  1. Dec 12, 2018 at 4:27 PM
    #2431
    Outbound
    Aaron
    Northern Alberta
    Yeah, the stock stereo sounds great to me. I never bothered swapping out the speakers and probably never will.
    I had Sirius sat radio in my Ford. Cancelled it after the first year once I tried Spotify. I only listend to 2 channels on Sirius so it wasn't worth it to me.
    Sunnier likes this.
  2. Dec 12, 2018 at 5:03 PM
    #2432
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Sneak peek of current projects
  3. Dec 12, 2018 at 7:39 PM
    #2433
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I did nothing. God damned company Christmas party got in my way.
    Sunnier and Outbound like this.
  4. Dec 12, 2018 at 7:56 PM
    #2434
    Outbound
    Aaron
    Northern Alberta
    Those are such a drag eh? The Woman's turned out to be on the same night as mine. Used that as an excuse to not go to mine. Going to hers which should be a quick dinner and done.
    Darkness[QUOTED] and Sunnier like this.
  5. Dec 13, 2018 at 8:31 AM
    #2435
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    If you are able to find a P/N for blue lights let me know. I have a good solder station and cant wait to change out my stock stereo lights.
    I found some on Amazon. I need to see how much voltage is going to these light first before i order. the blue surfacemount light i found are 3-3.5 v Ill take a mesurement tonight when i get home.
  6. Dec 13, 2018 at 2:18 PM
    #2436
    Professional Hand Model
    Hand Protectors
    Nothing better to do today, but pull all the small fuses out and sand/clean contacts. Did both engine bay and interior boxes. Both locations every fuse looked similiar to this one example before and after cleaning.
    BEFORE
    AFTER
    potoghi and Jerry311SD like this.
  7. Dec 13, 2018 at 2:30 PM
    #2437
    Hand Protectors
    Messed around yesterday and today with some Sharpies. Trying to spice things up without getting too hoopty. The steering wheel is not finished yet. I’ll end up outlining the red with some fine tip black to highlight it. The locks tabs need some cleaning up with acetone around the edges tomorrow.
    HIGHLIGHTED THE VENT INDICATORS (BLACK)
    FILLED IN THE FADED ORANGE WITH RED AND FRAMED WITH BLACK (clean up bleeds tomorrow).
    STILL SOME WORK LEFT ON THE WHEEL. FEELING IT OUT AS IT PROGRESSES (Red Toy and black dots).
    Will outline Toy Symbol tomorrow in black.
    04DCbuild, Darkness and FirstGenVol like this.
  8. Dec 13, 2018 at 2:41 PM
    #2438
    Hand Protectors
    Tightened every 10mm nut under the hood/engine bay as I noticed many were loose. There are about 30. Took about 5 minutes. Fabbed up a new bracket screw ith rubber washer along with underlying plastic anchor washer to hold the side blinker with the headlight frame body. Old one went MIA.
    Darkness, Musashi66 and Jerry311SD like this.
  9. Dec 13, 2018 at 2:46 PM
    #2439
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You have too much time on your hands sir. :D
  10. Dec 13, 2018 at 3:06 PM
    #2440
    Hand Protectors
    Yes. Yes I do. Might be dis-assembling the engine next week just for grins. I see they have a gasket kit for rebuilds. Not.
  11. Dec 13, 2018 at 3:07 PM
    #2441
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    Noticed some weird rattles from under the truck upon cold start up. Crawled under, and I’m pretty sure it’s the exhaust heat shield brackets on the drivers side, right under the driver. I’ll have to Pb blast them to see if they can be tightened or removed and replaced. They are metal on metal, so no place for rubber washers or anything like that to absorb vibrations. But the noise annoys me so I’ll have to fix it.
    because_wumbo-truck likes this.
  12. Dec 13, 2018 at 3:13 PM
    #2442
    Hand Protectors
    Grab some SS snake clamps from big box. Undo the clmps and wrap them around the pipe and tighten. Did a few a few years back. Better than factory clamps. No need for bushing.
    Brown Bear and Sunnier like this.
  13. Dec 13, 2018 at 4:11 PM
    #2443
    because_wumbo-truck
    Jon
    Houston, Texas
    Was under the hood today and couldn't locate the PCV on my 06 v8. It was really easy to find in my 3.4L v6s
  14. Dec 13, 2018 at 4:16 PM
    #2444
    Musashi66
    Is there anything you haven't done to your truck?? Thanks for the info!
