  1. Dec 29, 2020 at 9:12 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Got a tire rotation/balance done this morning. On the way home, my maint reqd light came on. I'll check the oil tomorrow and do an oil change this weekend if I get a chance.
  2. Dec 29, 2020 at 9:31 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Snagged the driver side visor hinge out of this thing. Tired of mine hanging down 1-2".
    I'll probably end up painting it, as it's a different color to my interior.
    Grabbed the center bumper trim for the 03-06 front end and gray steering wheel radio control switch from a Sienna (matching green LEDs). Found a local parting out an 05 4runner limited and got everything needed so I can add radio controls.
    Just not sure if I should use the leather wheel or not. I like how easy the plastic is to keep clean.
    MS22, Darkness, chrisb and 5 others like this.
  3. Dec 30, 2020 at 6:39 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    More upgrades coming soon! I am mostly working on cleaning and fixing it up right now.
    NUDRAT, artsr2002, abcinv and 3 others like this.
  4. Dec 30, 2020 at 7:33 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Did you really add 12 circuits?
    If so, I'm curious what they all are.
    Jerry311SD[QUOTED] likes this.
  5. Dec 30, 2020 at 7:58 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Ha ha. No
    I just have my Rigid lights, CB Radio and power going back to the camper. I might add one or two things down the road.
  6. Dec 30, 2020 at 8:00 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    you have a link for the one you got?
  7. Dec 30, 2020 at 8:03 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
  8. Dec 30, 2020 at 9:16 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I only asked because you had fuses in all the slots.
    I have a much smaller version of that fuse block in the 911 and I don't keep a fuse in the open circuit.
  9. Dec 30, 2020 at 9:43 AM
    notlikejohnny
    notlikejohnny New Member
    Shenandoah Valley, VA
    2005 4WD DC Limited, Phantom Grey
    Drivers side leaf, frame overlap area now...
    I have the exact same issue on my 2005 DC. Not a speck of rust anywhere else on the frame, i spent some time underneath before buying a year ago and sometime this summer I was under it doing fluids and noticed the delamination issue of the overlap. I'm really worried its going to cause it to snap eventually. I cleaned it up with a wire wheel to get all the loose stuff off and hit it with Rustoleum Rust Converter. Unfortunately I don't think it's helping and needs a better solution. So now I need to go out and grind off what I put on, and I guess POR-15? Not sure what the consensus is with this area of treatment. Plus the gas tank blocks most of the access on the driver side. Either drop the tank, or remove the bed for proper access and mitigation.
    Also the previous owner had it treated by the dealership twice with their frame coating solution. Its starting to flake off, so I'll be spending a lot of time scraping that off as well and then doing Fluid Film over the whole frame I think. Anyone know of issues of putting FF or similar product over POR-15 (I'll apply the POR only in the problem areas, not the entire frame).
  10. Dec 30, 2020 at 9:51 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I need to upgrade my 5100s to these 5160s. You like em so far? What did you come from?
  11. Dec 30, 2020 at 10:04 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    As someone with the same delam in the stiffener as pointed out here (with other goodies along these pages thanks to @N84434)
    I've pulled the bed, but have not dropped the gas tank. My gut instinct says that both would yield the best access to this area.
    N84434 and notlikejohnny[QUOTED] like this.
  12. Dec 30, 2020 at 10:06 AM
    notlikejohnny
    This is fantastic news for me too. After seeing @FirstGenVol and @Tundra2 pictures and I have the same problem that I noticed after buying it (after I thought I had inspected it thoroughly):frusty:. Definitely added to the, "will do" list, because I bought this baby with 140K on it from the original owner here in VA. I've spent a lot upgrading it with the intent to keep it to 300K at least. This gives me hope. I had no idea it was a stiffener that can be replaced.
    Any idea if this is something a dealer would do, or is this something a fabricator would have to do? Can you buy the stiffener?
    Tundra2[QUOTED] likes this.
