  1. Jan 10, 2021 at 3:37 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  2. Jan 10, 2021 at 3:38 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  3. Jan 10, 2021 at 3:39 PM
    FrenchToasty
    Mo
    Bone stock
    Nice, his copper gaskets only run like 7$! And it’s like a real piece of copper, check them out
    NUDRAT and empty_lord[QUOTED] like this.
  4. Jan 10, 2021 at 3:48 PM
    empty_lord
    05 rollover special
    Oh I bet they’re great. I was meaning for emergency repairs. (Unlikely) lol
  5. Jan 10, 2021 at 3:51 PM
    FrenchToasty
    Mo
    Bone stock
    So I was also going to put flex pipes on my straight pipes; so those will be on 99% of the time including off-roading, in case I bump them. I like your idea of a removes left tailpipe for off roaring. If I can’t keep it high enough maybe that’s an option I can look into, bed side dump would be cool AF though
  6. Jan 10, 2021 at 3:52 PM
    empty_lord
    05 rollover special
    Does the factory exhaust even have a flex joint? I was wondering if I should put. One in for each bank
  7. Jan 10, 2021 at 3:57 PM
    FrenchToasty
    Mo
    Bone stock
    There is a weird thing near the transfer case heat sink, not the heat sink itself but almost something that could be a flex joint? I’m tempted to put them in because why not? And also that other member that had some strange flex cracks possibly.
    I do wheel a decent amount and feel like it would be worth it and a peace of mind
  8. Jan 10, 2021 at 4:03 PM
    empty_lord
    05 rollover special
    those are weights for resonance
    NUDRAT and FrenchToasty[QUOTED] like this.
  9. Jan 10, 2021 at 4:44 PM
    recomr
    recomr New Member
    Recently ordered:
    - Dobinson IFP Front Struts
    - Dobinson 314 Springs
    - SPC UCA
    All from Mike at ExitOffroad (thanks Mike!). Looking forward to getting them on next week. Waiting on their rear monotube non remote resi to come out.
    Also coming in next week:
    Stealth Custom Series F5 17x9 -38 Matte Dark Bronze
    STOKED!
    My truck:
  10. Jan 10, 2021 at 4:47 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I always just fill it until it runs out. I did it a few weeks ago and got a little more than 3 quarts in.
    NUDRAT likes this.
  11. Jan 10, 2021 at 4:47 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well, where would you start on correcting that?
    I have no reason to believe these numbers are inaccurate. Running rich would explain the "hotter feel" in the bay, and would explain the fuel loss.
  12. Jan 10, 2021 at 4:52 PM
    empty_lord
    05 rollover special
    I’ve had issues with non oe injectors pushing too Much fuel.
    Tundra2[QUOTED] likes this.
  13. Jan 10, 2021 at 4:55 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    In that case whats your ltft @Tundra2 ? (Long term fuel trim)
    Tundra2 likes this.
  14. Jan 10, 2021 at 5:01 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That was my first thought also. I am running 48 more fuel holes than stock injectors (24 stock vs 72 dirtydeeds) They tested out fine, and I thought that the extra holes would help atomize the fuel thats being squirted in.
    I'll see what six denso 4-holes would run.
  15. Jan 10, 2021 at 5:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Showing my engine ignorance here, by saying no clue.
    I'll see if my scanner can read that. I turned a lot of the options off for easier read on the video. I may have turned that one off too by mistake since I was doing it on the fly.
    Darkness likes this.
  16. Jan 10, 2021 at 5:20 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Interesting. I wonder why 4 didn't fill mime up. Did you do it while the fluid was warm? I did it cold. Truck on a slight decline.
  17. Jan 10, 2021 at 5:38 PM
    empty_lord
    05 rollover special
    Ltft long term fuel trim and short term. Negative is pulling fuel, positive is adding fuel. Long and short should add up to roughly 5-0% + or minus.
    NUDRAT and lsaami like this.
  18. Jan 10, 2021 at 6:13 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I just go until it spills over, maybe in the early manuals they got their conversions messed up because I believe they state the transmission pan only holds 2 qt’s which is wrong as well.
  19. Jan 10, 2021 at 6:34 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Im guessing nose end facing down? That would be why. Supposed to be checked when level.
    An extra quart won't hurt anything. On the smaller 6.7" diff (rwd car) which are 1.3L factory fill capacity, some are filled with just over 3qts. This is so under G-load the fluid doesn't fill the axle tube and leave the gears dry mid sweeper.
    FirstGenVol[QUOTED] likes this.
  20. Jan 10, 2021 at 6:45 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    All done.
    -2.5” Toytec boss coil overs
    -JBA UCA
    -OEM lower ball joints
    -Front sway bar links
    -Front diff serviced and extracted stripped drain plug
    -New drums, shoes and hardware
    -Both rear wheel seals
    With any luck, I’ll have the new wheels and tires on tomorrow but most likely Tuesday.
    Voss, N84434, 2006 Tundra AC and 10 others like this.
  21. Jan 10, 2021 at 6:59 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    level ground, cold
    NUDRAT likes this.
  22. Jan 10, 2021 at 8:29 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I don't recall if I ever gave a follow up regarding the header issue. It turns out the reason my header was cracking is likely because of the JBA Y-pipe that I have installed. It has a weird (likely put of spec) twist in it that was putting a lot of twisting stress on that one header. This stress was especially bad when I would hit bumps while off-roading. My cat delete got rid of that stress, but it was pretty obvious when I was pulling everything apart.
    Are you sure it's resonance? It really seemed like they were counter weights to help pivot on the hanger and reduce downward stress on the exhaust manifolds.
    I have no idea and you'd be the expert more than me though.
    FirstGenVol and Darkness like this.
  23. Jan 10, 2021 at 8:32 PM
    Thrussn
    Gabe
    NM
    This is exactly what I was thinking.
    The sensors are feeding back into the ecu to perfect the A/F ratio though, right? I wouldn't think a 12 pin injector that pushes the same cc's would change too much. I think mine actually leaned out my long term fuel trims when I did it.
  24. Jan 10, 2021 at 8:36 PM
    empty_lord
    05 rollover special
    Typically heavy weights on exhaust or drivetrain components are for resonance. It adds mass to kill noise or vibration. In this case, likely vibration.
  25. Jan 10, 2021 at 8:43 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats interesting. I also have the JBA y pipe, maybe from the way I bolted it up I am not seeing stress that way. The flange from my driver side cat to the y doesn't align properly though and there is a small exhaust leak there. One day I will cut the pipe to realign it but that day won't come soon.
  26. Jan 10, 2021 at 8:47 PM
    empty_lord
    05 rollover special
    Honestly if I do headers the way I’m thinking I might just use a spring bolt pivot style flange for the exhaust to be able to articulate a little bit at the collectors
    Darkness[QUOTED] likes this.
  27. Jan 10, 2021 at 8:49 PM
    empty_lord
    05 rollover special
    The. Again, RWD engine layouts typically don’t need any flex... so I may not. As long as the exhaust isn’t forcing in any direction on the collectors you shouldn’t have any issue
  28. Jan 10, 2021 at 9:06 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Flex pipe section might not be bad. Something like this
    FrenchToasty likes this.
  29. Jan 10, 2021 at 9:15 PM
    empty_lord
    05 rollover special
    im not a huge fan of those just because they love to break at 5-8 years old out here
  30. Jan 10, 2021 at 9:31 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Before I record this next video, I found my long fuel trim, and short fuel trim.
    Leaving both exhaust sensors. Vehicle speed, engine speed, and coolant temp.
    Anything else I should add to help you guys help me?
