more.
    One really cold morning I was stopped at a light, heater cranked, headlights on, music jamming, and I looked down at my gauges and noticed my dummy gauge was abnormally low. So I put in one of those dual USB/digital voltmeter things to get a decent reading. Did the same thing on another cold morning and it got down to around 12.1.
    Now I know I’ve got the 130a alternator, but I can imagine it’s never been replaced and the brushes are just about worn. I need to do that 150a Sequoia swap but if I can get away with a $5 diode mod, I’m all for it.
    Thrussn[QUOTED] likes this.
  21. Mar 5, 2021 at 8:37 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Yup. Better than rust though. If you take a quick peek at mine, you’d think it’s covered in surface rust. Reality is, it’s covered in grease and a layer of red clay. Scratch through it and my frame looks as good as the day it rolled off the assembly line.
  22. Mar 5, 2021 at 8:55 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I’ve heard of bar and chain oil being used for rust prevention on frames, but not moly grease. Whatever works I guess. :notsure:
  23. Mar 5, 2021 at 9:32 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Got a link to the part you installed to bump up the voltage?
  24. Mar 5, 2021 at 10:03 PM
    Thrussn
    Gabe
    NM
    My voltage gauge has always been right in the middle while running (on the 05-06 dash), but it's definitely a little higher now after the mod.
    I'd imagine you covered it already, but have you had your battery tested? It's unlikely but possible that may cause your issue.
    You can probably get it cheaper at a local junkyard, autozoned, or broreileys if you look around on the internets. This is the part number for that GM diode.
    12135037
  25. Mar 5, 2021 at 10:10 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Some people pay a lot for that sort of job.
    oscardog86 and CodyP like this.
  26. Mar 6, 2021 at 4:01 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Nice results, thanks for sharing. This will be done in my truck in due time.
    I added a trickle charger and my AGM battery is topping up to 14.3v. I didn't monitor the level closely prior to to adding my push-button voltage meter but a tender makes complete sense for me.
    Voss and Thrussn[QUOTED] like this.
  27. Mar 6, 2021 at 5:30 AM
    Hand Protectors
    Part # pics?
    Which fuse location is this for others with a different box?
    Will this work for those of us with regular batteries?
    Voss, Tundra2 and Jerry311SD like this.
  28. Mar 6, 2021 at 5:32 AM
    Hand Protectors
    This Greasing/Oiling of the Frame blows peoples minds! Its so revolutionary nobody gets it. :thumbsup:
  29. Mar 6, 2021 at 6:00 AM
    Hand Protectors
    Found a picture of my Shaft Yoke portion that I re-did for informational purposes last month. I was seeing that people were having a hard time understanding these results I discuss.
    In this top pic you’ll notice how nice and oily and black my shaft appears (greased two years ago). The Yoke Section had some rusty crusty that I greased over. Last month, I cleaned off the grease and sanded the crusty off down to smooth metal. I then reapplied Grease (note the see thru shine!) in the bottom pic.
    I’ll post a third picture (later tonight) of a smooth Matte Black Shaft Finish that takes hold after a month of drive time. *Hint: It looks like the rest of the shaft I greased about 2 years ago.
    Filthyphil and RustyShackle323 like this.
  30. Mar 6, 2021 at 6:04 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Looks like Amazon has them.....
    https://www.amazon.com/Gen-Motors-General-DIODE-12135037-5/dp/B071913NJ4
