  1. Dec 27, 2020 at 11:54 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the fact i have to hook up the remote functions is why i keep holding back.. i did talk to n2 designs about getting one of their setups working that uses the factory fob.. but theyre too busy at the moment to look into it.. hopefully in the future they will.
  2. Dec 28, 2020 at 12:01 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Correct, relay coil trigger doesn't care which side gets +/-. It's an electromagnet.
    No need for the white/black as a ground. The only ground for the relay necessary is for the relay coil to trigger which comes from the alarm itself.
    artsr2002 and NUDRAT like this.
  3. Dec 28, 2020 at 12:03 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I'm going to try the other diagram. Basically all that diagram does is break the detection wire connection when the locks are activated. That's why the relay used is a 5 pin relay. Both sides of the detection wire are tied to posts 30/87a. This way, when the relay is at rest, the detection circuit is normal since 87a is a normally closed pin on the 5 pin relays. When the unlock command is received, the negative signal, grounds out the relay and cuts the detection circuit by switching 87a to 87 to which nothing is connected.
    NUDRAT likes this.
  4. Dec 28, 2020 at 12:09 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Holding back from?
    RC/AC are easier than a DC to wire locks into an alarm.
  5. Dec 28, 2020 at 12:11 AM
    empty_lord
    05 rollover special
    i prefer to use the original fob not to mention the horrible experience ive had with remote start control boxes shitting the bed and leaving me with tearing out the module to get my fathers truck started
  6. Dec 28, 2020 at 12:15 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Just pulled the adjustment plates off the pass side. I see why I couldn't get an alignment now.
    Both cam sleeve ends broke off inside the plate. :eek:
    Good thing I was going to replace those anyways. :)
  7. Dec 28, 2020 at 12:16 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Worth a shot. It is a simpler setup. Always good to follow the k.i.s.s. principal.
    You may also need to check the programmed lock/unlock pulse duration. Maybe it's super short and the relay isn't triggering fast enough (like .2 sec, when over .5 sec would work).
    Good luck.
    NUDRAT likes this.
  8. Dec 28, 2020 at 12:37 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm seized in blue, and if I got anymore I'll round off the brake tube fitting.
    I'm not seized in red.
    I suppose I could replace this whole little section of tube.
    Anyone have a link?
    Edit: never mind. I forgot I had map gas handy. Little heat, and wiggle. :rofl:
  9. Dec 28, 2020 at 12:47 AM
    artsr2002
    'Yonder
    One a more positive note, Krud Kutter, which I purchased at my local Big Blue box store, does an excellent job of cleaning grease stains. Sprayed directly on the seat cover, let it sit about 20 seconds, then scrubbed with a microfiber towel. Stain is mostly gone. Nice!
    oscardog86, Darkness, MS22 and 5 others like this.
  10. Dec 28, 2020 at 1:30 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  11. Dec 28, 2020 at 9:02 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Glad you got it off! I had the same problem and just replaced the lines, the hard lines are only $8 each.
  12. Dec 28, 2020 at 9:11 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It sounds like you already got it, but are you using flare nut wrenches? It will help avoid rounding the soft metal.
    Darkness and Tundra2[QUOTED] like this.
  13. Dec 28, 2020 at 9:12 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes. Flares on the brake lines. I did get it. Still tried to round before I put some heat on it.
  14. Dec 28, 2020 at 11:32 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well...
    Front sway bar is off. Rack is pulled back, and on jack stands. Burned up all my Sawzall blades.
  15. Dec 28, 2020 at 11:33 AM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    So you’re saying you’ve earned a lunch break?
  16. Dec 28, 2020 at 11:34 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    No, I've been working on this for 12 hours now. No lunch for me.
  17. Dec 28, 2020 at 11:38 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  18. Dec 28, 2020 at 11:54 AM
    jpink
    Knoxville
    “Liked” for dedication.
    Tundra2[QUOTED] likes this.
  19. Dec 28, 2020 at 12:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It is beer:30 though. First beer in a month or so.
    Upper spc arm is on. Halfway cut through the lower arm bushings.
    Ordering Diablo blades... bought all the cheapo blades from local RK. Bought one pack of milfuckeeee. Burnt em all up.
    My breakfast of oats this morning 13 hours ago is gone.....
  20. Dec 28, 2020 at 12:13 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Finally had some time to:
    1. Change the front differential oil. Was quite dark.
    2. Tranny drain and fill. (second drain/fill since I have owned the truck)
    3. Adjust the front/rear brake bias a bit more.
    4. Spray the undercarriage with fluid fill. Virtually no rust as it was/is a CA/AZ truck.
    theblurry1, MS22, Filthyphil and 6 others like this.
  21. Dec 28, 2020 at 12:33 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I work in gravel as well so I commend you. I can’t see further down your frame, but I always throw the tire I removed under the truck under the frame rail for one of those just in case moments. I use steel plates under my jack stands because they sink strangely and make me nervous. Then once I’m solid, I give her lots of shakes and pushes to make sure she’s solid on the stands. I’m sure the tire makes a good seat for working from, but so does a milk crate
  22. Dec 28, 2020 at 12:55 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It is a fantastic seat. I have two jack stands for the steering rack (that i have no idea how im gonna put back on by myself...) and two under the frame that are sitting on concrete papers 4 inches thick.
    I'm too heavy for milk crates...
    Buckets sit too high...
    I have a small success.
    And a small injury from about 9 hours ago...
    oscardog86 and Darkness like this.
  23. Dec 28, 2020 at 1:00 PM
    empty_lord
    05 rollover special
    Soo yea, future reference, a 6” cut off wheel works wonders cutting those things out
    Kimosabe, Tundra2[QUOTED] and chrisb like this.
  24. Dec 28, 2020 at 1:02 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I think Just For Men makes a fix for that 'injury'
    Darkness and Tundra2 like this.
  25. Dec 28, 2020 at 1:04 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Wear your glasses man. Safety squints don't count!
    Voss, jpink, FrenchToasty and 2 others like this.
  26. Dec 28, 2020 at 1:06 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    How the hell do you keep making those buttons that become pictures?
  27. Dec 28, 2020 at 1:10 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I was wearing my glasses, but I was holding a flashlight in my mouth. So my head was tilted back.
    I almost threw up when the clip hit my eyeball at mach 2...
    1. Upload your picture.
    2. Highlight it
    3. Add a "spoiler"
    4. Title your spoiler.
  28. Dec 28, 2020 at 1:17 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    My eyeball looked much worse earlier
  29. Dec 28, 2020 at 2:34 PM
    Professional Hand Model
    Hand Protectors
    Your dirty hand reminds me of the one day I worked in the mine with Pops. I could not handle my hands getting so dirty like that. Had to use Gojo with Pumice and that ruined my hands for a few days! The Lanolin wasn’t so bad as its Aú Naturél.
  30. Dec 28, 2020 at 2:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm still shy a brake line, torquing everything down, and a few other little items.
    theblurry1, Darkness, N84434 and 5 others like this.
