  1. Feb 5, 2021 at 5:08 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Where did you get your catted o2 spacer?
    NWPirate likes this.
  2. Feb 5, 2021 at 5:09 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    i have 3 oak logs sitting over the axle all winter, has been working well
    I would have backed it down over the bank his ass s hanging and then pull onto the road, unless large culvert present.
  3. Feb 5, 2021 at 5:12 PM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    What crack are you referring to in the diff? To me it appears to be a seam with what we would call pando (brand name) at work. It’s a flexible gasket material.
  4. Feb 5, 2021 at 5:18 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    More weight in the back might be a slight help. My last tundra was a 02 2wd v8 and it was hell In the winter but I made it around
  5. Feb 5, 2021 at 5:38 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    The shell is technically a Raider, but I believe it's identical to a Leer or ARE since they're the parent brands. I added a heavy duty gasket to where it seals around the bed and it lifted it a good amount. It still is eating a bit though.
    I found it on eboy. It's surprisingly solid construction. Here's the link:
    https://www.ebay.com/itm/2-PCS-Catt...spacer-90-02-extension-M18-X-1-5/163826751813
    This one is equivalent to the non-fouler spacer I used. You might not need the catted spacers if you can get this one and one or two non-drilled spacers as well.
    https://www.ebay.com/itm/2pcs-02-O2...pter-spacer-M18X1-5-CEL-FIX-Bung/163538721146
    The catted spacer was a last ditch effort to get rid of the CEL and it worked when I added that drilled out spacer.
  6. Feb 5, 2021 at 5:42 PM
    FrenchToasty
    Mo
    Bone stock
    I’m making test pipes for my cats, I think I’ll run the cats for a month to see if I get a code at all, hopefully not. Then I’ll switch to the test pipes and just deal with the CEL until next testing window.
    Darkness and Thrussn[QUOTED] like this.
  7. Feb 5, 2021 at 5:42 PM
    Thrussn
    Gabe
    NM
    I was referring to this one:
    I find it suspicious only because of how uneven in width and depth it seems to be.
  8. Feb 5, 2021 at 5:47 PM
    Thrussn
    Gabe
    NM
    Definitely try the stacked non-foulers before investing in the catted spacer. They are much cheaper. It is pretty odd that 4 or 5 stacked spacers wouldn't fix my issue. Most people can get a fix with only ~2 spacers according to Keith from DirtyDeeds when I spoke to him privately.
  9. Feb 5, 2021 at 5:55 PM
    NWPirate
    Zach
    WA
    Awesome, thanks. :hattip:
  10. Feb 5, 2021 at 6:01 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Casting mold line?
    Lil Steve, Thrussn and FrenchToasty like this.
  11. Feb 5, 2021 at 6:28 PM
    FrenchToasty
    Mo
    Bone stock
    Just some strange differences in the main frame piece that you start the build from, I had to modify it to work, the hole spacing was off, on the plate they sent not my frame rails. I had the patience to deal with it and fix it. the swing out adds a lot of weight
  12. Feb 5, 2021 at 6:53 PM
    shoe07
    shoe07 New Member
    Ohio
    Upon closer inspection I agree. Appears to be some flashing.
  13. Feb 6, 2021 at 8:36 AM
    Professional Hand Model
    Hand Protectors
    Circled back and checked up on the HIR Reverse Bulb Housings to make sure the Zzzztttt! hasn’t creeped in. All looks well!
    two2cal, Darkness and NUDRAT like this.
  14. Feb 6, 2021 at 8:44 AM
    Hand Protectors
    While in there Explored the Junction Box Thingy on the Driver Side. Pulled it apart and found some Gelatinous Mass Protection Fluid (protecting the circuit board) similar to the Hand Model Protection we used in Hollywoo Fire Scenes. Cleaned it up and snapped the cover back on. Slathered some Electric Goo around the perimeter to keep that debris from getting back in there making sure not to block the drain/weep hole at the bottom.
    Darkness, hammeron and Thrussn like this.
  15. Feb 6, 2021 at 9:35 AM
    Hand Protectors
  16. Feb 6, 2021 at 9:38 AM
    shoe07
    shoe07 New Member
    Ohio
    Amazing how much dirt creeps into places you’d never expect it to be.
  17. Feb 6, 2021 at 9:41 AM
    FrenchToasty
    Mo
    Bone stock
    Have they been tracking me this whole time? I don’t recall seeing that when I pulled mine, what does it do?
  18. Feb 6, 2021 at 12:38 PM
    Hand Protectors
    Unsure. Too lazy to research it. Maybe check it later tonight, but think it has something to do with ‘Tow Package’.
  19. Feb 6, 2021 at 1:40 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Broke 270K miles this week. Just did an oil change and replaced the battery hold down bracket.
    old and new pictured. thanks @Coupe
  20. Feb 6, 2021 at 1:40 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If it's attached to the tail light wiring it's probably a convertor for the trailer wiring.
    Newer trucks I believe it's located up in the dash.
  21. Feb 6, 2021 at 1:42 PM
    FrenchToasty
    Mo
    Bone stock
    What is being converted?
  22. Feb 6, 2021 at 1:49 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    It takes the separate turn/stop signals and combines them so it'll work on a regular dual filament bulb.
  23. Feb 6, 2021 at 1:51 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Guess I blew the fuse for these right sided center console outlets. Anyone know which fuse?
    Also now wondering if I can find the covers for these
  24. Feb 6, 2021 at 1:59 PM
    Hand Protectors
    Clean up/cut off the nubs and slip two of these in there. $10 each. In my pic, the cover was hanging by a thread for years. I cut it off after the pic.
  25. Feb 6, 2021 at 2:26 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I use one for the backup camera but that’s an idea.
  26. Feb 6, 2021 at 4:26 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Likely the converter box for the lights
    FrenchToasty likes this.
  27. Feb 6, 2021 at 4:30 PM
    Hand Protectors
    Yeah. Went out and snapped a shot for curiosity sake earlier. Here is a pic of the ‘Towing Converter’ with 2 part#’s which cannot be found on any of my Deep Search Sites.
  28. Feb 6, 2021 at 6:09 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Maybe it’s an island only converter box. Can’t let that slip to the mainland ya know...
  29. Feb 6, 2021 at 6:11 PM
    Hand Protectors
    I think its the St. Barts Package Converter and forgot they added it in with all the Taxes. :rofl:
    CodyP[QUOTED] and Tundra2 like this.
  30. Feb 6, 2021 at 6:14 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Hard to tell from the pic, but I would have backed up way further and gas it out. I've been in funny situations like that too but manage to get out.
    Tundra2[QUOTED] likes this.