  15. Dec 13, 2018 at 4:21 PM
    #2445
    because_wumbo-truck
    Jon
    Houston, Texas
    Anyone install Rago Fab ditch light brackets? Gunna tackle em tomorrow. Maybe wire em Saturday when I install my bumper and wire the reverse lights
  16. Dec 13, 2018 at 4:26 PM
    #2446
    Musashi66
    It's easy to find, it's on the right side when you're facing the engine, under a foam-like shroud. This video shows it well
    https://www.youtube.com/watch?v=PT3fa-tutYU
    Removal is fairly easy as well - remove the hose clamp, remove the hose, remove the foam shroud, pull it out, and reverse the process.
  17. Dec 13, 2018 at 4:27 PM
    #2447
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If memory serves, drivers side in the front between the valve cover and manifold.
  18. Dec 13, 2018 at 4:35 PM
    #2448
    Hand Protectors
    Under the foam cover. Be carefull as your grommet bushing may be deteriorated/dryrotted. If it is and you pull the PCV out the pieces of grommet will fall down inside and will have to fish with needle nose or vacuum out. Best thing is to buy a new PCV and grommet so if the old breaks you have back up right on the spot.
  19. Dec 13, 2018 at 4:40 PM
    #2449
    Musashi66
    I bought mine on Amazon for $10 or $13. Saw them for less but with shipping, or I wasn’t sure if they were OEM. One I bought for my 2000 was identical to the one I removed. I don’t really know what pcv valve does, so I figured I might as well replace it at that price range.
    I bought this
    https://www.amazon.com/dp/B00KTG5HJY?ref=yo_pop_ma_swf
  20. Dec 13, 2018 at 4:45 PM
    #2450
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I know this is an old post but I just came across it and it's funny because I was just thinking I NEVER see regular cab's. Now I have!
  21. Dec 13, 2018 at 4:52 PM
    #2451
    Hand Protectors
    It vents some of the heat build up and facilitates the ventilation of gases through the engine and back into the throttle body to be burned off in combustion.
    Mine was bad for about two years when I didn’t do a thing to the truck (gasp!). When I motivated about keeping this truck and not buying a new $50k Tundra (nice but) the pcv and valve cover gaskets were the first on repair list.
    I have a suspision the PCV valve is a culprit to a few things/complaints I’ve read in the many threads here, but they chase the wrong solution. 1) Engine (slightly) overheating. 2) Loud engine noise/ticks. Both of this things went away when the PCV valve was replaced and switched to Full Synthetic.
    Its such an inexpensive replacement. Get a new grommet though! Might have to do stealership.
  22. Dec 13, 2018 at 8:17 PM
    #2452
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    wait.. regular cabs exist??! Never saw one.
    BestGen likes this.
  23. Dec 13, 2018 at 9:15 PM
    #2453
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    You should try to do the wheel logo with a vinyl wrap. It might come out much cleaner.
  24. Dec 13, 2018 at 10:15 PM
    #2454
    Casper421
    In the woods
    06 DC
    Nothing really but placed orders for a matching SCS Stealth 6 and Cooper st maxx. I’ve never gotten a flat on a 10 ply but now I’ll have a full size spare just in case.
  25. Dec 14, 2018 at 6:49 AM
    #2455
    Hand Protectors
    I think when I do the black outline will bring it home and tighten it up. Otherwise, that vinyl wrap is great idea.
  26. Dec 14, 2018 at 7:33 AM
    #2456
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  27. Dec 14, 2018 at 7:37 AM
    #2457
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Not to mention that very unique color. It's like gray with a hint of violet...? I think Toyota offered some colors that you don't see very often.
  28. Dec 14, 2018 at 7:37 AM
    #2458
    Festerw
    Festerw New Member
    04 Tundra DC
    That's funny because I see them and T100's around here all the time.
  29. Dec 14, 2018 at 8:30 AM
    #2459
    because_wumbo-truck
    Jon
    Houston, Texas
    What's crazy is I used to see those all the time and then one day it's like they all disappeared. I still see T100s around Houston pretty often though.
  30. Dec 14, 2018 at 9:19 AM
    #2460
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Keep an eye out for 2 tone trucks. Dont see many of those either.
