  1. Dec 16, 2020 at 1:17 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    Thanks!, I'll go take some measurements. And to answer the previous question - yes, the handle is in this position when the cover is clamped securely to the bedrail.
  2. Dec 16, 2020 at 1:31 PM
    Casper421
    In the woods
    06 DC
    @abcinv Found a pic on my phone, hope it helps:
    NUDRAT likes this.
  3. Dec 16, 2020 at 1:39 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Drilled some holes to install a hopkins easylift torsion bar.
    I drilled the bedside hole 5/16" lower than the recommended 3 3/4" mark, this kept the bar from rubbing against the hinge.
    Used some rustoleum gunmetal spray paint I had laying around, sprayed onto the box and used a q-tip to apply to the freshly drilled holes.
    Holds the weight of the tailgate and plastic bedliner cover by itself.
    It actually holds it so well that it doesn't fully drop flat. You can tell by the cables, it still has an inch or so to drop.
    Maybe if I had drilled the tailgate hole about 1/2" further down it may not have done this. I'll probably have to weaken it with some heat or remove it and twist it some.
    I can close the tailgate with one finger now, thats pretty nice.
    theblurry1, artsr2002, NUDRAT and 7 others like this.
  4. Dec 16, 2020 at 1:43 PM
    abcinv
    Tommy
    South of ATL
    It does, thanks!
    My handle and your rear clamp seem to be in about the same position (see pic 1). I can adjust the handle so I can tuck it in closer to the bed (see pic 2). So the only question; is there enough room behind your box for the handle to tuck. The handle extends down 6" from the bottom of the bedrail so it's too long to leave straight down, or so seems by looking at your pic.
  5. Dec 16, 2020 at 2:46 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I wouldn't. I'd just let the metal in the bed/tailgate fatigue naturally a bit and let the spring 'settle'. There's a lot of leverage on that spring with the gate all the way down/open.
    NUDRAT likes this.
  6. Dec 16, 2020 at 2:56 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    I'm probably going to replace both front Drl and blinker housings first since they are held tight with zip ties and get full of moisture after a wash or rain....(whatever that is).
    I figure this will buy me some time and if they cloud up again, i will polish them again cuz it was ez-pz and i got more discs and polish left. I'm getting my 13 bucks worth out of this shit.
  7. Dec 16, 2020 at 3:00 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I was going to like this post, but your flagrant disrespect for the AC prevents me from doing so. :D
  8. Dec 16, 2020 at 3:01 PM
    Professional Hand Model
    Hand Protectors
    The second polish isn’t as pretty iirc when I did mine. Its like a one and done. Still have the little 3M buffer pad for my drill!
    Tundra2 likes this.
  9. Dec 16, 2020 at 3:18 PM
    Hand Protectors
    Trying to name this picture. First thought was ‘Textures’ then I was thinking ‘Black Gold Peak Earth Splash’. Might use this to fund raise $ for my ‘Non-Profit’. Is it artsy? Best answer wins a free pair of used Hand Model Gloves.
    Darkness likes this.
  10. Dec 16, 2020 at 3:20 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Greta?
    Pollution?
    The future?
  11. Dec 16, 2020 at 3:20 PM
    Hand Protectors
    3 strikes. Next batter...:rofl:
    Tundra2[QUOTED] likes this.
  12. Dec 16, 2020 at 3:21 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  13. Dec 16, 2020 at 3:24 PM
    abcinv
    Tommy
    South of ATL
    hitch lubed like crazy for no good reason??
  14. Dec 16, 2020 at 3:29 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Haha after I got the mail and was walking by my truck after work, I looked at my ball hitch and thought to myself “ do I need grease?”
  15. Dec 16, 2020 at 3:52 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    It'll be years probably before the spring looses that much tension if I leave it alone. Since I don't leave the tailgate down and I'm not using the truck daily.
    Also there's nothing in the tailgate/bed that will fatigue.
  16. Dec 16, 2020 at 3:58 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    fuck, and I though my frame had waves :bucket:
  17. Dec 16, 2020 at 4:02 PM
    FrenchToasty
    Mo
    Bone stock
    Soft whisper
  18. Dec 16, 2020 at 4:11 PM
    NWPirate
    Zach
    WA
    You grease your balls like you grease your frame.
    Nice work
  19. Dec 16, 2020 at 7:16 PM
    bassman417
    Paul
    Las Vegas
    1. crusty old Ball hITCH.
    2. keep it greasy so it will tow down easy...
    3.molten Tundra tow Knob.
  20. Dec 16, 2020 at 7:34 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
    Drove it a bunch and noticed I now get a 3x Maint Reqd light when turning it on. So I ordered a Veepak OBDII dongle.
  21. Dec 17, 2020 at 4:34 AM
    Hand Protectors
    Thank you to all of you that responded with a sense of humor. :rofl: So the Award Winner will be announced tonight 6pm St. Bart time. Any last minute guesses will still be considered.
    My last minute guess:
    Wurrld Grease
    Will I award myself the gift? Stay tuned.
  22. Dec 17, 2020 at 4:52 AM
    FrenchToasty
    Mo
    Bone stock
    That’s your oil change reminder, it will go solid soon when the timer is up
    jpink[QUOTED], NUDRAT and chrisb like this.
  23. Dec 17, 2020 at 4:57 AM
    daveyjames207
    daveyjames207 New Member
    Dave
    2013 SR5 DC 4x4 5.7 Off Road Nautical Blue Metallic
    Schmeg Griffin.
    NUDRAT, chrisb and Tundra2 like this.
  24. Dec 17, 2020 at 5:39 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Your pictures are not showing up. I'll snap some pics showing space behind the box but I can already tell from Chris's pics that your double cab bed has more room than mine.
  25. Dec 17, 2020 at 5:44 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Does anyone remember which plug is the DRL?
  26. Dec 17, 2020 at 5:51 AM
    jpink
    Knoxville
    :anonymous:
  27. Dec 17, 2020 at 5:52 AM
    FrenchToasty
    Mo
    Bone stock
    The reminder is usually set for every 5k FYI, so you don’t HAVE to change the oil depending on your driving habits
  28. Dec 17, 2020 at 7:51 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    For anyone curious, it's the bigger one mounted to the side of the fender. Just got it disconnected.
    Grumpy74 likes this.
  29. Dec 17, 2020 at 8:23 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I bought this stuff and respray every 6 months. It's been a year so far since I did the 3m kit and the headlights are still clear.
    MEGUIAR'S G17804 Keep Clear Headlight Coating
    bassman417[QUOTED] likes this.
  30. Dec 17, 2020 at 8:44 AM
    rock climber
    I'm having this weird issue in my sequoia where my fan feels like it's blowing cold air if my fan is on 1, if I turn it up higher then it's fine. I'm wondering if maybe my blend door is partially stuck. Any other ideas.
    Also, where is the blend door, I looked online at some parts diagrams, but couldn't see it.
