  1. Dec 31, 2020 at 5:17 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I spent extra on the Nickel stuff last time I bought anti-seize. It's so much nicer than the copper junk. Doesn't separate as much and good to go for an extra many 100s of degrees.
    After fighting and then paying my fabricator/machinist friend to unfuck some stud holes in the 911 heads (exhaust studs did not come out nicely), I gladly paid for the best anti-seize I could find commercially.
    Darkness, Tundra2, jpink and 2 others like this.
  2. Dec 31, 2020 at 10:27 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
  3. Dec 31, 2020 at 10:44 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Haven’t been on in a while, but this week I got my bed line-x’d and wheel/tires (275/70/17 BFG’s) on. Went to get it aligned per SoCal57’s specs and shop says my driver side ball joint is shot. Looks like it’s time for complete front end rebuild... What is the quickest easiest way to find part #’s for below parts? Should I go aftermarket for any of these parts? @Roman please provide a quote?
    • Front Upper Ball Joint - Qty 2 (43310-39016)
    • Front Lower Ball Joint Passenger Side - Qty 1 (43330-39466)
    • Front Lower Ball Joint Driver Side - Qty 1 (43340-39356)
    • Front Outer Tie Rod End Passenger Side - Qty 1 (45046-39465)
    • Front Outer Tie Rod End Driver Side - Qty 1 (45047-39295)
    • Front Inner Tie Rod End - Qty 2 (45503-09120)
  4. Dec 31, 2020 at 10:57 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
  5. Dec 31, 2020 at 10:57 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I use this method for finding exploded diagrams and parts numbers. Replace local dealer with a local dealer, might have to try a few dealer names. This is how I got all the proper part numbers for my front end rebuild.
    https://toyotaparts. local dealer .com/
    Better yet, here's a link: https://trdshop.carlocktoyotaoftupelo.com/oem-parts/toyota-lower-ball-joint-4334039356?c=YT10b3lvdGEmbz10dW5kcmEmeT0yMDAxJnQ9c3I1JmU9NC03bC12OC1nYXM=
  6. Dec 31, 2020 at 11:14 AM
    Professional Hand Model
    Hand Protectors
    I use a similar cross-reference technique. Toyotapartsnow dots coms is a good reference point utilizing your VIN#, as well.
  7. Dec 31, 2020 at 11:21 AM
    des2mtn
    SW
    Tonto cover
    Vin verification on these sites is definitely piece of mind.
    LBJ failure is no joke though.
    theblurry1, Voss, artsr2002 and 2 others like this.
  8. Dec 31, 2020 at 11:25 AM
    Hand Protectors
    Ordered up some side view mirror glass replacements from Dormans.
    Ordered up 2 Sheepskin Seat Covers because they keep you warm in winter and cool in summer. I had a pair on the truck from 2002 until 2013 and really liked them.
    Darkness, N84434, NUDRAT and 5 others like this.
  9. Dec 31, 2020 at 11:27 AM
    Hand Protectors
    Yeah. I had the factory recall done in 2006. Put another new Toy OEM pair on in 2018.
    des2mtn[QUOTED] likes this.
  10. Dec 31, 2020 at 12:06 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Started raining last night around 12-1am. Verified no issues with my Bluetooth FM adapter in the rain.
    Also verified the radio controls on the steering wheel match the instrument cluster green color.
    Gorilla tape didn't stop the dash noise. :(
    theblurry1 likes this.
  11. Dec 31, 2020 at 12:16 PM
    Hand Protectors
    Went ahead and pulled the trigger on some upcoming Prevent Maintenance Shtuff coming up next month. Bolts/Nuts are to replace the y-pipe flange rusted ones.
    FrenchToasty likes this.
  12. Dec 31, 2020 at 12:55 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    Where did you order this stuff from? Does a Preventative Maintenance master spreadsheet pdf exist?
    For Instance
    Timing Belt - Every 100,000 miles
    Front End Suspension (shocks, ball joints) - mileage ?
    Steering (tie rods, column bushing, etc) - mileage ?
    Brakes (pads/rotors) -
    Fluids
    Etc...
    I would find this very helpful as I purchase a high mileage tundra with little to no service history. At this point I am replacing items as the break or wear out.
    theblurry1 and NUDRAT like this.
