  1. Jan 6, 2021 at 8:20 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    be careful with a tape job - you might want to just disconnect them under the hood as well. One of them will be the trailer brake activation wire, and one will be 12V power.
    NUDRAT and FirstGenVol[QUOTED] like this.
  2. Jan 6, 2021 at 9:37 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Lots of good quality videos out there on YT. It's not that bad, especially if you have a basic skill set for doing mechanical work. Only special tool needed is the crank pulley removal tool.
    https://www.amazon.com/Toyota-Crank...a-782479832855&psc=1&ref=&adgrpid=76361197332
    Thrussn[QUOTED] likes this.
  3. Jan 6, 2021 at 10:40 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I feel the same way. On other cars I feel scared but will do the timing belt. On my truck I just feel overwhelmed by it. Too many cams and too expensive if it goes wrong.
    Thrussn[QUOTED] and Casper421 like this.
  4. Jan 6, 2021 at 11:29 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    And only needing to do it once a decade prevents remembering anything about what you did last time. Practice makes perfect....
  5. Jan 6, 2021 at 2:33 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You're talking about the 2 going to the battery?
    I also have 2 sets of wires mounted to the firewall.
  6. Jan 6, 2021 at 2:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Rear end went out of Bertha rolling 55. Coasted to the safe zone.
    Due to a miscommunication Mom, and I both showed up to retrieve poppa.
  7. Jan 6, 2021 at 2:45 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I have a similar setup in my 4runner. Those are breakers. I would just disconnect the battery from those if that is an option until you fix your 7 pin.
    Tundra2 likes this.
  8. Jan 6, 2021 at 3:32 PM
    Professional Hand Model
    Hand Protectors
    Seat Covers came in today. Looks and feels high quality Himalayan Back Country Sheeps Skins. :bananadance:
  9. Jan 6, 2021 at 4:17 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    :worthless:
  10. Jan 6, 2021 at 4:19 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
    You’ll have to forgive @Professional Hand Model he’s new and doesn’t know all the rules and customs.
  11. Jan 6, 2021 at 5:47 PM
    pullupthendown
    pullupthendown New Member
    2006 Tundra Double Cab SR5
    Care to share? I’m looking for some different ideas.
    NUDRAT likes this.
  12. Jan 6, 2021 at 6:00 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Correct, I’d just unhook them right from the battery and not worry about the other end. Tuck em out of sight.
  13. Jan 6, 2021 at 6:29 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Well the epoxy attempt for the sunvisor pivot did not work, as expected. Just scraped partly off.
    Some in channel window visors from the rainforest warehouse showed up. They were still new and unopened lol. Awesome deal for <$12 & free shipping.
    Installed:
    There wasn't enough light left this afternoon to install my bumper trim, now that it has had time for the paint to cure.
    MS22, NUDRAT, abcinv and 3 others like this.
  14. Jan 6, 2021 at 6:36 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Hopefully this makes since.
  15. Jan 6, 2021 at 6:54 PM
    fighthedude
    fighthedude New Member
    How many white tail you seeing out there? That area looks awesome. Hope Bertha gets back on the road
    NUDRAT and Tundra2 like this.
  16. Jan 6, 2021 at 7:05 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I think you meant to quote me?
    Anyways, I see a few from time to time :D
    https://youtu.be/v_GdPPUDg3Q
    https://youtu.be/DiqvBJiNqWQ
    https://youtu.be/BlivxUJHEP4
    https://youtu.be/mRQV9pNUOak
    Power lines, raccoons, and birds too. :p
    https://youtu.be/OM6SVfA06Zg
    https://youtu.be/Dr9tHRgxiSY
    https://youtu.be/G4i0blmm5jg
    https://youtu.be/F_O8cY9RoYk
    https://youtu.be/9xLgilxanNg
    https://youtu.be/_e8JSqcj4xY
    Not sure how tempting pushing Bertha into the tent of pain is... may contract that job out if the quote is right.
  17. Jan 6, 2021 at 8:09 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I think I’m even more confused after trying to figure this out.
  18. Jan 6, 2021 at 8:19 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    The first picture is looking up at the shell the lines you see run down to the hand winch on the wall straight ahead. The lines just have loops that I stick around each bolt. So to take the shell off I take the nut off each corner. Then I lift each corner and put the loop around the bolt . Thats the hardest part. Sometime in the next few months I will get a rack on the shell then it will be a 5 minute job.
  19. Jan 6, 2021 at 8:23 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Still trying to picture it. Looks like the first picture is from the passenger side. That would mean the winch is on the driver side. How are you lifting the shell from only the two passenger corners?
    Tundra2 likes this.
  20. Jan 6, 2021 at 8:24 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Yeah, and there are two more lines on the driver side. You can kind of see the four blocks up there with pulleys on them.
  21. Jan 6, 2021 at 8:45 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Wish I could also be dusting my engine bay instead of sticking a shop crane in it! Finally got the ole' 2UZ-FE pulled the other day and am moving right along with the replacement. Hardest part was separating the transmission/torque converter, I can see why some might pull the tranny with it. Did my best organizing all the bolts, nuts, and parts---during the heat of pulling only a couple of wire harnesses didn't get disconnected until the engine was hanging, there are a lot of random grounds, sensors, and loom clips on this motor and I hope I remember where they all go!