  13. Dec 30, 2020 at 10:08 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Also, woke up a little early to pull one side of the Cams back out to peel the sticker off of it.
    It probably doesn't matter, but I was thinking while commuting last night that the paper based sticker may draw, and hold moisture. Best to remove it, and be safe.
    If toyota had used a plastic based sticker I would have left it.
    Darkness, NUDRAT and chrisb like this.
  14. Dec 30, 2020 at 10:17 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I doubt a dealer would do this, and I have no idea if you can buy that independently.
    I'm sure if we could figure what kind of hokey ass name toyota calls it then we could pull up an exploded parts diagram.
    When the time comes for me to do this job, I was just going to see what @N84434 would charge to make a set. That is TOTALLY up to him.
    I would like to make one, but I do not have the metal working tools on premises to do that level of work.
    I would love nothing more than to send some money to one of our best contributing members for a service.
    :spending:
    N84434 and jpink like this.
  15. Dec 30, 2020 at 11:40 AM
    notlikejohnny
    Absolutely agree. If he would decide to do so, I would gladly support his skillset with my wallet. I don't have the skillset let alone the tools to make it happen myself.
    I did a quick google search for and exploded frame diagram and it doesn't seem to be included. I guess its considered part of the frame and not replaceable by Toyota. But it seems silly that this piece couldn't be removed and replaced for a fraction of the cost of replacing an entire frame, dealing with the recalls etc.
    N84434 and Tundra2 like this.
  16. Dec 30, 2020 at 4:16 PM
    artsr2002
    'Yonder
    Looks great. Factory fresh.
    So Fresh, So Clean
    -Outkast
    MS22 and 2006 Tundra AC[QUOTED] like this.
  17. Dec 30, 2020 at 4:24 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Today I made a bracket and wrapped it for my voltage meter and USB charger in the camper today.
    Brown Bear, Voss, lsaami and 6 others like this.
  18. Dec 30, 2020 at 5:26 PM
    Bleek182
    Bleek182 New Member
    Josh
    Minden NV
    2006 sr5 double cab
    Came from the yellow Bilstein so far so good
    CodyP[QUOTED] likes this.
  19. Dec 30, 2020 at 5:28 PM
    Bleek182
    Bleek182 New Member
    Josh
    Minden NV
    2006 sr5 double cab
    Got dem 6112 done today on my sons truck. Going to have the Camburg UCA’s done so the alignment gets done correctly
  20. Dec 30, 2020 at 5:38 PM
    Bleek182
    Bleek182 New Member
    Josh
    Minden NV
    2006 sr5 double cab
    Selling the old ones if anyone is interested off a 2006 crew cab 4x4
    They have a 1 inch spacer on them already
    Darkness, Tundra2 and Jerry311SD like this.
  21. Dec 30, 2020 at 7:58 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    Final clear coat on the top side tomorrow, when Shame Garage is warmer, but I’m very happy with the results so far. I didn’t buy a 5th matching wheel for the spare because I didn’t want to put it in the rust hole, but now I feel better about the idea.
    The immediate focus was on the spare tire holder space. 2021 will bring more attention to the rest of the areas. I hear @Tundra2 is renting his Nerve Tent out on the weekends.
    I also got all the Noico 80mil on the doors. I gave up and spent some time with the dog instead of putting any on the back panel. Tomorrow I will get the 315mil installed over the 80.
    Monday it gets dropped off for the roof sanding and coating. Gotta have it drivable by then.
    Oh, also sanded and hit the rusty (driver side only) door parts behind the weather stripping with a couple coats of Rust Reformer. Cleaned those pieces up too. Will hit the stripping with 303 tomorrow.
  22. Dec 30, 2020 at 8:43 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Did a few small things. Lots of pics. Everybody likes pics. ;)
    Popped the dimmer knob off and re-clocked it 90 degrees. I already had it's brightness set there, so now my very minor OCD is happy the diagram sits level.
    Here's the stubby antenna I used to run on my Tacoma that I put on a few months ago (and didn't grab a pic then). Ignore the tree remnants which I haven't washed off.
