  1. Dec 16, 2018 at 10:17 AM
    #2551
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Yeah it smells. Mine was bad too. But sounds like yours has us all beat...
  2. Dec 16, 2018 at 10:47 AM
    #2552
    Casper421
    In the woods
    06 DC
    5000k DRL leds in place and switchbacks ordered for the turn signals.
  3. Dec 16, 2018 at 11:36 AM
    #2553
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That looks really nice, good match
  4. Dec 16, 2018 at 1:04 PM
    #2554
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I'd like to make my fogs and headlight ambers into drl instead of the head lights.
  5. Dec 16, 2018 at 1:23 PM
    #2555
    Casper421
    In the woods
    06 DC
    Like this:
  6. Dec 16, 2018 at 2:08 PM
    #2556
    because_wumbo-truck
    Jon
    Houston, Texas
    Exactly like that. What is thy bidding my master?
  7. Dec 16, 2018 at 4:10 PM
    #2557
    Professional Hand Model
    Hand Protectors
    Not sure if this solution to the leaky back Access Cab windows has ever been detailed, but I think I found the culprit (at least one of them). Its the rear slider window track when it gets gunk build up which clog the weep holes, that overflows into the cab and down the back wall behind the back seat. The water ends up in the rear corners of the cab on the carpet. See pics.
    Rear track inspection. Yep goop. Hmmm let me pull it up and see whats under.
    Let me pour some water in this water channel with the dirty track out of the way. Yep clogged.
    Lets poke the weep holes in the bottom of the track with a sharp pointy rod and scrape out the goop with a cloth and screwdriver.
    Lets clean out the rubber track holes that were clooged.
    Now lets flush the track and see what happens. Yep. Water in channel is no longer overflowing towards the inside of cab. An inspection of the outside of window rubber gasket reveals success! Water is flowing out from bottom of seal into the outside.
    Put it all back together and spray the rubber components with PB Silicone.
    tvpierce, Filthyphil, bmf4069 and 2 others like this.
  8. Dec 16, 2018 at 4:13 PM
    #2558
    Afkouki
    Afkouki New Member
    2006 Natural White Limited
    Got the windshield eyebrow tinted, removed factory steps. Just pulled into the garage to remove the sticker on passenger window and for some way
  9. Dec 16, 2018 at 4:20 PM
    #2559
    Hand Protectors
    Went ahead and caulked the rear gasket (top only) and the top track trims on both sides front to back.
    Blue tape is your friend. Used Liquid Nails ‘Fuze’. Nice color match.
    Darkness, Jerry311SD and Afkouki like this.
  10. Dec 16, 2018 at 4:25 PM
    #2560
    Afkouki
    Afkouki New Member
    My roof trim in the front on the passenger side it starting to pop up, maybe I should do this. Great idea!
  11. Dec 16, 2018 at 4:29 PM
    #2561
    Hand Protectors
    Big Box has the ‘Fuze’. It yours isn’t leaking, then a few dabs along the track should be good. This stuff is perfect for auto repairs. Flexible, yet strong. Bonds to wet surfaces too.
    I went over kill on todays ‘waterproofing’ project. This leak has been around for a few years (off and on). Hope everything done today got it.
    Sunnier and Jerry311SD like this.
  12. Dec 16, 2018 at 5:18 PM
    #2562
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  13. Dec 16, 2018 at 5:20 PM
    #2563
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I think they are close but they will not match up perfect from what I’ve heard. There’s some topics that have referred to this.
    Casper421 likes this.
  14. Dec 16, 2018 at 5:23 PM
    #2564
    Hand Protectors
    Anyone with some rust scale starting around their rear cross-member, or wanting to prevent rust on a new(er) frame: Buy a grease needle and insert it into the crevices/cracks where your frame overlaps and pump loads of grease where ever you can. I’m using moly-lith grease, then following up with PB Blaster Penetrant with a straw and squirting it into those same cracks that have already been loaded up with grease using the needle.
    The grease acts like a dam/seal, which locks in the PB Penetrant, thus flushing/bathing the vulnerable spot in petroleum distillates.
    Note: This will not cure holes in frame or severely rusted frames. In my case, I noticed some minor scaling where the rear cross-member ties into the frame side channels and decided to take action using the tactics above. My frame has already been through Toy recall with no problems (no holes) and they sprayed the rear half with the black tar coating at the Stealership. This scaling isn’t addressed in recalls.
    Stealerships coating ‘fix’ isn’t going to stop the scale from worsening at this critical area of the cross-member tie into the frame. My fix will.
    See the grease squeezing out of the overlaps. This is the second application of grease this year. Should be good to go for many years as this will prohibit future rust and lock out salts etc.
    Darkness and Filthyphil like this.
  15. Dec 16, 2018 at 6:20 PM
    #2565
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Skid Row back at it again with 20% off and free shipping till the end of the year!
  16. Dec 16, 2018 at 6:21 PM
    #2566
    because_wumbo-truck
    Jon
    Houston, Texas
    Man I wish I could afford them right now.
    Rheywood456[QUOTED] likes this.
  17. Dec 16, 2018 at 6:29 PM
    #2567
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Damn it. Tempted to get the short motor pate and sell my big one...
  18. Dec 16, 2018 at 6:41 PM
    #2568
    Casper421
    In the woods
    06 DC
    I’m still waiting on my front and transfer case skids to arrive.
    Sunnier and Rheywood456[QUOTED] like this.
  19. Dec 16, 2018 at 7:03 PM
    #2569
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Are you still waiting from the Black Friday Sale??
  20. Dec 16, 2018 at 7:53 PM
    #2570
    Casper421
    In the woods
    06 DC
    Yup. The transmission and oil pan plates have arrived. The other two had to be powder coated.
  21. Dec 16, 2018 at 7:57 PM
    #2571
    because_wumbo-truck
    Jon
    Houston, Texas
    U got a link to how you did the drls?
  22. Dec 16, 2018 at 8:10 PM
    #2572
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    what lift are you running with those?
  23. Dec 16, 2018 at 8:24 PM
    #2573
    Casper421
    In the woods
    06 DC
    You mean the wiring? I bought the truck like this. Only thing I’ve done was the fog anytime mod.
  24. Dec 17, 2018 at 12:36 AM
    #2574
    Sunnier
    Sunny
    San Diego, CA
    I've been trying to catch a glimpse of your hands ever since you joined this forum (back when I guessed it was a reference to all the pics members post that show only their hands), before I learned you were actually a @Professional Hand Model. Here I finally get a peek... and it has clothes on. :rolleyes:
    Good write-up on correcting the leak by clearing the channel of the window seal. :thumbsup:
  25. Dec 17, 2018 at 5:44 AM
    #2575
    because_wumbo-truck
    Jon
    Houston, Texas
    Toytec Boss coilovers with SPC UCAs
    Wheelers progressive AAL with 5160s
    potoghi[QUOTED] likes this.
  26. Dec 17, 2018 at 5:45 AM
    #2576
    because_wumbo-truck
    Jon
    Houston, Texas
    Yes. Ok I need to do the fog anytime mod.
  27. Dec 17, 2018 at 6:16 AM
    #2577
    Sunnier
    Sunny
    San Diego, CA
  28. Dec 17, 2018 at 7:01 AM
    #2578
    because_wumbo-truck
    Jon
    Houston, Texas
    On the interview? Thanks :)
  29. Dec 17, 2018 at 9:38 AM
    #2579
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Are those sumperbumps easy to install?
    because_wumbo-truck likes this.
  30. Dec 17, 2018 at 10:32 AM
    #2580
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Let us know how it goes. If bad, you can move up here. I'll hire ya!