    Everything looks decent for the amount of miles it had, of course aside from the head gasket blowing, and rust. Couple of questions on what to replace vs swap over to the newer engine:
    Motor mounts,
    Mine look okay, but I probably should replace them as I'll never be able to again.
    -Any good aftermarket brands that aren't basically $100 apiece like Toyota's?
    -Anyone used Moog?
    Starter,
    It's a B to replace without the engine pulled, but mine still works fine with 260k miles.
    -I have no way of knowing if it's original, but would you replace it?
    -Where can I get the heavy duty cold weather version?
    Alternator,
    This one I'm sure is original! It looks ancient and works just fine.
    -Should I simply replace the brushes (the part that actually wears) and call it a day?
    -Or not take the chance of a roadside repair?
    If I was like @Professional Hand Model I'd be fancy and measure resistance, etc. to judge its life, but alas, I'm not.
    Sensors,
    Again, everything worked; however, I'm not against preventative maintenance while it's easy.
    -What should be bought new? The 4 O2 sensors? Crankshaft position, throttle position, and water temperature sensors?
    -Unfortunately one of the wires came out of one of my knock sensor's harness. Is there a fix?
    Other parts I'm replacing include timing belt kit (w/water pump), manifold, plenum, and exhaust manifold gaskets, miscellaneous other gaskets, O-rings, and bolts. I'll swap over my new valve cover gaskets, restored valve covers, new spark plugs, and all the other bits and pieces the used engine won't come with.
    I'll be restoring my stock headers as I'm not ready to do an exhaust overhaul. I'll be painting many components with high heat paint like those and heat shields. I'm most excited for a) the truck to run again, and b) the Dirty Deeds re-manufactured 12-hole injectors y'all seem to swear by! I think in the end it's going to run tons better than ever.
    MS22, Darkness, hammeron and 3 others like this.
  22. Jan 7, 2021 at 4:10 AM
    Hand Protectors
    Mounts: If they are ok then reuse them, but you gone this far so spending extra is ok?
    Starter: Your local stealer should have the 2.0kw.
    Alternator: $150 for a rebuild Denso is a no brainer. The bushings/etc cost $20-30 so just a little more for factory rebuilt.
    Sensors: Get all new Densos o2’s. The other sensors like crank and cam @empty_lord said should be ok keeping original as the don’t go bad. Unfortunately, the Knock Sensor is mangled and those are touchy. Not sure how to fix.
    @theblurry1
    MS22, theblurry1 and ktundra like this.
  23. Jan 7, 2021 at 4:19 AM
    Hand Protectors
    Pretty cool system you have.
    FrenchToasty likes this.
  24. Jan 7, 2021 at 5:50 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What do you mean by this? Are you installing short tube headers? The engine pictured doesn't have them. Now would be a great time to install shorties which doesn't require you to change anything with the exhaust.
    theblurry1[QUOTED] likes this.
  25. Jan 7, 2021 at 7:34 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Stevinsons Toyota participates in the Toyota online program and they have pretty good pricing and it's local so no shipping. McGeorge is still slightly cheaper even with shipping, but it's nice to go pick it up in two days and if I have a warranty issue I can just take it back..
    MS22 and theblurry1[QUOTED] like this.
  26. Jan 7, 2021 at 7:36 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    I meant I'm just restoring what I have, because I heard on here that short tube headers aren't worth it and offer little to no HP/torque gain, while long tubes do have benefits, but require changing out other exhaust parts.
  27. Jan 7, 2021 at 8:28 AM
    Hand Protectors
    Thats what Kieth at DD told me last week. Thanked him for not taking my money.
  28. Jan 7, 2021 at 9:41 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Thanks for reading all of that! Hahaha so basically buy all the things, huh. ;) At least I can sell many of the old parts and recoup some of the funds. Good to know about the other sensors not really going out, that's new info to me. I'll look more into the knock sensor harness stuff, I don't see why I couldn't solder on a new harness connector. Appreciate the opinion on the mounts and starter.
    Yep, they are usually my go-to, but I found an out-of-state Toyota that is way cheaper, I'll price out both and see if a trip into Denver is still less expensive than the other's with shipping.
    I feel like this is the anthem of many "performance upgrades." I don't know much about modifying engines, I just know most bolt-on parts---cold air intakes, throttle body spacers, headers, and even tuners---don't yield nearly as much added HP as promised, and one can drop a lot of money on placebos or tiny increases.
    Amazon has some "performance" coil packs for the 4.7, I'd be interested to see if anyone's running them over the Densos (and yes, I know OEM are undisputed reliability-wise). If they actually are an upgrade, I might not even benefit from them with stock fuel pump, etc.
    NUDRAT and oscardog86 like this.
  29. Jan 7, 2021 at 11:25 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Maybe I misunderstood. I unhooked those from the battery and I now have now power at all. One of those wires runs into the bottom of the fuse panel. I'm guessing this one needs to be hooked back up to the battery?
    The other runs to a connector beside the battery.
  30. Jan 7, 2021 at 11:32 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Was that the 4 flat connector or the 5?/7?-Round?
    (Every automobile we've ever owned has used the 4 flat so I can never remember the other two. :p)
