  1. Dec 4, 2020 at 12:09 PM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    Disagree, big photos are bomb! I love when I check the forum on my real computer instead of the phone.
    So much truck!
  2. Dec 4, 2020 at 12:50 PM
    Professional Hand Model
    Hand Protectors
    iPad is nice to view things.
  3. Dec 4, 2020 at 1:08 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    For me, typically, if I can't do it from my phone it doesn't get done.
    Darkness and FirstGenVol like this.
  4. Dec 4, 2020 at 2:21 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    It's gotten cold here in Colorado and my truck has started doing some weird things. When I start it up in the morning the overdrive light is on, and I have to click it off each time. Any ideas on that?
    Also, the steering wheel is really had to turn. I read that it could be the u-joints on the steering shaft. I'm goin to check it out this weekend, but just wanted to see if anybody had other pointers on what to look for.
  5. Dec 4, 2020 at 2:26 PM
    Hand Protectors
    Which year model?
  6. Dec 4, 2020 at 3:29 PM
    rock climber
    06 DC SR5
    I also found out my hvac knob doesn't go all the way to defrost, full defrost is actually floor, but full vent is full vent. I'm really hoping it's just that the teeth on the white dial under the knob have jumped.
  7. Dec 4, 2020 at 4:00 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    ]Pulled the diff put and took it to the shop to be redone. I'm 99% sure the noise I get is a bad pinion bearing since the wear pattern and backlash were within spec.
    I also put in those red stainless steel brake lines. I hope bleeding the brakes won't be too bad. I would love to hit my underbody with a power washer, but I have to put it together first.
  8. Dec 4, 2020 at 4:20 PM
    Hand Protectors
    They gave my pedal a consistent feel through the push down. IOW, before my pedal was soft on the initial push until feeling the potatoe in the pedal.
    Now, the pedal has the same soft initial push and the brakes engage evenly through the push. A more lineal feel. Same brake pedal depth just a different smoothing out consistent feel.
    Thrussn[QUOTED] likes this.
  9. Dec 4, 2020 at 5:58 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Disabled the always on A/C micro-switch for the floor-defrost and defrost vent positions. Only one side has to be disconnected, unclipped the wire back to behind the fan switch, routed up through a hole and back so it hangs over one of the blend door cables. No chance of rattles or it being in the way.
    Got tired of the squeak from the center of the dash over the radio. Noticed if I put pressure on the center of the top of the radio bezel it went away. Since I had the radio bezel off I removed the top center clip and the noise is gone now.
    Also snapped a pic of the stick on pad that helped quiet down the door rattle some.
  10. Dec 4, 2020 at 6:25 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I need to do this myself. Thanks for the pictures! :thumbsup::)
  11. Dec 4, 2020 at 6:29 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    No problem.
    Probably one of the few good things about the 05-06 factory amp being in the rear pass storage area... extra room to disconnect it.
    I tend to leave the vents on floor-defrost but don't always want AC on. So I'm pretty happy it was a simple and easy mod to do. I was worried I'd have to figure out techstream lol.
  12. Dec 4, 2020 at 6:38 PM
    Thrussn
    Gabe
    NM
    That's great to hear! I think the tundra brakes are way too mooshy. I plan to do the 4runner/lexus brake upgrade when I can justify it. I hope the SS lines do the same for me.
  13. Dec 4, 2020 at 7:35 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    95% of the time I leave mine on one of the two defrost settings. I must have missed your tag where it says '05. I'm wondering if my '02 will be that easy also.
  14. Dec 4, 2020 at 7:52 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Shouldn't be a problem. The amp is back far enough you probably have more than enough room.
    More info/pics here:
    https://www.tundras.com/threads/disable-ac-in-defrost-mode.58403/page-3
    Darkness and Tundra2[QUOTED] like this.
  15. Dec 4, 2020 at 8:08 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  16. Dec 4, 2020 at 8:48 PM
    04 Tundra
    04 Tundra New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    Yep I made a form about changing headers. Here are a couple of pics
    Mustanley, Voss, jpink and 3 others like this.
  17. Dec 4, 2020 at 8:55 PM
    04 Tundra
    Albert
  18. Dec 4, 2020 at 10:33 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    One...single....dimple. then I broke my Hydraulic pressure pump.
  19. Dec 5, 2020 at 7:38 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    High angle cv boots installed. Also got my 5th rim/tire installed. Need to give my truck a bath!
    Ignore the umbrella in the LX470..haha window went off track last night and we had a small sprinkle.
  20. Dec 5, 2020 at 7:43 AM
    Hand Protectors
    Those look extremely well made. They look stout, as well. Nice smoov bends and both sides have the bungs! These look like winners.
    Tundra2 and 04 Tundra[QUOTED] like this.
  21. Dec 5, 2020 at 7:57 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm feeling more confident about headers. Pretty sure I'll do long tubes at some point.
    @FrenchToasty , when are you installing yours?
    jpink likes this.
  22. Dec 5, 2020 at 8:08 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I haven’t ordered all my parts yet, but I’m hoping by the end of January. Just trying to be wise with funds and not buy crap that’s not necessary right now with holidays on the front
  23. Dec 5, 2020 at 10:37 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Today I snugged up all the bolts on my sliders and finished my annual fluid film application. The frame looks sexy. Fluid film is a neat product. It's can do a variety of jobs. I spray my battery terminals with it and I also wiped it all over my front bumper.
  24. Dec 5, 2020 at 10:42 AM
    Hand Protectors
    Been using the little bit left over from a few years ago on my Lawn Mower Blade. Keeps it slick and from grass build up adhering.
    CodyP, Jerry311SD, NWPirate and 3 others like this.
  25. Dec 5, 2020 at 5:28 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Yup got them medium duty vs their regular light duty.
  26. Dec 5, 2020 at 5:39 PM
    Voss
    2003 AC TRD 4x4
    Today I finished what I started on Thanksgiving.
    - changed my rear diff oil with Lucas.
    - Installed rear diff breather ext
    - changed front diff oil
    - installed both front axels, rebuilt 1 and had to restrap the other as it was leaking grease.
    - installed new front wheel bearings, hubs etc.
    - installed onboard compressor
    - mounted switches for compressor and light bar
    - almost decided to torch the truck when I was almost done last week but my front passenger brake line started leaking while flushing the brake system. I didn’t torch the truck, came to my senses before I could find the lighter fluid.
    Over a week later, got the new Blake line and caliper line. Today, I drove my truck.
  27. Dec 5, 2020 at 5:41 PM
    Hand Protectors
    Voss[QUOTED] likes this.
  28. Dec 5, 2020 at 5:42 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Does changing the headers change the exhaust sound? I don't want it to be louder, but obviously I'm all about HP/MPG gain.
  29. Dec 5, 2020 at 5:42 PM
    rock climber
    :rofl::rofl::rofl:
    I've some so close so many times on different vehicles. I changed the timing belt on my brothers golf years ago and then realized I'd put the pulley on backwards :angrygirl:
    Darkness, Tundra2 and Voss[QUOTED] like this.
  30. Dec 5, 2020 at 7:46 PM
    04 Tundra
    Albert
    I didnt do any testing for hp but I couldnt really spin my tires on a dry road but I can now . Also i blew a hole in my resinator it was very rusty though but it happened after i changed my headers when I was accelerating onto the highway. You definitely have more airflow I can tell you that much for sure.
    chrisb, Voss, FirstGenVol and 4 others like this.