    Went full TuRD gen with a stainless allen and O-ring. The no-tenna mod.
    I'll have to see how it is in the rain. My XM & BT adapter uses FM to transmit to the OEM radio. On a previous vehicle no antenna (or allen) was ok when dry but went to crap in the rain. :notsure:
    Went by an automotive paint supply store and had some color matched enamel paint made for the bumper trim. Also stopped by vatozone for some charcoal grey trim paint.
    Yanked my drivers sunvisor and removed the pivot/mount. The good pivot from the junkyard will get painted if the temps are warm enough outside tomorrow.
    You can see how the original is really worn compared to the other. Without that edge on the notch these things just droop too much.
    The trim paint is darker but so little shows it shouldn't bother me like the brighter tan would.
    Also wet sanded the spare bumper trim with 600 grit in prep for paint if warm enough tomorrow.
    When the interior is cold (below 40-50 degrees) the dash squeak from the radio bezel at the top came back. The one that I thought I eliminated by removing the metal center clip. I've just been living with it for the last month or so.
    Gonna try this trick out and see if I can shut her up again. Some gorilla tape to space the bezel a hair out, if I had some cloth Tesa tape I probably would have used that instead. Only 1 layer at the moment but I may try 2-3 if 1 isn't enough.
    Swapped the radio control internals of the 4runner switches with the Sienna ones. This makes the color switch from orange to green.
    Circuit boards, wiring and pinouts are identical. Only difference is the LED colors.
    Since I have an '05 SR5 my dash/radio harness was pre-wired for radio controls and I have the correct clock spring. Simple to add controls, just disconnect battery, swap airbag/switches/harness and reconnect battery.
    I'm considering trying to source the right side switches for BT phone controls, if I get a radio capable of it.
  23. Dec 30, 2020 at 9:09 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    jpink[QUOTED] and NUDRAT like this.
  24. Dec 30, 2020 at 10:58 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    remove stickers, lather the cams with anti seize.. your alignments will be doable for years to come
  25. Dec 30, 2020 at 11:03 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    My gut instinct was correct then. Mainly...
    Grease is not acceptable?
  26. Dec 30, 2020 at 11:08 PM
    empty_lord
    05 rollover special
    grease wont last as long. anti seize will last longest. but even it will eventually be gone. in my trucks i pull the cam tabs at work every couple years and reapply.. but i have an alignment rack at my disposal.
  27. Dec 30, 2020 at 11:19 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Any old anti-sieze? I know there are certain greases for certain things.
    An alignment rack would be real suweet
    NUDRAT likes this.
  28. Dec 30, 2020 at 11:45 PM
    empty_lord
    05 rollover special
    Nickel anti seize is what I use (nuclear grade... but that’s just because I get that for free)
    Tundra2[QUOTED], NUDRAT and chrisb like this.
  29. Dec 30, 2020 at 11:48 PM
    empty_lord
    05 rollover special
    marine grade might be best.. since its being battered in the north by salt water effectively
    Tundra2, Jerry311SD and NUDRAT like this.
  30. Dec 31, 2020 at 5:16 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I appreciate the confidence guys. I'd have to give this some real thought. It's one thing to make a set of T-Top storage bags for a 300ZX ( My wife and I used to make those for fellow members on the 300ZXClub Forum), but fabricating those frame stiffeners...? I'm no journeyman welder, and I'd hate to have something fail because of my fab skills.
    The other hurdles include measuring the frame to create a template, ensuring the upper and lower legs will fit correctly in the contour of the existing frame, prepping the existing frame for installation and repairing any rust that may be on the existing frame.
    My right side frame was in fact very clean and required very little prep work, the left side however, did have a small rust hole in it which required fabricating a filler and doubler to repair the frame before installing the stiffener. Much of the stiffener fab work required multiple fittings in the frame to ensure my replacements fit like a factory part.
    Longstory short, it's not impossible, but it would be a little difficult to pull this off.:thumbsup:
