  1. Jan 15, 2021 at 11:55 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I take the torque wrench to mine every oil change.
    hammeron, Voss, N84434 and 3 others like this.
  2. Jan 15, 2021 at 12:11 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Anyone have the torque specs for those 4 bolts for the LBJs on hand??
  3. Jan 15, 2021 at 12:27 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Someone can chime in if I'm wrong but I think it's this one.
    hammeron, Voss, Darkness and 3 others like this.
  4. Jan 15, 2021 at 12:30 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I had written down 59 ft-lbs for the 4 bolts and 103 ft-lbs for the castle nut.
    N84434, FirstGenVol and oscardog86 like this.
  5. Jan 15, 2021 at 1:32 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Now I gotta go check mine too. :eek2:
    MS22 likes this.
  6. Jan 15, 2021 at 1:33 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    You know I can't put rusty parts back in after I've removed them. Since I am holding off on an exhaust overhaul for now, I resolved to simply restore my stock headers during the engine replacement and quarantine downtime. It's to help them last for a few more years, and make the engine look cool. I let mine soak in some Evaporust for a few days before wire-wheeling the rest of the rust off, cleaning, priming (pic not included), and painting with a VHT exhaust paint per directions.
    Figured why not do the heat shields too, including the wire loom one, because why not.
    Maybe one day I'll be wealthy and can afford those fancy stainless exhaust parts y'all like, such as long tube headers. Until then I'll settle for good looks.
    What are you guys' opinions on wrapping exhaust components?
  7. Jan 15, 2021 at 2:48 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    New tires today. Came home and changed oil.
    134,000 miles best truck I've ever owned.
    Voss, MS22, Rheywood456 and 7 others like this.
  8. Jan 15, 2021 at 2:54 PM
    Professional Hand Model
    Hand Protectors
  9. Jan 15, 2021 at 3:57 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    malo.
  10. Jan 15, 2021 at 3:58 PM
    artsr2002
    'Yonder
    Muy malo
    NUDRAT likes this.
  11. Jan 15, 2021 at 4:03 PM
    Hand Protectors
    Seems SN (Situation Normal) for this time of year on the truck. I’ve been doing lots of short trips under a mile. Checked PCV and it looks good. No worries here.
    MS22 and NUDRAT[QUOTED] like this.
  12. Jan 15, 2021 at 4:10 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I run 33x10.50R17 and have zero rubbing. I love pizza cutters.
    oscardog86 likes this.
  13. Jan 15, 2021 at 4:40 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Finally got the Tundra in for an alignment today. While it was in a shop had them change the oil & rotate the tires.
    When it was done, he let me know I was low on coolant, but he topped it off along with the washer fluid.
    Checked it over, because i do that & because he literally took almost 30 minutes to get the skid plate reattached. WTF?
    Alignment feels good. The overflow tank full of pale green fluid - NOT good.
    Now instead of 'watch it', i have to do a system flush - but first have to do a pressure test to find out why it was low.
    Are there no professional professionals in this city? So frustrating.
  14. Jan 15, 2021 at 4:43 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I continued my paint restoration project today and have a couple of questions.
    What is the best way to remove this lower window trim? I'd like to prep and paint it.
    [​IMG]2021-01-15_05-30-14 by GhostCreekMine, on Flickr
    ... and what is the best way to remove these OE decals? They're stuck well and I expect they're pretty brittle.
    [​IMG]2021-01-15_05-30-38 by GhostCreekMine, on Flickr
    Progress for today: I was able to finish the front quarter panel and passenger door (also that fiberglass strip above the front bumper). Slow going but I'll get there.
    [​IMG]2021-01-15_05-28-58 by GhostCreekMine, on Flickr
    To PHM and others... from a previous thread. The tips you gave me regarding emblem removal worked excellent! Heat gun + fishing line does the trick. I sanded them and used adhesion promoter & bedliner to black them out. I ordered FuzeIt to reinstall as recommended by you shadetree geniuses. Should get here next week sometime.
    [​IMG]2021-01-15_05-29-33 by GhostCreekMine, on Flickr
  15. Jan 15, 2021 at 4:54 PM
    Hand Protectors
    Try the Heat Gun on the stickers, as well. Per the window trim: I sanded and painted mine right on the door without removal. Used some Blue Tape, Paper, and a Plastic Bag over the mirror. Sprayed with Bedliner. Holding strongly.
    oscardog86 and Glock 40[QUOTED] like this.
  16. Jan 15, 2021 at 5:12 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Roger that, thank you!
  17. Jan 15, 2021 at 5:54 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I think I am about to order a set of those in that size. What do you think?
    Jerry311SD[QUOTED] likes this.
  18. Jan 15, 2021 at 9:13 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Got a good start to my three day weekend of Tundy fundy. I will finally be finishing my rear disc brake conversion.
    Went to the DMV without an appointment to pick up the truck's new black personalized plates. In and out in less than 25 minutes.
    I also picked up my axles from the machine shop. Brand new housings, bearings, seals, ABS rotors, everything. The backing plate for my disc brake conversion mounts differently than the OEM drum backing plate.
    Undamaged bearing vs damaged:
    Damaged ABS rotor vs undamaged:
  19. Jan 15, 2021 at 9:51 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Kinda blows my mind that the FSM calls for only 48 lb/ft on these. I used red loctite when doing mine and also ordered new OEM bolts purely out of fear.
    oscardog86 and NUDRAT like this.
  20. Jan 15, 2021 at 10:18 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  21. Jan 15, 2021 at 10:27 PM
    des2mtn
    SW
    Tonto cover
    They made me put it on before going in, I wish I had asked for an extra to have as a keepsake. For now mine is stuck on my Corolla's dash.
    Jerry311SD and Darkness[QUOTED] like this.
  22. Jan 15, 2021 at 10:30 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    My wife went in this week but they got us both with the temp gun and gave us both stickers. At the door only she went in.
    des2mtn[QUOTED] likes this.
  23. Jan 15, 2021 at 10:48 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Do it! This is the second set on this truck.
    I've had these on every truck I've owned.
    onesojourner[QUOTED] and NUDRAT like this.
  24. Jan 15, 2021 at 10:55 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I found a camper shell for the bed and it was only $150. The paint is crusty and the rear hatch seal needs to be replaced. It's mint otherwise and I even have the key for it.
    I also hit a mileage milestone
    hammeron, abcinv, artsr2002 and 6 others like this.
  25. Jan 15, 2021 at 10:56 PM
    empty_lord
    05 rollover special
    check with a body shop. my guy painted my cap for 200 bucks.
  26. Jan 16, 2021 at 12:06 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Whatever you decide to do with it, here is a guide on how to spend 3 times what you paid for it on paint and supplies.
    *Gratification not implied
    https://www.tundras.com/threads/06-dc-daily-driver.48447/#post-1259889
    oscardog86 and Darkness like this.
  27. Jan 16, 2021 at 5:59 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah it seems odd but there must be a reason for it. Those bolts aren't that stout and it here is what happens when you over torque them.:anonymous:
  28. Jan 16, 2021 at 7:29 AM
    empty_lord
    05 rollover special
    05-06 have bigger bolts
  29. Jan 16, 2021 at 7:54 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Fascinating. I wonder if I could have taken my oem axles to a machine shop when the mechanic said the seals would no longer sit right and charged me over a grand to put new axles and seals in (which did fix the issue).
  30. Jan 16, 2021 at 8:23 AM
    oscardog86
    Southern California
    So with my truck being an 01, do i torque to 59 ft/lb like previously stated or the 48 ft/lb like just recently stated?
    FrenchToasty likes this.