  13. Dec 31, 2020 at 1:02 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Most of us can't afford PHM's preventative maintenance schedule ....:rofl:
  14. Dec 31, 2020 at 1:49 PM
    Hand Protectors
    There is one somewhere. I think my Stealer provided it when I bought the truck so I’ll look around. The manual has some suggestions on the basics. FSM provides more detailed info on Ohms Testing certain Sensors like MAF, Coils, o2 Sensors, etc.
    Timing Belt 90k miles or 9 years.
    Front end suspension on mine started creaking and squeaking at 120k miles. You’ll know when its time when it drives like a boat and the Cams Bolts can’t align the front anymore.
    Steering you’ll know if its bad. Leaky rack, PS Pump whining. Tie rods I’m not sure how to test.
    Brakes Pads have depth wear grooves and squealers to let you know.
    Brake Fluid 3 years, but its so cheap and easy DIY you should do it sooner. Transmission Fluid 20-30k miles if towing. A little more if not. Or, do a drain and fill like an oil change during your normal engine oil change (3-5k miles). Cheap and easy DEXIII.
    Truth is I didn’t do anything to this truck other than fluids and tires all by others for the first 16 years I had it. She never broke down or had a major problem other than a bad coil pack.
    Check my build page for pics and more info.
    NUDRAT and Jerry311SD like this.
  15. Dec 31, 2020 at 1:53 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Did a bit more on the camper today.
    Fold out table or stove holder with rubber bumpers so it wont rattle when im driving.
    Also installed roof net for lite item's like jacket or towel. And holder for Mr buddy heater when im not using it.
  16. Dec 31, 2020 at 2:07 PM
    Hand Protectors
    Come to think of it haven’t done much spending on the truck these last few months. Mostly some tinkering with dumb stuff for free. Everything is basically done at this point with the early conclusion of the Timing Belt back in October. Hoping for good results on the Oil Pump Leak ‘jackleg FIPG fix’ once I drop the Skid Plate for oil change and inspection soon. Been driving lots of short less than a mile trips these past couple months. Brutal on oil/engine. :annoyed::rofl:
    Voss likes this.
  17. Dec 31, 2020 at 2:54 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    have a factory skid plate if anyone wants it.
  18. Dec 31, 2020 at 3:02 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Did you get a new one from Skid Row?
    jImmegart[QUOTED] likes this.
  19. Dec 31, 2020 at 3:11 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Fer sure, my friend. HNY!
    N84434[QUOTED] and Tundra2 like this.
  20. Dec 31, 2020 at 3:26 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It seems like its always the drivers side that is worse on everyone ones rig. Wonder why?
    Anyways, I know this would be challenging. Let us know what you decide.
    :spending:
    N84434[QUOTED] and NUDRAT like this.
  21. Dec 31, 2020 at 3:29 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  22. Dec 31, 2020 at 3:36 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Shadow dancing?
  23. Dec 31, 2020 at 3:55 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Darkness and FrenchToasty like this.
  24. Dec 31, 2020 at 4:08 PM
    jImmegart
    Jonah
    California
    Ya, I was just going to paint this one, but I impulsively bought a skidrow one night right when I got my pay check. It cleans up the front alot though so Im happy with it :)
  25. Dec 31, 2020 at 4:26 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What that'd run you? I may upgrade my plastic one. All these years I thought it was metal because I wasn't paying that much attention. Lol
  26. Dec 31, 2020 at 4:29 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Passengers side is buttoned up except for the tie rod/sway link I'll connect those when I put my rack, and bar back on.
    Under its own weight, bounced, and torqued. Everything moves proper. Now that the sun is down its getting real cold, real fast even with the tent.
    New mevotech sway bushings came in today.
    N84434 and NUDRAT like this.
  27. Dec 31, 2020 at 6:07 PM
    jImmegart
    Jonah
    California
    theres a promo code I used that I need to find, but it was 212 after tax and free shipping for the skidrow one.
    Tundra2[QUOTED] likes this.
  28. Dec 31, 2020 at 6:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oooooh. Are there pictures in the armor thread?
  29. Dec 31, 2020 at 7:13 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Sprayed the visor hinge and installed. Darker than OEM but as long as it's gray and not tan I can live with it.
    Visor will now stay up. Not as well as my passenger side but waaaaaay better than before.
    Grabbed a can of Rust-Oleum universal bonding primer and then did the color coat on the bumper trim. I think I'll hit it lightly with 600 grit and do another color coat, maybe some clear as well.
  30. Jan 1, 2021 at 12:27 AM
    jImmegart
    Jonah
    California
    never heard of this armor thread o_O
