  1. Jan 17, 2021 at 8:04 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Not sure it will apply to all you folks, but I had a noticeable gain in low end torque when I got rid of my side pipe for a full tail pipe.
    oscardog86, Voss and FrenchToasty like this.
  2. Jan 17, 2021 at 8:15 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    So the 89 pickup someone said they had is actually a 98 extra cab taco. If I can get it for less than 1000. I’m grabbing it.. then I’ll deal with shipping the freebie frame from Cali for it.. might be making a 2.4l 5 lug taco a 3.4l 4x4 here shortly... with parts that I mostly have already.
  3. Jan 17, 2021 at 8:19 AM
    empty_lord
    05 rollover special
    Shit I posted that in the wrong thread. DOH
    oscardog86, NUDRAT, NWPirate and 3 others like this.
  4. Jan 17, 2021 at 9:05 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    What’s the story on these center caps. They custom or do the trd caps push through and fit the method wheels? I’ve got the 304’s and really not a fan of the cap sticking out. Method sells the flush caps but some trds would be even better
    NUDRAT likes this.
  5. Jan 17, 2021 at 10:43 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  6. Jan 17, 2021 at 11:19 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    I applied Fluid Film the other day. Super impressed. You would never know this truck is almost 15 years old!
  7. Jan 17, 2021 at 2:35 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Today's scrapyard finds:
    •Passenger lower seat cover, looks real nice for $13 and I need to put the heated seat pad in anyway.
    •Intake manifold and plenum gaskets. I'd never put used gaskets in my truck, just need them as I threw away the old ones and plan to sell the old engine as complete.
    •Hood struts to replace my squeakers.
    •Alternator, knock sensor, and O2 sensor (the one I frantically posted about) harnesses to crimp in.
    •Oil pressure sensor bc I accidentally sold the old engine's one.
    •Rare strut bolt to restore and sell.
    •Radio brackets since I highly modified mine and will eventually replace the head unit.
    •Extra coil packs.
    •Visor screws for @des2mtn (not pictured)
    $38.
    I'm hopeful I can get this engine wire harness back to working condition. It has proven one of the most fragile parts of the engine replacement process.
    hammeron, oscardog86, NUDRAT and 2 others like this.
  8. Jan 17, 2021 at 2:37 PM
    Professional Hand Model
    Hand Protectors
    Wow! Those coils look new. How many miles on them?
  9. Jan 17, 2021 at 2:39 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    No idea, I tried to find out but the truck didn't have any indication on it. The frame was rusty though and everything looked pretty high mileage. That could just mean abuse, though.
    oscardog86 likes this.
  10. Jan 17, 2021 at 2:51 PM
    Hand Protectors
    Went out after coffee this morning to stretch the Hands and put a couple drops of 3 in One Oil on the Throttle Thingy with a toothbrush. This stuff is wonder oil.
    abcinv, HBTundra, oscardog86 and 3 others like this.
  11. Jan 17, 2021 at 2:55 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Installed a quick release fire extinguisher today.
    RJVA, abcinv, HBTundra and 8 others like this.
  12. Jan 17, 2021 at 3:01 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Loving that detailing. Could one just use WD-40 for the same purpose? I believe you recommended it to clean the manifold.
  13. Jan 17, 2021 at 4:58 PM
    Hand Protectors
    Thanks. I’ve tried a few things like oil on a rag, and Aerospace 303, but this 3 in One works good on the Power Steering case, the Thermostat Housing and adjacent pipe, and this Throttle Thingy. They’ve never been cleaned before using this so maybe its the first time look?
    I’ve tried it on some nuts that had some rust and it makes it disappear over a few days. Didn’t make a difference on the Manifold today. Its probably as good as its gonna get after all the shtuff on it.
    Never did try WD40.
    Here is the PS Case I did last month. Still looks just like this. Used to be a dusty rusty brown look. A couple drops on a tooth brush and just scrub it on.
  14. Jan 17, 2021 at 4:59 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    That bright green belt.........
    every time I see it, I think I installed mine wrong. But no.......
    theblurry1 and Thrussn like this.
  15. Jan 17, 2021 at 5:02 PM
    Hand Protectors
    Yeah its freaky green. Its a Gates Heavy Duty. Weights almost double the Continental one I had on there before.
    oscardog86 and theblurry1 like this.
  16. Jan 17, 2021 at 5:09 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Nice find! I always try to keep my eye out for those coil packs but here in Denver when a Tundra comes to U pull and pay or LKQ if your not there in a day that thing is usually picked apart. Ive been looking for a tailgate but Im always too late :annoyed:
  17. Jan 17, 2021 at 5:44 PM
    Hand Protectors
    I’ve had some for sale for a while now. Some are ok shape and some have cracks. Check them out as I dropped the price with the last nibble but the guy never got back with me.
    https://www.tundras.com/threads/first-gen-oem-denso-ignition-coils-used.35152/
  18. Jan 17, 2021 at 6:11 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I would be interested in the 2 coils. One of mine went out about 6 months ago (210,000 miles) and from what I read on posts here when one goes out some are ready to follow. When I come in some extra cash new denso coils will be next on the list.
  19. Jan 17, 2021 at 7:03 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Yeah buddy! I rarely venture up into the central Denver yards, these funds were from my go-to, Littleton U-Pull, which is a little closer to me. They are way more organized and you can see what vehicles they get in every day on their Facebook page.
  20. Jan 17, 2021 at 8:04 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I never knew that there was a U pull in Littleton, I will put them on my watchlist :thumbsup:
  21. Jan 17, 2021 at 9:01 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    The Taco got kicked outside where it belongs because of my Sunday Tundy fundy. Also it was 86 degrees today so I went back to the summer beer - Golden Road Guava Dia.
    I tried using a gear puller among other things to remove the inner axle seal but to no avail. The $12 seal puller from vatozone and some elbow grease made easy work of removing the old seals. I found five bucks in the parking lot so I picked up another set of those leaf spring clamps even though they cost more than five bucks. Dude at autozone really wanted to let the cashier know his Charger was a V8 and not a V6. Now I have a clamp on each side of the axle to accommodate my broken add-a-leafs (band-aid fix). I used brake cleaner to get all of the metal shavings and gear oil out of the axle housing; spent well over an hour on the driver's side. The bearing cage from the damaged bearing put a few nicks in the axle housing, so I sanded them down the best I could. New o-ring as well.
    Putting the inner seals in correctly is a lot more difficult than the Youtube videos make it out to be. I don't know if it's just my truck or what. Last night I mangled two seals trying to put them in using an oversized socket and hammer. Today I asked my dad to see if he'd have better luck, so I put the driver's seal in the freezer for an hour and after twenty minutes of working he and I got it in. He tried hammering against the base of a holesaw rather than an oversized socket. We tried the same method on the passenger's side and he ended up mangling two seals as well. We called over our neighbor who is a retired Toyota tech for his opinion and he gave up before mangling my last seal. He is going to one of his old shops in the morning to look for a special service tool so hopefully we'll have luck with that. He told me I should drop the driveshaft and clean the inside of the pumpkin while I wait for him so I think I will do that since it is not that much more work and I have the day off.
    Breather mod done is also done. Took less than five minutes. Relocated to the gas tank filler area as that seems to be a low-dust area above water. I added a clear fuel filter on it in addition to one of those Dorman OEM breathers. To get the fuel line over the union, I carefully used a cigarette lighter to heat up and expand the fuel line.
    Here's another something from today for all you sports fans out there and SoCal-ers.
    NUDRAT, Voss, hammeron and 5 others like this.
  22. Jan 17, 2021 at 9:05 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Is that whats left of Qualcomm? I head it was getting demolished but haven't seen.
    NUDRAT and oscardog86 like this.
  23. Jan 17, 2021 at 9:09 PM
    des2mtn
    SW
    Tonto cover
    Yep, apparently it is getting torn down piece by piece. It's a spectacle to see considering I've been there sooo many times.
  24. Jan 17, 2021 at 9:49 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    All the way back to Jack Murphy Stadium.
    Just makin sure I recognize hometown less and less every day I guess!
    oscardog86 and des2mtn[QUOTED] like this.
  25. Jan 17, 2021 at 9:52 PM
    des2mtn
    SW
    Tonto cover
    In related news, Ted Leitner is also retiring as the Padres broadcaster.
  26. Jan 17, 2021 at 9:59 PM
    Siebler
    CJ
    Eastern Oregon
    Finally got my ass back in garage. Mounted the bumper I started forever ago up and got the hitch mostly fitted. Little plate and full welds on added pieces and itll be ready to go back on for good.
    RJVA, NUDRAT, FrenchToasty and 9 others like this.
  27. Jan 18, 2021 at 3:49 AM
    Hand Protectors
    Cool bud. Post up on that for sale link that you want 2 Coils for $30. Also, PM me your address so I can get them in the mail this week. Thank you.
    MS22[QUOTED] likes this.
  28. Jan 18, 2021 at 7:53 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    So I double checked my LBJ bolts yesterday. They all moved maybe a quarter of a turn or so until they were torqued so mine seemed alright. I like @empty_lords tactic of checking the torque every oil change. I might have to start doing that. Or atleast at every tire rotation.
  29. Jan 18, 2021 at 9:53 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Same here. And again, none would make my torque wrench click so I just stopped.
  30. Jan 18, 2021 at 10:33 AM
    oscardog86
    Southern California
    Interesting, mine all clicked at the 59 torque setting. I did get nervous when I saw someone posted a photo of a snapped bolt, definitely wouldnt want that to happen!
    Voss likes this.
